Testarossa Cross Reference Thread | Page 9 | FerrariChat
Discussion in 'Boxers/TR/M' started by JAYF, Oct 14, 2006.
  1. EZORED
    EZORED Formula 3
    1,032
    Scottsdale, AZ
    Dennis
    Replaced my cat with test pipes. Got them off ebay Brand New T-304 Stainless Steel 3"O.D. / 2.75" I.D. Straight Cats With TIG Welding + Cast Iron Flange
    http://www.stores.ebay.com/delubozparts
    I got new large exhaust donuts from GT Car parts in Phoenix.623-7802200 $15 each
    I messed up one o2 sensor in the change out and had to replace it also. Gt Car parts again.
    NTK 25034 $110 The harness was a direct replacement no problem.
  2. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Mouser 57,
    Your list is great!!!
    thanks
    Ago
  3. shaikhzeep_212
    shaikhzeep_212 Karting
    Apr 13, 2006
    85
    Saudi arabia
    HAM
    Hi,Anyone knows where to find cheap windows control switches ? or similar replacement?
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    shaikhzeep_212, this is not the appropriate place to post your question so it may not get answered. This section is for providing other users with a cross reference of parts.
    P
  5. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
  6. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Courtesy of Hawaii....
    Found it:
    Digi-key Corporation
    701 Brooks Ave South
    Thief River Falls, MN 56701-0677
    1800-344-4539
    www.digikey.com
    1ea 9 pos connector plug #A99536-ND $13.95
    1ea 24 pos connector plug (Your pic shown) #206837-1 $4.18 (don't know why it's cheaper)
    1ea Wire extraction tool #A1329-ND $13.72
    You may not need the small connector plug, but while you're in there you might as well change that one too. It's cheap enough. Hope that helps.
    Emery
    Shamile
    Freeze....Miami Vice !
    kartboy1234 likes this.
  7. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    For the 1992-1994 512TR, throttle position switch is either Bosch or Beck Arnley for a 94-97 Volvo 850. Cost differential about the same, from $208 Ferrari ville to $59 for the Volvo. Walked into my Advance Auto and they had it.
  8. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    512 TR Secondary Air Valve ( #18 on diagram)
    Delco 219-419, 20.00 usd
  9. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    Spasso, have you verified that this particular part is indeed a suitable subsitute for the original Ferrari-supplied part? If you search for Delco 219-419, it shows an "air injection pipe", not air check valve...
  10. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #210 Juri, Mar 10, 2011
    Here are the correct part numbers for the air check valve substitute:
    ACDelco# 214-419
    GM# 22040805
    Standard# AV7 or AV45
    All these parts are less than $25/each.
  11. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #211 Spasso, Mar 10, 2011
    Just going by post #6 of http://www.ferrarichat.com/forum/forumdisplay.php?f=90
    Looks like a typo.
    The important part is, no need to pay a "MILLION" dollars for a 20.00 part
    God forbid it doesn't come in a yellow box.
    Delco 214-419
    Thanks for the heads up.
  12. 90TR
    90TR Formula Junior
    Nov 23, 2005
    274
    Celebration, FL
    Bill
    I am still struggling with the shift linkage; but thought I would pass along some information on the more unusual or difficult items I had to research. I will also add this information to the Cross Reference Thread.
    Alternator- I was going to have my alternator rebuilt as I typically got the warning light on the dash when I first started the car. When I removed it, I noticed that it was stamped Delco-Remy on the back. After a few hours on the phone with the folks at Delco-Remy they were able to convert the number on the unit to other, more common fitments. In this case the alternator was used more commonly on Taxi Cabs and specifically on 1989 GMC P3500 Vans with the 6.2L engine and the 120Amp Alternator. I found this at Advance AutoParts for $74.99 (Part # P728712) with a lifetime guarantee. The only real difference was in the adjuster mount. The GMC version was threaded; so I had to drill out the threads to accept the Ferrari adjuster. I noticed the original had also been drilled out.
    Braided Hose- I was able to source nearly all the braided hose (except the larger 20/22mm sizes) via VW suppliers for a fraction of the price. Most I was able to get online through a company called CB Performance...The 20mm hose I got from Italian Car Parts and was very pricy. All was sold by the foot. You can also get the braided hose via WURTH; but it comes in pkgs.
