Testarossa oil filter collapse | FerrariChat
Discussion in 'Technical Q&A' started by TonyHill, Feb 1, 2012.
  1. TonyHill
    TonyHill Rookie
    Feb 1, 2012
    4
    Michigan
    I am writing on behalf of my father in-law. He is the owner of a 1988 Testaross. He is very handy with working on cars (and his Testarossa) but not so much with the internet.
    After doing a couple of oil changes he has discovered that the internal parts of the filter have collapsed. He says he would notice a spike in oil pressure, hear a pop sound, and then things would seem to be fine. That is when he investigated and discovered the collapsed filter.
    He only used Mobile 1 oil (10w 40 I believe) and a UFI filter from the local Ferrari dealer. The dealer said they have not hear of this problem and their only solution was to sell him another filter (at $75 a pop).
    Any information regarding this would be greatly appreciated.
  2. Steve Magnusson
    26,507
    AFAIK, internal collapse of the TR UFI oil filter hasn't been reported here before. We've had a couple of prior reports of the old, soft, D-ring seal blowing out, but the seal on the latest TR UFI filter has been redesigned to match "normal" large oil filters. Any chance that you can post pictures of the failed internal bits?
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Fram is known to fail, UFI and Baldwin have been good.
  4. boatr2001
    boatr2001 Karting
    Oct 3, 2006
    88
    Rockford,IL
    I run M1 15w-50 in my Euro 308QV, and was thinking about the bypass valve in the Baldwin 253 (that I use). I was curious about a cold oil start/high rpm warm oil operation, if the filter's bypass valve would open allowing un-filtered oil into the galleries.
    I've looked at factory flow rate data, but I don't have the technical background to convert the data to real world use. Is filter bypassing something we are experiencing MANY times during the course of normal operation? I know the Baldwin bypasses at 20psi, but any idea what the normal pressure differential would be?
    I was also thinking a collapsed filter may be a result of a bypass valve that DID'NT open?
    Thoughts?
  5. TonyHill
    TonyHill Rookie
    Feb 1, 2012
    4
    Michigan
    I don't have any pictures of the UFI collapsed filter, but it looked much like the collapsed Fram filter images I have seen online.
    Pardon my ignorance, but is the bypass valve actually inside the UFI oil filter, or is there a bypass valve that is part of the car?
    Thank again for the feedback.
  6. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    Yes, this in normal with cold oil. The oil temperature that the oil no longer bypasses is a function of the oil temperature, oil flow rate, filter design, and dirt in the filter. Note not all the oil bypasses the filter, some still flows through the filter even when the bypass is open. The oil filtration on the older Ferrari's is quite crude i.e. 212 timeframe, that even with bypassing the oil, it is far cleaner in the newer cars.
    Cheers Jim
  7. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,885
    Several years ago (10-ish, maybe), we had a factory authorized dealer do a service on our 348SS. The car was returned to us on a flatbed, and the first time it was driven the oil filter "collapsed" in on itself and starved the motor of oil. The motor was lunched.
    Upon tear-down, it was determined that the oil filter had failed, internally, and Ferrari ate the cost of a replacement 348 motor. There were a number of other oil filter failures around that time.
    Perhaps, the supplier is having the same problem? I'd take it back to the dealer, tell them their oil filter is defective, demand a refund or a replacement and tell them that FNA just dodged a bullet. FNA needs to know about this and ought to remember the previous failures.
    CW
  8. Steve Magnusson
    26,507
    There's no bypass valve/pathway build into the TR engine oil lubrication system. No one has posted internal details of the TR UFI oil filter so don't know if it has a bypass valve or not (nor, if it does, whether it is a spring-loaded, resettable design like the Baldwin B253 or a one-time-blows-open-and-stays-open type). I've got an old, used TR UFI filter that I've saved, but haven't yet gotten around to doing an autopsy -- maybe I'll try to move that up my to-do list...
  9. MiuraP400
    Feb 3, 2008
    949
    Arizona
    Jim
    If there is no bypass in the engine there has to be one in the oil filter. Basic lubrication design would require it to be there and for it to be the spring loaded type. I would recommend double checking the oil filter part number. If someone accidently gave the OP a filter without a bypass in it, it would easily explain the issue.
