TBM Avenger ditches public beach | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by rob lay, Apr 18, 2021.
  1. TheMayor
    TheMayor Nine Time F1 World Champ
    98,771
    Vegas baby
    I bet she flies again.
    ChipG and boxerman like this.
  2. boxerman
    boxerman F1 World Champ
    18,809
    FL
    Sean
    I dont doubt it for a minute, all it requires is $.
    NürScud, ralfabco and TheMayor like this.
  3. jcurry
    21,566
    In the past
    Jim
    There are some pretty good anti-corrosion compounds available (ACF-50, Corrosion-X) that work well in penetrating seams and displace water. I've read reports where these even work on electronic components, e.g. radios, that have been immersed in water.
  4. Etcetera
    Etcetera Two Time F1 World Champ
    22,268
    C9H8O4
    It would be a pile of atoms shortly after exposing it to the air.
  5. Etcetera
    22,268
    C9H8O4
    I saw one of these at the Warhawk Museum. HUGE plane. I was surprised at the scale of it.
    MIG in the same area looked about Guillow's sized in comparison.
  6. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    7,917
    Shoreline,Washington
    Robert Parks
    When we lived on the beach on Siesta key, a guy just down the beach from us kept a nice little Luscomb in front of his house. He flew it occasionally and one day I noticed that he didn't have it in front of his house for quite a while and found out that he had taken it in for its annual and it was grounded. Corrosion and rust from the salt air had done it in.
  7. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    38,809
    Huntsville, AL., USA
    Andrew
    JJ and ChipG like this.
  8. jcurry
    21,566
    In the past
    Jim
    When I was looking to buy my first airplane I avoided anything that had more than a couple yrs near the gulf and east coast. 5yrs on the gulf coast would cause more damage than 20yrs sitting outside in WA.
  9. jcurry
    21,566
    In the past
    Jim
    In the video the last two people in the water that he passes before 'landing' are surfers. You can see them catch a wave as soon as he goes by them.
  10. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    As I remember, this airplane was on and off the beach for a period of about 2 1/2 years. The sun and salt air on the mid-state Gulf coast is brutal on everything.
  11. jcurry
    21,566
    In the past
    Jim
    I looked at one Mooney that had spent about 10yrs in Fl. There was corrosion around every inspection plate on the wing, and Mooney's used clad sht.
  12. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    A lot of you probably know this but I thought that I would offer it anyway. Every time a clad aluminum sheet is trimmed or drilled the alloy is exposed no matter if it is clad on both sides. A deep scratch will do the same and I have spent a few hours with a supply of vaseline and a burnishing tool closing the opening by working the clad back over the wound. Universal head rivets can trap small amounts of contaminants under the head but a countersunk or flush rivet exposes a relatively large area of the alloy under the head and in the case of an unpainted surface operating in a salty environment, the corrosion never sleeps. Soon the material around the rivet head deteriorates , pillows, and fails and precipitates a blow out or other structural failures . Steel fasteners produce rust that insinuates the aluminum structure around it and destroys the connection.
    tazz99, afterburner and tritone like this.
  13. tazandjan
    38,074
    Bob- You also get galvanic corrosion where steel meets aluminum.
  14. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    I didn't remember that, if I knew it. The only thing that I could think of was the invasive action of the rust into the surrounding materials and the conjoining of steel into steel when two adjoining pieces are exposed to the environment. I have lived with fabric covered, wooden, and aluminum airplanes and all are vulnerable in their own ways to the environment that always tries to take them back to their origin.
  15. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    You should never pay attention to atoms. They make up everything.
    BJK, tritone, Gatorrari and 1 other person like this.
  16. Etcetera
    22,268
    C9H8O4
    Yes. The difference being neatly arranged and selected atoms vs a pile of random atoms randomly arranged.
  17. Gatorrari
    Gatorrari F1 World Champ
    15,939
    Georgia
    Jim Pernikoff
    :D:D:D
  18. jcurry
    21,566
    In the past
    Jim
    Correct and no they do not. Seaplanes land in salt water everyday. PBY's, Clippers, and others did for yrs. They, like every other airplane, have seams in the skins. Seaplanes/floatplanes leak, constantly to some degree. Standard practice to pump out all water prior to TO. But yes, corrosion maintenance is an on-going task. This plane sitting in the water for a few hrs won't fall apart. More work replacing damaged components than worrying about the salt water bath.
  19. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    We're not talking about water-borne aircraft that are designed and prepared for operating from the water's surface. We're referring to totally immersing an airframe that has little or no protective coatings internally or externally. We're not imp[lying that the TBM will "fall apart" from sitting in salt water for a few hours but it will eventually have hidden and unstoppable corrosion in every element of the structure and instruments. Well , what the heck did the Air Force know, anyway? They only operated aluminum airplane for 88 years.
  20. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,577
    Recovery update
  21. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Let me know if it is listed on BaT with a 50% off salt sale.
    Texas Forever and Boomhauer like this.
  22. jcurry
    21,566
    In the past
    Jim
    Doubtful. What they don't clean directly during the rebuild they will treat with
    Lear Chemical Research Corporation or
    CorrosionX Aviation – Corrosion Technologies
    They will have likely already treated most of the airframe with one of these. Instruments and avionics can also be treated with these products, then thoroughly cleaned and re-built. There will not be "hidden and unstoppable corrosion in every element of the structure and instruments".
  23. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    Okay, now I know something.
  24. BJK
    BJK F1 Rookie
    Jul 18, 2014
    4,789
    CT
    or, if cost of re-furb is too high/not worth it, they will relegate it to 'for display only.'
    jcurry likes this.
  25. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    Aw, come on ! According to the experts, they can buff that out in the morning and squirt some stuff in it..
    tritone, jcurry and BJK like this.
