Testarossa Cross Reference Thread | Page 5 | FerrariChat
Discussion in 'Boxers/TR/M' started by JAYF, Oct 14, 2006.
  1. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    #101 JAYF, Apr 27, 2009
    Verell from Unobtanium Supply Co makes a really nice kit for those who are interested in replacing their fuel lines and having the fittings replated. Here is the thread on it. It mostly covers 308/mondial(that is his speciality), however he also has a kit for the TR as well:
    http://www.ferrarichat.com/forum/showthread.php?t=186689
  2. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,088
    Melbourne, Australia
    Robert Hayden
    I cant get this link to work. Can someone please check it out from the USA end?
  3. carcollector
    carcollector Karting
    Apr 23, 2006
    143
    palo alto
    Chris M.
    Paste the web address ending in ".com", then press enter. When the home page pops up, enter "xm631" in the "item search box" and press enter.
  4. uzz32soarer
    Sep 9, 2006
    3,088
    Robert Hayden
    It keeps timing out Chris and won't do the search. Maybe they have a weekend issue. I'll try again Monday.
  5. Steve Magnusson
    25,149
    That WAI link for the XM631 works for me.
  6. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    CV axle joint boots.
    Lobro ( OEM GKN Parts)
    Porsche 300527 (GKN part # )
    9283329242 (Porsche part # )
    4 required
    Shamile
    Freeze....Miami Vice !
  7. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    anyone know the ATE part NOs to rebult the front and rear brake calipers for a 87 TR?
  8. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    Rebuild kits from GiroDisc are the best pricing I believe at about $35 per caliper for my '87 TR.
    The part #'s are CRK1-037 & CRK2-037.
    Contact info is:
    GiroDisc
    1602 Carilina Street D-8
    Bellingham, WA 98229
    Tel# 949-350-6194
    Fax# 866-384-8058
    www.************
  9. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    #109 kerrywittig, May 29, 2009
    Send in your old TR parking brake shoes and get back new ones in less than a week. 2 day turn around, $15 USD per shoe, new friction material is 5/32" thick.
    Where.....
    PBS Brake & Supply Corp.
    6044 Corporate Drive
    East Syracuse, New York 13057
    Tel: 315-463-4541
    Ask for DON & mention Kerry with the Black Testarossa from Ithaca, New York sent ya!!!
  10. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    thanks for the info.
  11. uzz32soarer
    Sep 9, 2006
    3,088
    Robert Hayden
    #111 uzz32soarer, Jun 24, 2009
    I found another supplier of ignition modules for the Testarossa. A German company called HUECO appears to make a range of them.
    Manufacturer Product OEMS/Number HUECO No
    FERRARI Ignition Coil 134386 138793 '
    FERRARI Ignition Coil 115013 138732 '
    FERRARI Ignition Module 138225 138403 '
    FERRARI Ignition Module 137511 138401 '
    FERRARI Throttle position sensor 142434 138601 '
    FERRARI Throttle position sensor 158170 138601 '
    FERRARI Throttle position sensor 130974 138511 '
    FERRARI Throttle position sensor 121517 138510 '
    FERRARI Fuel Pump Relay 62370600 132040 '
    FERRARI Fuel Pump Relay 124717 132041 '
    FERRARI Glow plug Controller 311609 132050 '
    FERRARI Regulator 121840 130504 '
    http://www.hueco.com/dynasite.cfm?dssid=5301
    Here's a picture of the 138 403 model. Looks very muc like a Testarossa one, yet they list it for a 512TR 91 - 94.
    If anyone has a Ferrari part number for the 85 - 91 Testarossa ignition module, maybe you can compare with the list above.
  12. uzz32soarer
    Sep 9, 2006
    3,088
    Robert Hayden
    My 1988 Testa uses Magneti Marelli BKL 3BA
  13. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
  14. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    the ox sensors oN my 86 tr part no stamp on sensor 0 258 003 009 on both sensors same no i call BOSCH and thay call me back with the sort part no #13957 call NAPA AUTOPARTS this is a good no and from the photo looks OEM WILL PLUG IN TO THE OEM WIRE HARNESS PRICE $ 89.99
  15. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    #115 JAYF, Jul 31, 2009
  16. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
  17. uzz32soarer
    Sep 9, 2006
    3,088
    Robert Hayden
    Testarossa CV joints.
    Printed on the actual outer CV joints of my 1988.5 TR are the numbers: 7 153 15 01 87 001 LOBRO 25 88 W-GERMANY
    I sent an email to Lobro and they responded:
    "Our joint kit number 302291 could fit your application"
    go to www.gknservice.com as the actual company name is GKN Lobro.
    Pricing should be around $85 USD per CV including boot.
  18. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
  19. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    TR Clutch relining : www.clutchmasters.com
    Recommended by several people on the board-This company will reline your existing clutch with Kevlar.
  20. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    the bosch fuel filter bosch part no # 71039 from importtec $ 12.00
  21. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    Fuse box rebuilding info:
    Here is one option that has had some good success(taken from a mondial thread):
    GT Autoparts in Arizona. This is a continuation of their successful program rebuilding TR fuseboxes which have the same problems as the Mondials (go figure). The units are rebuilt with a newer technology circuit card in the original box to replace the old multilayer card; all of the original cards delaminate with time. The boxes come with used relays,
    Both of the prototypes are installed and working well in our cars without any problem - so far so good. For more info call GT directly at 623-780-2200.
  22. 91silverRedHead
    Sep 29, 2009
    21
    any one find any front rotors that will fit a 91 TR?
  23. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    #123 JAYF, Oct 20, 2009
    Another fuse box upgrade option:
    done by Dave Helms
    http://www.****************.com/
    The standard 5 circuit TR kit is currently priced @ $887.52 usd plus shipping and insurance, with the extra circuit adding an additional $45 when it is required.
  24. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
  25. Baza32-TR
    Baza32-TR Rookie
    Jun 26, 2009
    2
    Florida
    Dwight Baza
    Dwight from Palm Beach
    I drive my TR 2-3 times a week. Every once in a while after 4 -5 stops I have a delay in the ignition. I turn the key and the car will finally start after 2 mississippi.
    1. The battery I currently have in my TR has 550 cold cranking amps and
    630 cranking amps
    I would like to replace that battery with a 700 cold cranking amps and
    880 cranking amps
    1. Is this too powerful of a battery?
    2. Will it ruin my ignition? Digiplex??
    3. Will it ruin my altenator or starter?
    4. What are the correct numbers for the CCA and CA for a n 89 TR?
