Testarossa Engine Lid Foam | FerrariChat
Discussion in 'Boxers/TR/M' started by sweetspotav, Oct 19, 2015.
  1. sweetspotav
    sweetspotav Karting
    Nov 21, 2004
    122
    Florida
    John Cawley
    Does anyone know where to get a replacement for the foam that is on the underside of the engine deck lid?
  2. Rifledriver
    37,363
    Just so you know it is not required and was only intended to be used on US cars as noise insulation to comply with our sound level limits. Not all US cars even had it.
    There are many foams available that will work but despite looking long and hard I never found a source besides the very expensive OE foam that looked correct.
  3. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Another thing to consider, even if you find a factory foam pad, how old is it? When was it made? You might be buying a spendy piece of brittle dust in a bag.
  4. sherrillt
    sherrillt Formula 3
    1,126
    Northern Virginia
    I think Mel made his own that looked perfect. There was thread about a year or two ago about it - did a quick look, but couldn't find it.
  5. dgt
    dgt Formula 3
    Jan 14, 2011
    1,293
    Northeast, USA & Oz
    Andrew
    I cut it to size from this which worked nicely...
    McMaster-Carr
  6. Rifledriver
    37,363
    That foam is 24x24.
    The TR hood pad is 32x31.
    And for $160 I'd strip the foam and glue and paint the fiberglass satin black the way the factory did instead.
  7. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    My '85 doesn't have the foam. But I've stripped the glue off another cover and that glue is a royal PITA to remove completely. Stuff is tenacious.
  8. dgt
    dgt Formula 3
    Jan 14, 2011
    1,293
    Northeast, USA & Oz
    Andrew
    #8 dgt, Oct 20, 2015
    whoops... that was on a 512TR.
    edit...
    They have this in 36x36" without the adhesive.
    http://www.mcmaster.com/#85925k346/=zgadgx
    .. but it's more than double the price for the larger size.
    The stuff from Ferrari for the 512TR was poorer quality and much more expensive IIRC, this has about the right color in a hi temp silicone foam which should last.
  9. Rifledriver
    37,363
    You're right. The TR512 piece is half the size for twice the money.
  10. Rifledriver
    37,363
    It takes a little time but I have done enough of them it is a little easier.
    Some really want the foam but I usually advise to just paint it. Either way is correct.
  11. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    looks just like the honeycomb foam that is the OEM hood pad on my '88 W126 Benz. Might be able to buy a hood pad from this model car and cut it to size for far less then the factory foam.
  12. Rifledriver
    37,363
    That foam looks quite a bit different. If an OE look is desired that won't do it. If an OE look is not important just leave if off and get the best of both worlds.
  13. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Just don't bother!!!
    Phil
  14. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    My foam finally started falling apart. I just stripped the remnants and painted it.
  15. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,296
    Mel
    #15 Melvok, Oct 22, 2015
    Correct, it was about the 512TR .... oem part $ 600 or so :(
    Went to an airco maintenance shop and got a piece of one square meter (left-over part) for $ 20 or so
    There are 2 version, just rubber of with sticky back
    Get the rubber material that has the glue already on it, strip off the plastic and stick it on its place
    Use an electric knive and do the job (made one more for Edvar's 512TR)
    Can be done to any car :D
  16. N17RO
    N17RO Formula Junior
    Apr 9, 2013
    263
    UAE
    Craig
    Wow Mel that carving knife must be as old as the car. Ive nit seen one of them for years lol
    Guess it does the job really well.
  17. Melvok
    Jul 25, 2008
    14,296
    Mel
    That's all it needs ... and with scissors it will not work that neat ! :)
    GOOD LUCK and tell us how you succeeded ! :D
  18. CornellCars
    CornellCars Formula 3
    Mar 24, 2005
    1,102
    South Florida
    Jason
    Something to consider, should you ever ponder showing or having the car judged, or putting it in for Classiche...if you have the incorrect foam, you may very well be docked points, but if you have no foam, you will almost certainly not be docked points, as judges can't ascertain whether foam was original to your car or not.
  19. N17RO
    Apr 9, 2013
    263
    UAE
    Craig
    Thankfully no need mine has no foam. :)
  20. sweetspotav
    sweetspotav Karting
    Nov 21, 2004
    122
    Florida
    John Cawley
    I'm planning on having the car judged. It has the original foam on it and it is starting to deteriorate. I don't want to be docked points for it. If the foam is removed, points would be deducted as well since any judge would know these cars had foam installed.
  21. CornellCars
    Mar 24, 2005
    1,102
    South Florida
    Jason
    Incorrect, some trs were delivered with foam some without, there is no record that i'm aware of for whether a car was built with foam or not, and certainly none available to judges at an event. As such, per judges i have asked, better to not have any foam than to have the wrong foam or heavily deteriorated foam.
  22. SEAN@TEAM AI
    SEAN@TEAM AI Karting
    Sponsor
    Sep 22, 2006
    201
    Charlotte, NC
    Sean Smith
    If I read Brian's words correctly. You will not lose points. Brian is a judge at top events.
  23. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Thats just how mine is Brian. I have never understood the function of the foam and it has never been picked up at Concourse events.
    P
  24. Steve Magnusson
    27,016
    #24 Steve Magnusson, Oct 25, 2015
    Does anyone with a standard (euro) version TR (that has never been imported the US) have the foam? Or, if you have such a euro TR without the foam, please indicate that too. Would love to see such a poll for all TR version/situation/year to get a snapshot of the population (although, maybe, many have been molested/changed/removed by now) -- they went to such crazy lengths in other areas to try to keep the weight down, they must have had some reason to add...
  25. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Phil Worrall - Euro 1987 - NO Foam
