Testarossa engine weight? | FerrariChat
Discussion in 'Boxers/TR/M' started by yelcab, Mar 9, 2022.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Assuming the heads come off without too much of a fight, would you do a valve job on an engine stand instead of on the platform where the engine comes off the car? What is the weight of that engine without the gearbox?
    I have an engine stand on which I mounted a fully laden 1960 Cadillac 390 engine. That sucker was pretty heavy. Would that be good enough for the Testa engine?
  2. Rifledriver
    36,747
    A good quality standard engine stand hold it up easily enough but it takes considerable work to make a good adapter.
    You are not going to just bolt it to the studs in the back. It needs a structure to reach out to nearly the front to support it.
    Id just leave it on the gearbox. The only time I put one on the stand is if I need to pull rods or the crank.
    Needs a valve job? How many miles? I have never seen one that needed a valve job unless it broke a belt and I have seen a few with a lot of miles.
    peteficarra and turbo-joe like this.
  3. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    I'm very interested in the engine weight, I'll need to transport my engine once it's removed for it's belt service.
    Sent from my GM1917 using Tapatalk
  4. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    I'm not convinced that it needs a valve job either. It does need an engine out for timing belt service. Compression test shows one bank is uniformly lower than the other. The engine is out and I will do a leak down test to see what that is like. It might just need valve stem seals.
  5. Rifledriver
    36,747
    Again, seen quite a few with over 100,000 miles and never found one I felt needed stem seals.
    One bank uniformly different is not usually a sign of wear. Of anything.
  6. Steve Magnusson
    26,506
    +1 -- a whole bank being uniformly different from the other bank in compression almost certainly has to be a cam timing issue (e.g., just never set right the last time it was messed with, a skipped tooth, etc.).
    Agree that the next logical step is a Leakdown Test, but, even before that, they did put externally-viewable, coarse cam timing reference marks on the backside of the TR cam belt timing covers and cams to detect if really bad things have happened. Are those obviously wacky or sort of still OK for alignment? How different are the compression test results for the two banks?
  7. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Yes, I get that one bank is off cam vs the other. I am going to do leak down test next to have more data.
    Compression: 1 to 12: 149, 139, 149, 148, 143, 146, 154, 163, 160, 159, 167, 152 psi
    Outliers are C2 and C11
  8. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    So no one knows the weight of the engine and transmission combo?
  9. Rifledriver
    36,747
    Not sure why I'd care.
  10. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Because that's what the original post was about, not valves. I'm having to move my engine from a shop to my house. I need to know how much it weighs so I can figure out how to move it.
  11. Rifledriver
    36,747
    And I answered that question because it really was not the information he needed.
    As far as moving it is concerned anything big enough to hold it is more than capable of carrying it. Sorry but I know of no one who has ever weighed one.
  12. INRange
    INRange F1 World Champ
    12,071
    Virginia/Florida/Caymans
    JD
    For what it is worth this is the engine data. Double it for the transaxle and you will be close. I believe your bigger challenge is getting it off the truck and onto the ground. I doubt you have a railing system at your house which means a conventional hydraulic lift hoist. A 1,500 pound lift hoist will pick it up but you will need to make something for it rest onto since the engine/transmission combination may be too wide for the legs of the hoist.
    I presume they are loading it with a forklift on a pallet. That definitely will not fit between the legs of most hydraulic hoists. Any chance you can have them bring the forklift along to get it off the truck?
    Weight
    Ferrari 312T 397 (2) (V12 3.0L racing engine)
    Ferrari "250" V12 382 (2)
    Ferrari V12 ~300 (23) 65 degree bank angle, 1992 F1
    Ferrari 456 V12 517 (32,65) 65 degree, 5.5L, 1992
    Ferrari "036_ F1 V12 310 (66) 65 deg, 3.5L
    Ferrari "291" F1 V12 275 (66) also E1A-92, 65 deg
    Ferrari E1A/92 F1 V12 308 (70) 65 deg
    Ferrari F50 4.7L V12 432 (90) iron block, titanium rods
  13. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Thank you for some helpful information. The engine will still be in it's cradle with the suspension attached. I was thinking of putting the wheels back on and trying to wheel the whole thing onto a trailer.
    I currently do not have a hoist for it, though I was looking at a mobile gantry crane. I'll definitely post pictures of how I find a way to move the damn thing.
    INRange likes this.
  14. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #14 vincenzo, Mar 10, 2022
    Rent an engine hoist
    not expensive to buy
    build a cradle on casters
    kartboy1234 and turbo-joe like this.
  15. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Yea I'll see if I can get a hoist. That cradle looks good, I'll measure the car and see if I can build one to hold the engine.
  16. raysur
    raysur Formula Junior
    604
    So. Cal.
    Jeff
    Out if its subframe with no muffler, the engine and transmission weigh 930lbs.
    Veedub00, V4NG0 and kartboy1234 like this.
  17. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,054
    Troy, Michigan
    James
    422 kg according to this video.
    Elberoth likes this.
  18. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Awesome
  19. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    AKA; 928LBS….
