Testarossa Cross Reference Thread | Page 15 | FerrariChat
Discussion in 'Boxers/TR/M' started by JAYF, Oct 14, 2006.
  1. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    How did this end up in the cross reference thread?
  2. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,640
    wisconsin/chicago
    bo
    Do you have a part number for those? Or what model they came out of?
  3. ago car nut
    5,495
    Madison Ohio
    David A.
    #353 ago car nut, Jun 25, 2020
    Rock Auto Volvo 271-664
    OEM; Includes Gasket or Seal
    MAHLE® thermostats provide world class temperature control and are trusted by OEMs & Technicians around the globe. When purchasing a MAHLE thermostat, you know you're getting quality guaranteed by MAHLE. Demand the best, demand MAHLE.
    Type Thermostat Insert
    Gasket or Seal Included Yes
    Start to Open Temperature 92 Deg. C
    Alternate/OEM Part Number(s): 271417, 271664, 2716640
    turbo-joe likes this.
  4. bpu699
    Dec 9, 2003
    17,640
    wisconsin/chicago
    bo
    Thanks!
  5. bpu699
    Dec 9, 2003
    17,640
    wisconsin/chicago
    bo
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,260
    Mel
    Found the Gripper DIFF maker in England ! https://gripperlsd.com/
    (Dino, 330 and 512 ...look all the same to me in their photos )
    Phill stopped selling them because he went to Singapore or Hong Kong.
    But Gripper is still produce this immaculate TR and 512TR diffs for very good prices (UKP 1700) and gives life-long guarantee still.
    Ask them simply for info.
    You need two Timken bearings and a shimm-kit.
  7. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,507
    romano schwabel
    thank you mel for this info
    exactly working as phills diff with the overrun side ramp.
    when back in germany hopefully the next 2 weeks I will order one
    there is no complete kit available and if so then not payable
  8. Casmith
    Casmith Rookie
    Mar 20, 2018
    3
    Craig Smith
    Half shafts / Axle Shaft (Part # 116016)
    As per previous posts by others the CV joints for the half shafts are the same as Porsche 930 CV joint with many good and cheap aftermarket CJ joints available. I also needed to replace both half shafts on my Testarossa. Rather than paying ~1,000GBP each for Ferrari half shafts I found that I could order custom half shafts with the same Porsche 930 / 28 splines that are made for high horsepower offroad racing applications (that often use this Porsche 930 spline) that are stronger and made from better alloys than the OEM part. I measured them up and had them cut to the same length using 300M alloy. The pair ended up costing $770 for the pair ($385 each compared to 1000GBP each). Cheaper 4340/chromoly ones are also available but I opted for the stronger 300M option.
    For 300M they will usually be supplied unpainted (to facilitate crack testing for racing applications) so I had to paint them. The final product seemed much better than the OEM ones they replaced. I ordered mine from Kartek.com in the US and was happy with their service. Another supplier is swayaway.com
  9. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    #359 Arvid, Jul 21, 2020
    vincenzo, tbothier and TestaDDS like this.
  10. EZORED
    EZORED Formula 3
    1,032
    Scottsdale, AZ
    Dennis
    Testarossa Sean and turbo-joe like this.
  11. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    I think these will do it... but have not seen them in person. I can verify personally that the air pump body (not nozzle) is the same.
  12. turbo-joe
    Apr 6, 2008
    9,507
    romano schwabel
    Ferrari PN: 104310 Crown gear securing screw
    ARP Part #100-9908
  13. TestaDDS
    TestaDDS Karting
    Sep 6, 2015
    87
    France
    RM
  14. Steve Magnusson
    26,725
    That's my fault. I misread the ARP PN from the pic in another thread -- should've written:
    ARP Part #203-2802
    TestaDDS and turbo-joe like this.
  15. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Hi
    I have 1991 Testarossa RHD
    Any cross-reference part for
    1) Valve guides
    2) Valve seals
    3) standard piston rings
  16. Modisp
    Modisp Rookie
    Jun 28, 2021
    3
    Peter Baschtarz
    Hello, any cross reference part for the oil preassure sender ? Superformance is out of stock . It is a M18 . Maybe something from VDO ? Thanks
  17. 4heid
    4heid Karting
    Jul 31, 2019
    87
    Maryland
    Chris
    DetroitDetomaso likes this.
