Temperature issues in unheated garage
Discussion in '360/430' started by drcripp, Jan 6, 2017.
  1. drcripp
    drcripp Karting
    Nov 1, 2016
    123
    Pittsburgh
    David Crippen
    #1 drcripp, Jan 6, 2017
    Winter is here in Pittsburgh along with snow and my beautiful 360 is covered in the garage with the trickle charger in place. Unfortunately, the garage is not "heated" but two of the four walls are contiguous with the house so it rarely gets much below freezing. However, it sits around 30 degrees for most of the winter. It's sitting at 30 now and the temp outside is 18 degrees. I'm told by the Ferrari technician that the charger should go on before a week in the garage passes which sounds reasonable. Is there any particular problem with letting the car sit for extended periods at or somewhat below freezing? Should I spend a bundle to have the garage heated?
    Thanks in advance.
  2. 24000rpm
    24000rpm F1 Rookie
    One of my parking space is always 30-40 degrees F throughout winter (dec--Feb.)
    and I start it up and drive it like every week, even in the snow.
    No battery tender!
    No problem so far.
  3. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    It will be fine.
    TBH. I think ppl worry more about temp when they should be more concerned with humidity.
  4. ENDOSURG
    ENDOSURG Karting
    Dec 9, 2008
    70
    Massena,New York
    Vijaykumar Mandalaywala
    I am not sure whether your garage is insulated. You can at least reduce draft from the door by adding a nice rubber seal edge to the garage door. And in extreme cold days you can add an electric garage heater. Check the voltage which your garage outlets supports.Or you may consider space heaters, some of them you can turn on and off using internet/ app from your phone.
    I have 220 volt garage heater in my garage and I maintain around 60. I don't drive my 430 in the winter. It is off the road from Oct 1 till spring. A battery tender in place. I live near the border up north and it gets very very cold at time minus teens.
  5. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    I have to ask ... if the car in your garage were a Toyota Camry ... would you feel you needed to have a heated garage? Or in the summer, a cooled garage? I live in Arizona and of course winters are not an issue, but there are some people who believe that a cooled garage in the summer is beneficial for the car. I doubt it makes any difference and the only reason I can think of for heating or cooling a garage is for the comfort of the human occupants. I think your car will be fine in a cold garage. And, the battery will not suffer either.
    Steve
  6. I.T. Guy
    I.T. Guy F1 World Champ
    Jul 17, 2004
    12,923
    Canada
    Jason
    Only real issue is some high performance track tires with soft compound will freeze and ruin. Any street tires will be ok.
  7. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,969
    St. Louis, MO
    Eric
    My garage is 10 degrees right now.
  8. bart12
    bart12 Formula 3
    Nov 6, 2008
    1,711
    The River runs through it
    MD Leo
    My garage is 10 degrees right now but I drive mine atleast once a week to work, unless it is icy. I wish I can drive mine more than 1-2 week but I need to rotate using my cars to make sure they are driven with purpose.
    Dont like to drive around the town for no apparent reason. It is useful but a waste of gas.
  9. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    Is this gag thread?
  10. SuperF
    SuperF Karting
    Jul 27, 2016
    164
    Philadelphia suburbs
    Lou
    My garage was built like a barn. Before welcoming my SuperF, I built myself the ceiling (3 weeks of evening work), I sealed every hole in the doors' opening, I sealed the 2 windows, and installed an electric heater. Temperature is now 40F+ when outside is less than 20F. My Ferrari Master Technicians told me it is better to avoid subfreezing temperatures and condensations due to cold car parts in humid conditions during pre-Spring days.
    I have experienced degradation of different articles kept in the garage after winter, such as hoses, plastic containers, oils, etc. so it is not so difficult to imaging the slow but meaningful degradation of some delicate parts exposed to low temperature, whose effect may not be apparent now but may cause long-term damage. It was "easier" for me to put in the effort upfront and lower this risk. Now, I'm sleeping like a baby on sub-freezing nights!
  11. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    It is 0 degress outside m garage now and will be minus 10 tomorrow night - but garage is 60
  12. dreichman
    dreichman Formula Junior
    Sep 9, 2011
    425
    Denver, CO
    It'll be fine. No worries at all. Just make sure you put your battery maintainer on it's lowest power setting.
  13. KM1959
    KM1959 Formula Junior
    Nov 12, 2014
    984
    Kevin
    Jeez, I didn't realize how cold it was in other parts of the country right now. 0 in NC? 10 in Dallas? Sorry guys.
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Some great stuff on u tube showing cars being started in minus 40 c. They all start up if a bit slowly.
  15. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Your car should be fine as long as none of the fluids freeze. Connect the battery to a maintainer... to help prevent the battery acid from freezing as well as maintain charge. Starting a car in very cold temps just to keep the battery up is a bad idea, as a lot of wear occurs due to the low fluid flow of the lubricants. Humidity can be a concern as things can still rust in cold temps. It's expensive to heat a garage, in part because most are not well insulated, so I'd start with improving insulation before adding heat if you are still concerned.
