Testarossa AC Dryer Freezing | FerrariChat
Discussion in 'Technical Q&A' started by swamthing, May 3, 2021.
  1. swamthing
    swamthing Rookie
    Apr 28, 2021
    12
    Jonathan Clark
    AC seems to be flowing at startup and blowing cold. After a few minutes the dryer starts to freeze at it's base and flow stops. My AC compressor does run and I see flow in the sight window until it freezes.
    Thoughts on where I start before a dealer tells me they have to pull my dash apart?
  2. wmuno
    wmuno Formula Junior
    430
    Wilmette, Illinois
    Bill Muno
    Freezing in the evaporater (and dryer) is usually caused by low refrigerant. Recharge the system and see if this solves the problem. If it does, the next step would be to determine if there is a slow leak. If an obvious leak can not be found, there are sealers that can be added to the system to stop pinhole leaks.
    tbakowsky likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,563
    Central NJ
    Dominick
    My bet considering on high side a blockage in dryer
    Test a few things
    Are lines coming into dryer hot ?
    Are lines leaving dryer colder ?
    If yes ..dryer has a blockage and acting as an orifice
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    Some debris are probably preventing the expansion valve from properly stoping liquid refrigerant from escaping the evaporator.
    Check also that the pressure switch on the drier is properly operating.
    Circle K likes this.
  5. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    For the record, the refrigerant enters the evaporator in liquid form, then should "evaporate", and finally gets pack to the compressor (through the drier/filter).
    When it escapes the evaporator, if it is in liquid form, there is a risk to seize the compressor. Sot there is an expansion valve at the exit of the evaporator. This is basically a "sensing bulb" that expands when the refrigerant is too cold (i.e liquid). This expansions closes the system, as a result this modifies the pressure untill the pressure switch kicks in and stops the compressor.
    If your drier is too old, it is possible that some desiccant particles have escaped from the filter and found their way up to the valvle and prevent it from properly closing.
    If your AC does have a thermo-switch (snowflake switch with a fin inserted in the evaporator), then you can try to reduce the AC input and see if this solves your issue temporarily (thermo switch stops the compressor when the evaporator has riched a given temperature, if switch is low enough this kicks in before the expansion valve). In this case you could invest in a new dryer and let the AC work until the debris are all captured again by the new filter.
    This is based on my knowledge of the 400i system, so your mileage on the Testarossa may vary.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,563
    Central NJ
    Dominick
    #6 flash32, May 3, 2021
    The dryer /sight glass is on the high side on the testarossa then to the expansion valve ..so not sure if your description fits
    It is liquid going in and out of the dryer /sight glass .. The issue here is that it is turning to gas within the dryer ..hence blockage/restriction within the dryer if lines coming in are hot and outlet is cooler
    If lines are cool both sides - most likely a low refrigerant
  7. fatbillybob
    Aug 10, 2002
    26,292
    socal
    Low hanging fruit DIY style, sans real diagnosis is to evacuate, cook dryer in oven 250F for an hour, refresh orings in system, draw vaccum for 1+ hours. Then if vac hold recharge. This involves very little of your time while you do other things in the garage. Now doing it right is a much longer process.
  8. windsock
    windsock Formula 3
    1,066
    The drier in this system is on the high side after the condenser so it should see nothing but liquid refrigerant. This is likely due to a plugged or restricted filter causing a pressure drop in the drier assembly. Now the next question is what is causing the restriction. Best case the drier bag came apart, worts case the compressor is failing and sending metal through the system. Remove and open the drier and inspect for debris.
    flash32 likes this.
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    If the dryer is on the high side, I would not try to resurect it in the oven, and use instead a brand new one (not new old stock "with glass" ).
    The pressure switch that is built in the dryer (I see to wires on the pic) may also have been damaged. Would not take a chance.
    When was the dryer last replaced?
  10. swamthing
    swamthing Rookie
    Apr 28, 2021
    12
    Jonathan Clark
    I’m not sure. Trying to look through history. They did some AC work 5 years ago then a recharge 3 years ago.
  11. tazandjan
    37,985
    Ferrari recommends changing the drier/filter every 2 years on models up through the 575s.
  12. swamthing
    swamthing Rookie
    Apr 28, 2021
    12
    Jonathan Clark
    Does anyone have advice on where to get a new AC Dryer?
  13. raemin
    raemin Formula 3
    Jan 16, 2007
    1,825
    Lyon (FR)
    R. Emin
    Any AC shop will stock a suitable dryer. On my 400i, a cheap four seasons product bought on Summit Racing was a perfect match.
    This being said connectors may vary from one model to another depending on what maranello had in stock, so let your AC shop pick the right product, or be ready for a bit of trial and error. This being said, these products are cheap, so you may take a chance.
    Have a look at http://www.ferrari.cdyn.com/carl_rose_docs/
    That's for the 328, but plenty of valuable information.
  14. Rifledriver
    33,736
    Austin TX
    Driers from an AC supply are cheap and they are considered a routine service item. Take the old one out and go to an AC shop and have it matched.