  18. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    I thought I would contribute what I found if anyone is looking for fuel injectors for the Ferrari 512TR. Long time ago, I had an injector go bad and had them cleaned and bench flowed. The shop told me they were 19lb high impedance injectors. I must have lost my injectors so I had to find replacements. The Bosch orange top injectors have worked fine for over a decade. It was really close to the OEMs. I think it flowed 195cc/min and high impedance. I had them on the 512TR for over a decade and seems to work fine. The O2 sensors will trim the fuel delivery when needed. Recently I was talking to RC Injection and they told me the 19lb injector I have will be fine but they make some that are about 5-10cc closer to the OEM. I was told the stock injectors on the Ferrari 512TR are saturated (high-impedance, 16 Ohm) units that flow approximately 200 cc/min at 43.5 psi of fuel pressure. They make the SL4-0205 RC injector that will work on the 512TR. About $79 a piece new with warranty. I am going to order 12 of them just to get closer to OEM but the guy at RC said what I have (Bosch 19# orange top injector/high impedance) is probably fine.
    SL4-0205 Saturated Injector for Ferrari and Diablo.
    Flow Rate - CC's:
    205 CC's / MIN @ 43.5 PSI
    Flow Rate - LB's:
    20 LBS / HR @ 43.5 PSI
    Thought I would pass a long.
  19. DetroitDetomaso
    DetroitDetomaso Formula Junior
    Mar 6, 2006
    455
    Las Vegas
    Chris
  20. DetroitDetomaso
    Mar 6, 2006
    455
    Las Vegas
    Chris
  21. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    265
    Southern Florida
    As a replacement for the large zip ties in the 1986 TR engine bay, I came across a nearly identical zip tie generically called a double locking cable tie or a double lock zip tie. I purchased what is called a "collar double head cable tie" made in Italy by SapiSelco. The only markings on the original F tie is the trade name COLSON on the top of the lock, which this does not have. The supplier was AutomationDirect.com in Atlanta, Ga. Their part number for this cable tie is COL.3.322 shown in the pic below. EDoug
  22. tbothier
    tbothier Rookie
    Dec 3, 2021
    23
    UAE
    THIERRY
    Hi guys, do you know if there is cross reference for driver seat belt buckle?
    Am looking Euro specs, I don t know if same for US version. My Testarossa is '87.
    Thanks in advance
    ag512bbi likes this.
  23. lagunacc
    lagunacc F1 Rookie
    4,327
    Fuel pump - MAGNETI MARELLI 313011300019 - about 35 euros
    • OEN 893 906 091 B — AUDI
    • OEN 69435 — BOSCH
    • OEN EKP-3-D — BOSCH
    • OEN 119291 — FERRARI
    • OEN 121727 — FERRARI
    • OEN 53719568 — FIAT
    • OEN 1613157 — FORD
    • OEN 6106539 — FORD
    • OEN 6150295 — FORD
    • OEN 82GB 9350 AA — FORD
    • OEN 83BB 9350 AA — FORD
    • OEN 84BB 9350 AA — FORD
    • OEN 002 091 59 01 — MERCEDES-BENZ
    • OEN 002 091 88 01 — MERCEDES-BENZ
    • OEN 002 091 97 01 — MERCEDES-BENZ
    • OEN 003 091 53 01 — MERCEDES-BENZ
    • OEN 116 090 00 50 — MERCEDES-BENZ
    • OEN 116 091 03 01 — MERCEDES-BENZ
    • OEN A 002 091 59 01 — MERCEDES-BENZ
    • OEN A 002 091 88 01 — MERCEDES-BENZ
    • OEN A 002 091 97 01 — MERCEDES-BENZ
    • OEN A 003 091 53 01 — MERCEDES-BENZ
    • OEN A 116 090 00 50 — MERCEDES-BENZ
    • OEN A 116 091 03 01 — MERCEDES-BENZ
    • OEN 721 1 49 099 2/1 — PUCH
    • OEN 893 906 091 B — VW
    • OEN 893 906 091 E — VW
    • OEN 8G0 906 091 A — VW
  24. TestaDDS
    TestaDDS Karting
    Sep 6, 2015
    87
    France
    RM
  25. BR in the UK
    BR in the UK Rookie
    Sep 18, 2006
    40
    Stockholm
    Hi how did this work out? Any feedback? Would appreciate your thoughts….