    Cheers Jim
  10. Cribbj
    Cribbj Formula 3
    #10 Cribbj, Feb 3, 2012
    Disturbing to hear about the UFI filter collapsing. After all, isn't this one of the main reasons we pay $40-$70 for these filters instead of cheaper alternatives. That and to be sure that if we lunch an engine due to the fault of a Ferrari oil filter, we have a better leg to stand on than if it was a WalMart filter?
    I've been going through some related searching for UFI's specs on the 550's oil filters, which I easily found on the UFI site, along with full technical details, so I saw this thread and decided to have a look, since I already had the UFI catalog open.
    The TR filter, (UFI P/N 23.192.02) doesn't appear in UFI's web catalog listing, which skips from a 23.191 filter to 23.194. (See first two pics below which are for the TR filter) Probably to keep people from doing what we're doing, and to protect their supply channel.
    The TR and 550 filters are very different physically and probably internally, but just as a point of reference, UFI do state in their web catalog that the 550 filter (their P/N 23.284.00) has an internal bypass set at 1.6 bar (see last pic below)
  11. ago car nut
    ago car nut F1 Veteran
    5,462
    Madison Ohio
    David A.
    That is why we pay $40 -$70 for UFI filters instead of Wal- Mart.
    The only filter I ever found available for my TR was an UFI.
    Ago
  12. Steve Magnusson
    26,507
    #12 Steve Magnusson, Feb 4, 2012
    Here are some photos of the UFI 2319202 oil filter internals. As far as I can tell, it has no bypass valve (nor ADV). I've been trying to convince myself that if the inlet pressure was huge and the outlet pressure was zero (i.e., a blocked filter element), the whole filter element would move away from the front plate (i.e., compress the sping at the back) and allow oil to bypass the filter element, but I keep coming to the conclusion that when the inlet pressure is higher than the outlet pressure, the filter element is pressed onto the front plate.
  13. Cribbj
    Cribbj Formula 3
    Steve, I think your first conclusion is spot on; what makes you think differently?
    And if you could measure the spring constant of that spring, then the bypass valve setting could be calculated.
  14. Steve Magnusson
    26,507
    #14 Steve Magnusson, Feb 5, 2012
    Because the inlet pressure (which comes in the eight outer holes) acts over the full area of the metal sheet at the back end of the filter assembly (which pushes the filter assembly onto the front plate) -- call this F1; whereas, at the front metal sheet of the filter assembly, the area over which the inlet pressure is acting (to push the filter assembly away from the front plate) is reduced by the center hole area -- call this F2. For all inlet-outlet pressures, F1 is always greater than F2 (and the greater the inlet-outlet pressure, the greater F1 is compared to F2)...
    I've sent an email to Baldwin to request some more information about thier BT355 filter (they've got a much better search function on their website now). It's about 3/8" longer than the UFI (and we've only got ~1/2" of extra clearance available), but it has an internal 20 psi bypass valve (and great price ;)). It seems to be used on the same Ford/New Holland Tractor 400CID diesel engine that the previously-investigated NAPA filter is used on, but, unlike the NAPA filter, the BT355 has 8 (not 6) inlet holes, and (based on the pressure specs of the B253), I'm hoping that it has higher operating and burst pressure specs than the NAPA (which were/are sort of marginal for use on a TR). I'll give a shout if they respond (but I'm guessing that this will rely on the email receiver forwarding my request to the right technical person).
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Looks to me like the TR has a typical pressure-relief valve on the oil pump. It doesn't appear to bypass a plugged filter but I can't remember seeing an engine that does. It's job is to protect the pump and hopefully prevent the filter from bursting.
    The filter looks like it might function as a bypass but it's not apparent what pressure would be required for it to occur.
  16. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Is the BT355 the same thread and o-ring size? If it's a good fit I doubt the length is a problem. Looks like a good alternative to the UFI.
