Testarossa Cross Reference Thread | Page 12 | FerrariChat
Discussion in 'Boxers/TR/M' started by JAYF, Oct 14, 2006.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,613
    romano schwabel
    for what car is this compressor?
  2. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    The car is a 1987 TR.
  3. turbo-joe
    Apr 6, 2008
    9,613
    romano schwabel
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,291
    Mel
    #279 Melvok, Jun 21, 2015
  5. Melvok
    Jul 25, 2008
    14,291
    Mel
    #280 Melvok, Jun 22, 2015
  6. turbo-joe
    Apr 6, 2008
    9,613
    romano schwabel
    right mel,
    but much cheaper than buying those from F
  7. Melvok
    Jul 25, 2008
    14,291
    Mel
    That's what I meant ... yes !
  8. wintech
    wintech Karting
    Jun 1, 2011
    206
    Perth WA
    Pete K
    #283 wintech, Jun 25, 2015
  9. Melvok
    Jul 25, 2008
    14,291
    Mel
  10. Steve
    Steve Formula Junior
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    A lot of us (including myself) used this post for finding replacement solenoids for our 512 TR or TRs.
    I bought the WAI and eventually still had the heat soak issue, so I decided to just fix the original problem. Now I'm back using the OEM Bosch unit and it works great. Here's my blog post with lots of photos:
    DIY: Fix a Ferrari Testarossa / 512 TR Hot Start Problem - SteveJenkins.com
  11. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Wow, Steve, that was way above the quality mark Mate.
    well done and a very well put together help file.
    I'll add it to my website for others to use unless you object........
    Phil
  12. Steve
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    Anyone got a replacement for the long hex screws that hold the 512 TR fog lamp in place? The dealer wants $27 for one of them.
  13. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,935
    wisconsin/chicago
    bo
    Anyone found a fix/replacement for the modules that throw up the "slow down" lights? These have no correlation to reality, and flash randomly...
  14. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Throwout Bearing (PN 70000567):
    There's a more detailed thread (http://www.ferrarichat.com/forum/boxers-tr-m/436550-throwout-bearing-thrust-bearing-clutch-release-bearing.html) but here's a brief summary
    Many choices available and they differ immensely in price:
    -OEM SKF is not available to my knowledge
    -AW Imports $380
    -Ricambi $460
    -Capristo $330
    -EuroSpares $490
    -EuroSpares (Pattern) $125
    -Ferrparts (Maranello Classics) $900
    -SuperPerformance $150
    I have the SuperPerformance and so far so good.
  15. Steve
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    #290 Steve, Aug 18, 2015
    Nevermind. I decided to make my own replacement. :)
    The nut is part #14 on the "lamps" page of the parts manual.
    There are two per side, and the previous owner apparently lost one of them (I discovered this out when changing bulbs) as well as part #15 with is a fastnut that helps hold the fixture in place.
    I took one of the OEM nuts to the hardware store and perfectly copied the functionality with $2 worth of bolt, nut, and washer. I also got a replacement fastnut for the fixture for pennies. When installed, you can't see any difference visually... but they're installed behind the front grille so you'd never see them anyway.
    It's a 6MM 1.00 course thread nut. Add a nut and a washer (outside the nut) and you're good to go.
    If you're not able to find a bolt where the thread stops like I did (which keeps the nut from moving up), you can buy a second nut and tighten them against each other.
    MisterT likes this.
  16. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    Differential oil seal left and right side (to replace deleted left side oil seal)
    use seals that is used both left and right side and I found that 45mm x 60mm x 8mm seal that works with my both cars are: VAG 016409399B
    Oil seal used almost every VAG product from 1980 to 2000 in Volkswagen, Audi and Porsche.
    Fitment is mutch better then original and is with double seal lip and is ment to be used in both sides.
  17. turbo-joe
    Apr 6, 2008
    9,613
    romano schwabel
    this cross reference thread is a very good thing :)
    problem is only to find something what someone is looking for. this takes a lot of time and my be you will give up just before you found what you are looking for. :(
    for example: when I type: diff oil seal TR then this cross reference thread is not appearing
    who has an idea to make this better???
  18. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
  19. Steve
    Nov 1, 2003
    901
    Seattle, WA
    Steve Jenkins
    I don't use the built-in search here. Type this into Google:
    site:ferrarichat.com diff oil seal TR
    You'll get lots of useful results, limited just to FChat.
  20. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    AutohausAZ has re-manufactured Bosch Starters (SR4884) for $298 with free shipping. Thats the best price I could find online as of this writing. My car only has 14,XXX moles on it but I could hear a difference on the new starter.
  21. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
  22. bpu699
    Dec 9, 2003
    17,935
    wisconsin/chicago
    bo
    Just wanted to add an update on spark plug wire options...
    Prior posters had mentioned getting NAPA wire wound wires... I searched low and high, and none of the NAPA stores still carry those...
    I also searched the net like crazy, trying to find wires with a 500-700 ohm per foot resistance, that were 7mm...
    I would have had an easier time finding dinosaur bones...
    There were threads that mentioned Taylor wires... Checked their site, they no longer make 7mm...
    Others mentioned magnecor... 8mm only...
    Saw threads mention that Dave Helms had some custom wires made that were 7mm... the threads mentioned they were 300 ohm per foot... and used for a 308? Didn't sound like what we needed...
    Searched Jegs, Summit, etc, etc... few carry 7mm, none list resistance...
    Searched Accel.... no go...
    Did come accross Kingsbourne wires out of California... They have the EXACT wires we need. 7mm, spiral wound, fiberglass core, 500 ohm per foot resistance, in black/red/yellow...
    And its $30 for 25 feet, or $50 for 50 feet... So, just ordered those...
    As these things are getting harder to find by the day, folksmay wish to stock up...
    I saw som eother folks use these in a 308, but thought I would add to this thread...
    Bo
  23. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Bo we have cables over here in the UK. I fitted them to mine some years back and still work perfectly. I have been told that it is important to get the correct spec for the cable as the electronic ECU's in the car have limited electro emission rejection.
    Message me for details.
    Phil
  24. AntonioMora
    AntonioMora F1 Rookie
    Jul 27, 2004
    2,941
    Malaga (España)
    Antonio Mora Romero
    Why are so cheap testarossa USA model?, european version are more expensive. regards.
  25. Special$K$
    Special$K$ Rookie
    11
    Amelia Island, FL (winters) Boone, NC (summers)
    Keith
    #300 Special$K$, Jan 9, 2016
    Are you referring to the ECU modules?
    There are 2 - one for cylinders 1-6 and one for 7-12.
    My 88 TR shows part # 62347000.
    Part # 5 on the ALGAR catalog......Table 12.
    The F pimp wants $595.00 each for them......
    I have been looking for one, or a cross reference to Bosch? maybe?.......
    Anyone?