    AC Compr- My original unit is a SANDEN SD-508; 9265. My unit seems OK, but thought I would try to replace it since I had such good luck with the alternator. After many, many calls I eventually got to speak with someone at Sanden who took this on and researched the fitment. Our alternators were specially ordered by Ferrari and were not used on any other vehicles. I was told the main case was common, but that the back plate was entirely custom (on their stock parts a Letter A-Z is stamped on the back plate for manufacture, mine had none) and although the clutch is a stock piece, it was not used commonly with that main case.
    Larger exhaust gaskets- I got these via TRutlands via Part#154985. I mention this because I attempted to source locally and was able too, but the fitment was not correct.
    3 wire plastic clips for the Ignition Wires, I also sourced at TRutlands Part#121789. As I did with the Spark Plug extensions- Part#124792.
    The local parts guys did not stock the Gear Oil, Redline 75W90NS; but I was able to source it via Summit.
  13. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    #213 kerrywittig, Jun 10, 2011
    Need a clutch disc or two relined..........
    Got a pair for my 1987 TR done for under $200 with a 5 day turn around.....my door to theirs and back to me!!!
    The name of the company is All Frictions Co. LLC. The tel # is 860-342-2001….ask for Tim, and mention my name Kerry Wittig, the Ferrari guy!
    Their website is www.allfrictions.com
    By the way, this is the company that does all the clutch and brake relining work for Wayne Carini, he's a Ferrari expert, owns F40 Motorsports, Portland, CT and hosts a TV show on HDnet called “Chasing Classic Cars”. I figure if Carini trusts his workmanship……….so can I!!
    Sharing Me
  14. NZ Ferrari
    NZ Ferrari Rookie
    Jan 5, 2011
    39
    Auckland New Zealand
    David
    #214 NZ Ferrari, Jun 12, 2011
    Its great to see so many testarossa owners have realized by now that ferrari only built the engine for the car, the body was built by pininfarina, gear box by colotti, diff by ZF, fuel system by bosch, electrics by bosch and marelli and with other parts raided from alfa lancia fiat, most of the generic looking parts on the car will have a number on them so you can google and you will see a x reference and other model cars that used that part, there are other ebay sites like ebay uk that from time to time have new and used ferrari parts for sale with a x reference on the part you are after last time i looked there was a new testarossa body and 2 used testarossa engines for sale
    Johnny Boys likes this.
  15. blackdr
    blackdr Karting
    May 20, 2008
    92
    Wow theres something you dont see everyday.
  16. jrbaldwin
    jrbaldwin Karting
    144
    Pacific North West
    James Baldwin
    All part numbers are Super Bright LEDS Part Numbers (http://www.superbrightleds.com)
    Wire Diagram # - Light (Color) - Part # [Number of Lights] - Cost per Light
    INTERIOR LIGHTS
    Feston Bulbs
    15 - Front Bonnet Light (White) - 3710-CWHP3 [1] - $ 7.95
    73 - Glove box (White) - 3710-CWHP3 [2] - $ 7.95
    87 - Interior Lights (White) - 4210-CWHP3 [7] - $ 7.95
    102 - Light for Center Consul Glove Box (White) - 3710-CWHP3 [1] - $ 7.95
    122 - Engine Compartment Light (White) - 3710-CWHP3 [2] - $ 7.95
    Note: 87 Interior lights & 73 Glove box lights - For 100% additional light can install 4210-CWHP6 - $ 14.95 which have 6 high powered LED lights per bulb.
