Testarossa Cross Reference Thread | Page 13 | FerrariChat
Discussion in 'Boxers/TR/M' started by JAYF, Oct 14, 2006.
  1. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    #301 dgt, Jan 30, 2016
    Melvok likes this.
  2. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    #302 qwazipsycho, Feb 14, 2016
  3. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    DON'T use this seal!!!!! Although the dimensions match the spec'd dimensions of the F seal, it's actually a .3mm larger ID. It will leak prematurely.
  4. jgmblair
    jgmblair Formula Junior
    811
    Winnipeg, MB Canada
    Jeff Blair
    #304 jgmblair, Apr 16, 2016
  5. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Bosch #438170001 Fuel Pressure Accumulator for TR.
    Various sellers on Amazon for around $80.
    Mine were leaking just before I got my engine out service and found them on Amazon.
    Shop wanted to charge me $300 each, NOT.
    I compared them to my original ones and they are exactly the same, worked great.
    Melvok likes this.
  6. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Mondial hood struts (PN 60563300) are a direct replacement for TR hood struts (PN 61496700 (early cars) superceded to 61571600) and hold charge considerably longer--used/recommended by Rifledriver
  7. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,065
    Troy, Michigan
    James
    #307 Veedub00, May 29, 2016
    Melvok likes this.
  8. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
  9. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    I have a better idea. Disconnect them.
    Melvok likes this.
  10. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    #310 qwazipsycho, Jun 14, 2016
    Melvok likes this.
  11. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,640
    wisconsin/chicago
    bo
    #311 bpu699, Jul 23, 2016
    Searched his thread but didn't find it...
    Anyone find a v-belt for the alternator or air pump that work and can be bought at the local napa? Bought them from Ricambi, but may have gotten the wrong items...
    Reads gates 6262mc 85be on new belts sent. Only way to get belt on is to take pulley off...
    Odd
  12. dwhite
    dwhite F1 Rookie
    Looks like a fuel sock for a 1978 CJ5 Jeep is a near perfect match. Needs very little modification. Thanks to cnpapa24.
  13. UpNorth
    UpNorth Formula 3
    Sep 30, 2006
    1,768
    Quebec, Canada
    Francois
    LS Technologies in Saskatoon, Canada
    This is where I found struts for the front lid of my 85 TR.
    Part # A8-8-090-255-330N Gas Spring ( Replaces Lift-o-Mat 530778 )
    $43.00 canadian each.
    Call and ask for Nolan. He knows what we are looking for.
    Great service!
    Melvok likes this.
  14. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    #314 ago car nut, Aug 21, 2017
    Rock auto: 1990 Chevrolet Caprice 5.7L V8
    air/smog check valve $ 27.65 pair
    GM22040897
  15. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    Going to build a TR fuse box relay bypass like Dave here:
    http://www.ferrarichat.com/forum/threads/tr-fuse-box-relay-bypass.561503/
    Really didn't want to use my old relays, which I suspect may be damaged anyway, so found this website I didn't see posted anywhere here to show the modern equivalent of the old relay numbers:
    https://secure.bosch-classic.com/en/produktsuche
    Put the # on the relay covering in the Bosch Order Number field, search, then click on the Alternatives tab to see the current replacement products.
    It seems waytekwire.com has the two types I'm looking for: 0 332 209 151 and 0 332 019 151, which replace 0 332 204 101 and 0 332 014 140, 0 332 014 113
    Melvok likes this.
  16. HOU
    HOU Karting
    May 2, 2009
    88
    Houston, Texas
    John S
    F12M Front Hood Struts
    Stabilus Liftomat 2196DQ 0700N 358/01 E10
    successful replacement May 2018
    Lift Supports Depot PM3087
    Melvok likes this.
  17. VColin
    VColin Karting
    Aug 5, 2012
    70
    SoCal
    Vince
    512 TR and F512M Radiator - OEM 150213 LH side radiator - OEM 150212 RH side radiator
    Replacement with Wizard Cooling units with same dimensions, higher capacity. Can be painted with radiator black paint to match.
    150213 LH side radiator interchanged with Wizard Cooling part # 60006-500
    Driver side LHD model:
    https://wizardcooling.com/1991-94-ferrari-512-tr-1995-f512m-driver-side-aluminum-radiator/
    150212 RH side radiator interchanged with Wizard Cooling part # 60007-500
    Passenger side LHD model:
    https://wizardcooling.com/1991-94-ferrari-512-tr-1995-f512m-passenger-side-aluminum-radiator/
    Testarossa Sean and Melvok like this.
  18. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,650
    Argent/Brasil
    Guido
    Instead of extra relais and wires hanging around of your fusebox, a better solution is changing your OEM board with a new board that has a thicker plate, bigger connectors for relais, fuses and wire connectors, has direct pin to pin solderpoints and wires of 2.5 mm2. Solves all those heating problems and you keep the OEM look !
    Those new boards you can find here http://redbaycars.com/remanufactured/ferrari parts.html
    or start conversation with theunissenguido.
    There is also an installation manual available in English, French and Italian.
    New boards are made for Testarossa, TR, 512 TR, all mondials, 400i and 412, F40, 288GTO, 328, 550, 456...
    Guido
  19. fast911ray
    fast911ray Rookie
    Jun 20, 2011
    15
    Sarasota, Florida
    Raymond Banicki
    How about early TR alternator & A/C V belt interchanges..
  20. bpu699
    Dec 9, 2003
    17,640
    wisconsin/chicago
    bo
    Not sure what that means. I can though tell you that you can change the alternator pulley with a $20 one off ebay with no issues. My belt kept popping off every 1000 miles so I put in a slightly oversizeed pulley that was deeper. No issues.
    Shamile and turbo-joe like this.
  21. c4b4the04
    c4b4the04 Formula Junior
    385
    Northern Virginia
    Cassidy
    My distributor center button had disintegrated over the past 30 years. The internal opening was roughly 0.22” dia. A Toyota truck 3.0 liter distributor cap from the mid 90’s has a 0.19” dia spring loaded center button. Drop in replacement. I cleaned the rotor with Deoxit cleaner and some 500 grit sandpaper. I used a bit of fine Emory cloth on the rotor contacts. The motor fired back to life, all 12 cylinders with good spark. The center button is a direct replacement and a part you can consider a 13 dollar service item. You’ll buy the whole cap, take the button out of the center and dispose of the cap itself. You’re only getting the button you need but at $13 usd, are you going to complain?!
    Cap part number is Borg Warner
    C763. Fits a 1994 Toyota truck 3.0L V6. About the most common motor on earth. Cheers. Hope this helps someone.
    FWIW, my research indicates Borg Warner standardized cap and rotor contact buttons. There are two sizes currently produced as spring loaded buttons. The smaller 0.19” dia and the larger 0.24” buttons. Openings in a Marelli TR cap are 0.22” dia so the 0.19 fits perfectly and the spring interlocks with the cap like factory. The Toyota cap I found is the cheapest and most plentiful cap I could source with the smaller size button. Others have it, this one is just the cheapest.
  22. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
  23. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    I had to replace the switch for the headlights. Lancia Delta Integrale is identical
  24. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    I’m looking to do the same. 100% swap in? Or did you have to mix and match some parts?
  25. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    Light switch fits, wiper switch too but needs changing plugs.
    xplodee likes this.
