Testarossa fuel injection rebuild | FerrariChat
Discussion in 'Boxers/TR/M' started by Philwozza, Dec 24, 2009.
  1. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    #1 Philwozza, Dec 24, 2009
    I took the chance to rebuild and detail the fuel injection system while the engine is out for new cam belts. Glad I did, there was so much gunge in places that had not see the light of day. It has taken me all day to strip, rebuild and reset things. After Christmas I am going to re-plate the fuel lines as they are past their best and replacement them is big $$$$$$.
    There are a couple of shots taken before the clean up and the last two show the job done except for refitting the fuel lines.
    Does anyone know if the fuel line copper washers, needs replacing, or can I just re-use them??
    P
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,419
    Alabama (was Mich.)
    Jeff
    You should replace the copper washers with new ones. Once they are tightened down (crushed) they should not be re-used.
  3. Steve Magnusson
    26,509
    #3 Steve Magnusson, Dec 24, 2009
    The copper washers should be replaced (or reannealed and cleaned, but this is way more hassle/cost than just buying new ones). When new, they are fully annealed = very soft. When they are crushed, they strain harden = not soft -- so they can't conform to the mating surfaces as well if reused, and might leak.
    They are know as DIN 7603A or W60 washers if you want to find a local (more reasonably priced) non-F supplier.
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Thanks guys, I have lots of copper washers to deal with so I will probably go the annealing route in my workshop.
    Steve you are a mine of useful Ferrari information, would you like to live in my garage? :)
    I will keep your washer details on my records now that I have found a supplier here in the UK.
    Merry Christmas
    P
  5. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,429
    wisconsin/chicago
    bo
    Steve, where specifically did you order these? I had a hell of a time getting these, and ended up reannealing them. Its only about 2 minutes with a propane torch :), get 'em red hot, douse with cold water...
  6. bpu699
    Dec 9, 2003
    17,429
    wisconsin/chicago
    bo
    Lots of folks on here have "beautified" the fuel supply system. Carreaper wire wheeled it, and used eastwood cad paint. I beadblasted, and used 2 part BMW gold paint... looks much better either way...
    If I had to do it over, I would probably just use a scotchbright pad and some brake cleaner, then some 2 part paint. Both bead blasting and wire brushing remove the CAD plating. But it sure looks nice :).
    Some on here had the lines replated. Great, if its a local option for you. I was way to worried about sending irreplaceable lines ($$$$) cross country to get plated...
  7. Steve Magnusson
    26,509
    #7 Steve Magnusson, Dec 24, 2009
    Yes, definitely not a hardware store item IME also. Being in the US (unlike Phil), I order both my W60 (Copper) and W63 (Aluminum) sealing washers from Global Metrics in Belmont, CA -- 650-592-2722 (a recommendation that Tony Palladino kindly passed on to me back when he had his own F shop in Redwood City):
    http://www.yelp.com/biz/global-metrics-belmont
    Doesn't make sense to order only onesies~twosies (because of the shipping costs), but anyone doing their own oil changes on a 3X8/TR can go thru 50~100 of the W60 22x27x1.5 in fairly short order -- so a wad of those + any few others needed is a good overall value IMO. And, as you know, the K/KE-Jet systems have a couple of candidate W60 sizes for a "bulk" order.
    Did you try searching armed with the DIN 7603A spec, and still couldn't find an industrial source, or was your prior searching done without that identifying spec?
  8. Steve Magnusson
    26,509
    Thanks for the kind words Phil, but, no thanks, I've got my own F problems to deal with ;) -- I just don't describe them here in gory detail like Shamile, but we all deal with the same sort of grief.
  9. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Steve, there is NEVER a Ferrari problem!
    Just an adventure that needs a solution :)
    Okay, an expensive adventure :(
    P
  10. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    I cant find the torque settings for replacing the fuel line banjo bolts to the distributors.
    Can anyone help?
  11. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,419
    Alabama (was Mich.)
    Jeff
    I do not think there has ever been a torque specified anywhere for those banjo bolts. You have to torque them carefully....you will sort of "feel" when you have them torqued enough when the copper washer "crushes". You will probably have to hold the fuel lines in their proper position when tightening the bolts, as the lines will want to rotate with the bolt a little bit. In the past, I have torqued the bolts to what I felt was adequate, then powered up the fuel pumps (do not start the car) and look for leaks, if you see a leak tighten till it stops leaking. It takes considerable force to get things tightened down, and I was nervous the whole time...but in the end everything worked out okay. Hopefully an experienced fchatter will post a better method than I have described here.
  12. Steve Magnusson
    26,509
    #12 Steve Magnusson, Dec 25, 2009
    It's given on page M5 of the TR WSM (I think) = "Union for securing injector fuel hosing assembly to fuel distributor" = 1,5 daN-m = 11 ft-lb, but I use 13 ft-lb (based on the "feel" as per Jeff's post, and my particular torque wrench ;)) -- and this is one of the very few places where you can actually use a torque wrench. They give a bunch of "Injection System" torque specs on pages M4 thru M6, but:
    1. The descriptions are very unclear IMO (and are for a K-Jet TR), so, even though they give the thread sizes to help identify things, it's hard to sure what's what (and they don't exactly correspond 1-to-1 to a KE-Jet TR), and
    2. most connections can only be accessed with an open/box end wrench so Jeff's point about "feel" is a must (unless you have a set of open/box end torque wrenches).
  13. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    you can buy
    1 open crowsfoot wrenches
    2 flarenut crowsfoot wrenches
  14. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Phil i got my copper washers from Maranellos and they were surprisingly cheap :D
  15. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    .....just because I like to kiss and tell ! :D
    Shamile
    Freeze....Miami Vice !
  16. carcollector
    carcollector Karting
    Apr 23, 2006
    143
    palo alto
    Chris M.
    [QUOTE=(a recommendation that Tony Palladino kindly passed on to me back when he had his own F shop in Redwood City)
    He still has a shop in Redwood City.
  17. Steve Magnusson
    26,509
    Glad to hear that (I meant his old shop on El Camino).
  18. portogts
    portogts Formula 3
    Owner Project Master
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    Hi Phill ,
    I got my copper washers , bolts and clamps from "Wurth". Very good quality.
    I assume you also have that company in the UK
    All the best
    Vitor