    BA9 Bulbs
    Dash
    37 - Parking Brake Warning 2W (Red) - BA9SF-R-12V [1] - $ 0.98
    38 - Rear Window Heater Warning 2W (Amver) - BA9SF-A-12V [1] - $ 0.98
    39 - Parking Light Warning 2W (Green) - BA9SF-G-12V [1] - $ 1.98
    40 - L.H. Direction indicating 2W (Green Small Round) - BA9S-G-120-12V [1] - $ 1.98
    41 - Electronic Speedometer Gauge 2W (White) - BA9SF-W-12V [2] - $ 1.98
    42 - Headlamp Main Beam Warning 2W (Blue Small Round) - BA9S-B-120-12V [1] - $ 1.98
    43 - R.H. Direction indicating 2W (Green Small Round) - BA9S-G-120-12V [1] - $ 1.98
    44 - Oil Pressure Gauge 2W (White) - BA9SF-W-12V [1] - $ 1.98
    44 - Oil Pressure Low Pressure Warning (red Small Round) BA9S-R-120-12V [1] - $ 0.98
    45 - Brake System Failure Warning 2W (red) - BA9SF-R-12V [1] - $ 0.98
    46 - Water Temperature Gauge 2W (White) - BA9SF-W-12V [1] - $ 1.98
    47 - Fuel Reserve Warning 2W (Amver Small Round ) BA9S-A-120-12V [1] - $ 0.98
    48 - Parking Light Indicator 2W (Green Small Round) - BA9S-G-120-12V [1] - $ 1.98
    49 - Electronic Engine Speed Indicator Gauge (White) - BA9SF-W-12V [2] - $ 1.98
    50 - Alternator Warning 2W (Red) (red Small Round) - BA9S-R-120-12V [1] - $ 0.98
    51 - Front Bonnet Open Warning 2W (red) - BA9SF-R-12V [1] - $ 0.98
    52 - Engine Bonnet Open Warning 2W (red) - BA9SF-R-12V [1] - $ 0.98
    71 - High Temp Exhaust System Warning Cyl 7-12 2W (Red) - BA9SF-R-12V [1] - $ 0.98
    90 - High Temp Exhaust System Warning Cyl 1-6 2W (Red) BA9SF-R-12V [1] - $ 0.98
    76 - Low Open Door Marker (White) - BA9s-CWHP9 [2] - $ 9.95
    77 - Open Door Marker (Red) - BA9s-R4-90-12 [2] - $ 1.98
    Center Consul
    58 - Fuel Level Gauge 2W (White) - BA9SF-W-12V [1] - $ 1.98
    59 - Front Fog Lights Indicator 2W (Green) - BA9SF-G-12V [1] - $ 1.98
    61 - Engine Oil Temp Gauge (White) - BA9SF-W-12V [1] - $ 1.98
    60 - Fasten Seat Belt Warning Drivers Side (Red) - BA9SF-R-12V [1] - $ 0.98
    134 - Fasten Seat Belt Warning Passenger (Red) BA9SF-R-12V [1] - $ 0.98
    Note: Gauge lights can be red instead of white (41, 44, 46, 49, 58, 61)
    Note: For small round indicator lights (40, 42, 43, 44, 47, 48, 50) can use 90 degree lights instead of 120 degree lights
    Mini Wedge
    74 - Ash Trays (Amber) - 74-AHP3 [2] - $ 3.49
    81 - Hazard Light Switch Center Consul (Red) - 74-RHP3 [1] - $ 3.49
    83 - Parking Light Switch Center Consul (Green) - 74-GHP3 [1] - $ 3.49
    85 - Cigarette Lighter Lamp Center Consul (Amber)- 74-AHP3 [1] - $ 3.49
    96 - Push Button unit for A.C. System 1.2W Center Consul (Green) - 74-WHP3 [1] - $ 3.49
    100 - Light for Tunnel (Red) - 74-RHP3 [2] - $ 3.49
    Note: The mini wedge LED lights bulbs are Polarized - flip bulb around if it does not light when first installed.
    Note: on 74 - Door Ash Tray light - if install 74-AHP (single LED) light fuse 13 will blow due the single LED light having the wires from both legs that are bent over base and runs down other side. Must cut wire so does not run down other side. This socket has positive one side and negative the other side.
    Note: Found the LED lights to bright in Hazard Light & Parking Light Switches and Reinstalled the original lights.
    Overhead Consul
    Spot Light (White) - WLED-W4-32 [1] - $2.59 (Mini Wedge Base)
    EXTERIOR LIGHTS
    The Front LED Parking light are a little brighter than the incandescent Lights they replaced, but the turn signal lights are around 50% brighter. The Rear LED parking lights look a lot brighter and the brake lights look 100% brighter than the incandescent Lights they replaced . The backup lights look to be 150-200 % brighter and they are actually effective at lighting up the area behind the the car.
