Testarossa blower motor only works on high | FerrariChat
Discussion in 'Technical Q&A' started by gizmo, Apr 25, 2007.
  1. gizmo
    gizmo Rookie
    Mar 3, 2004
    7
    the blower motor on my testarossa works fine, but as soon as you rotate the knob backwards to slow the speed down it shuts off completly. anybody have this problem before. also does anybody know where i can get a wiring diagram for a 1990 testarossa?
  2. MaleficVTwin
    MaleficVTwin F1 Rookie
    Jun 5, 2006
    4,312
    Reno NV
    Matt
    I'm not sure how the TR blower motor is wired, but in a "normal" car, that symptom is characteristic of a fried blower motor resistor. If I'm wrong, someone else please chime in. As far as wiring diagrams go, I'm not sure what you're looking to spend, but you can get the factory service and parts manual here on CD-ROM for $200.
  3. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    Change the Bosch fuse-the silver colored square thing in the fuse box. Look at the diagram in the fuse box to see which one it is. Diagnose it by swapping with another one that is working, or just buy a new one. They should be changed every few years. Buy a box of them. Should fix the problem for about $12. ;) Jim
  4. Steve Magnusson
    26,506
    Do a search on "TR power transistor" -- should get you ~10 relevant threads with information on this topic.
  5. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    Steve (91tr) is correct based on my experience. Replace the power transistor (p/n 127014) and your problem should be solved. I think the resistor retails for about $125.