    Now if there was one to match the Purflux 197654 used on 348/355/360. :rolleyes:
  17. Steve Magnusson
    26,507
    Yes, the thread is the same 1-12 size, and the OD is the same 4.25". From the picture the gasket size looks OK, but that's part of the questions that I've asked (ID and OD of their G401 gasket -- although the flat flange on the TR engine is fairly broad so this doesn't have to be super-exact). The pictures also allowed me to eliminate some possibilties because the gasket was/is out at the OD.
    If you've got the thread size, ID, and OD, you can do a search on the www.baldwinfilters.com website -- of course, the thread size has to be the same, but it allows you to set limits on how close the OD and length have to be (+/- 1/4", +/- 1/2"). It then pulls up all possiblities with photos and listings of features on each such as ADV, BP, HBP, standpipe, etc.. You also have to know if the filter you want to replace is full-flow or dual-pass, but if you've got an old one to dissect that should be no problem to determine. They've also got really good video tech tutorials explaining bypass (circa 1950), full-flow + bypass (circa 1960), and full-flow (circa 1970), and dual-pass (circa 1990) systems -- I now finally understand the full-flow + bypass set-up used on some of the vintage V-12 F ;)
  18. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    What type of filter is the UFI 191993??
  19. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I'll get the particulars next time I have one to cut open. The tricky part about the 348 & 355 is that the filter is fitted into a recess so the OD of the canister has to be a certain size.
  20. Steve Magnusson
    26,507
    You are mixing thing together here a little bit:
    Ferrari PN 191993 = UFI 2316202 = Baldwin B253
    and all are full-flow designs -- but the Baldwin B253 is already a well-established alternative so no extra homework necessary ;)
    I'm still waiting to hear back (a second time) from Baldwin about the BT355. I received most of the requested dimensional information (which all seems OK) and an initial fuzzy "specification" sheet so had some more technical follow-up questions that the first responder may need help with from their engineering dept. (so I'm not yet disappointed about the delay).
  21. BigTex
    79,321
    Houston, Texas
    Bubba
    Robert Garven has the inside line there at Baldwin from making the retro T shirts, see who his contacts are?
    B253 or go home, in my garage....LOL!
    If the shops put a UFI in there I am okay with that too.......
  22. TonyHill
    TonyHill Rookie
    Feb 1, 2012
    4
    Michigan
    I got more info from my father in-law about the collapsed filters in his Testarossa. Apparently shortly after he acquired the car he sent it out to have some work done regarding an electrical issue. While it was being worked on they did an oil change and discovered the collapsed filter. A few months later he did his oil change and discovered that this filter had collapsed too. He replaced this filter and some time later he noticed a spike in oil pressure, actually heard a pop sound, and upon inspection discover another collapsed filter.
    I am not sure where he obtained these past filters (all UFI), but the one he has on the car now came from the local Ferrari dealer and he did notice that this one had a slightly different part number on it. He has not removed the current filter yet. We are in Michigan and he has it put up for the winter.
    He will be visiting this weekend and is bringing the collapsed filters that he cut open so I will post photos, and also will be able to see what part number he has been given.
    I appreciate all of the posts.
  23. TonyHill
    TonyHill Rookie
    Feb 1, 2012
    4
    Michigan
    #23 TonyHill, Feb 11, 2012
    Here are the photos of the collapsed UFI filter. Please notice that the part number 23192-00. Is there a difference between the 00, 01, and the 02.
    You can see in the photos that the internal metal tube even collapsed. This happened immediately after an oil change with new oil and filter with the filter filled before installation with M1 15-50.
    If anyone has any information as to why this might have happened, and what should be done to correct it would be greatly appreciated.
  24. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Daymn.....with 10 years of ownership and oil changes at 3000 miles or 6 months, I've never seen this....wow....
    Shamile
    Freeze....Miami Vice !
  25. Cribbj
    Cribbj Formula 3
    I'd try contacting UFI themselves and see what they have to say. Their US headquarters are in Duluth GA:
    Ufi Filters USA Inc
    110 Firestone Pt
    Duluth, GA 30097-2077
    770-813-0452
    And their UK office:
    UFI FILTERS spa
    2 Temple Street
    Keynsham
    Bristol BS31 1EG
    +44 7712 254 152
    e-mail: [email protected]
    If it were me, I'd probably start with the UK office - you're less likely to get voicemail or be ignored.