    FRONT
    Direction Indicator (Amber) - 1156-A3W [2] - $12.95
    Parking / Direction Indicator (Amber) - 1157-A3W [2] - $12.95
    Parking (Amber) - 67-W9 [2] - $6.95
    Side Markers (Amber) - WLED-AHP5 [2] - $4.95 (Mini Wedge Base)
    REAR
    Direction Indicator (Amber) - 1156-A45-T [4] - $24.95
    Parking (Red) - 1156-R45-T [2] - $24.95
    Parking / Auxiliary Brake (Red) - 1157-R45-T [2] - $24.95
    Brake (Red) - 1156-R45-T [2] - $24.95
    Reverse (White) - 1156-W45-T [2] - $24.95
    License Plate (White) - 67-W15 [2] - $6.95
    Side Markers (Red) - WLED-RHP5 [2] - $5.95 (Mini Wedge Base)
    Note: Front parking / Direction Indicators - 1156-A45-T and 1157-A45-T will not fit into the light sockets deep enough to twist lock due to rear edge of light hitting the reflector.
    Note: 1156-A3W & 1157-A3W has a 3 Watt high power LED behind integrated reflector lens emits 320 degree beam that maximizes reflective housings & eliminating hot spots.
    Note: 67-A15 & 67-W15 are a wide beam LED light with 9 LED facing out and 6 LEDs radially Mounted. This maximizes reflective housings & eliminating hot spots.
  17. Skogens Baron
    Skogens Baron Formula Junior
    Dec 22, 2006
    259
    Norway
    Daniel
    Do you have the Delco partnumber? Is it 334-2176 / 334-2178??
    Best regards
    Daniel
  18. Engineer
    Engineer Karting
    Dec 22, 2004
    57
    Advance Auto Parts, Worldwide P7288-12. Shows up as for 1984 Corvette and other Chevy types. The spec says unthreaded mounting lug, but mine came from warehouse with threads. Easy fix with drill. 120 amp. Swap the pulley. Otherwise a direct drop in. Could not find the part number on the public web site, but it is on their store computer.
  19. wmfitts
    wmfitts Rookie
    Jul 2, 2009
    16
    Pittsburgh, PA
    Bill
    Testarossa Cold Start Valve/Injector
    Ferrari Part 113979
    Bosch Part # 0280170412
    Mercedes Part # A1190700246
  20. Monza 456
    Monza 456 Karting
    Sep 15, 2005
    231
    Portland, Oregon
    Craig Nelson
    I'm looking for the belt driven air injection pump. Any leads?
  21. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    #221 Philwozza, Oct 29, 2011
    This is to within a millimetre on all dimensions to the original but is not a fuzzy finish. Apparently same as a 512TR seal :)
    Part number DX80
    COH Baines Ltd
    Unit 3 Buckingham House
    Longfield Road
    Tunbridge Wells
    Kent
    TN2 3EY
    England
    Tel - 01892 543311
    Fax - 01892 530682
  22. Testarossa Lover
    Testarossa Lover F1 Rookie
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
    Does anyone know where to find Bosch 1990 TR injectors?
  23. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    I bought some for my 1991 from Autohaus (sp?) I think they were 17.99 each
  24. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    Hello Phil; Thanks Soooooo much for your due diligence & persistance in sourching the ever elusive Testarossa door seal. I'm going to contact the dealer & order. Any idea as in "meters" how much is needed to do both doors, plus a little extra for insurance?. Also recommendations for adhesive/glue to attach.....Mark
  25. Testarossa Lover
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
    I just found this link and called them, it was 30.13 per injector and .93 for the seal.
    07-31-2009, 10:26 AM
    JAYF
    Formula 3
    Not Subscribed Join Date: May 2006
    Full Name: Jay
    Testarossa Bosch Fuel Injectors:
    http://www.autohausaz.com/search/pro...ber=0437502047
    Bosch Fuel Injectors #0437502047
    Dont forget to order the new (green) Viton seals from Bosch as well
    Bosch PN 3 430 210 606
