Talk to me about Turbo Blow Off Valve
Discussion in 'General Automotive Discussion' started by BillyD, Sep 14, 2006.
  1. BillyD
    BillyD Formula 3
    1,809
    Pacific Northwest
    Bill
    My newphew, who is lucky enough to have his dream car, a Dodge Stealth Twin Turbo at 17 wants me to help install this:
    http://www.3sx.com/store/comersus_viewItem.asp?idProduct=124
    I know crap about turbos or Stealths/3000gts. Is this a simple mod with no ramifications to the engine management systems? looks like "weld in" so is it muffler place install? Help, I'm still just barely into fuel injection much less turbos.
    thanks
    Bill
  2. Der Meister
    Der Meister Formula Junior
    Aug 16, 2005
    657
    Glendora/Prescott
    Alan
    it should be a pressure relief valve, so when he takes his foot off the gas the Car wont over boost and kill the engine. since he already has a trubo/turbos. it should be a matter of switching out the old ones for the new ones. Its going to be really loud when hes done. Ie a cop magnet.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    The way I understand it, each turbo should have a wastegate that limits its full boost pressure (which I believe is 14psi on the Stealth). If there is a single blow-off valve operating in the range of 10-25psi, it would have to be mounted on the intake manifold (is there enough clearance under the hood?). The only time this blow-off valve would be operating would be if it were releasing boost pressure from the manifold, which would basically be .....just about never, and only if the car was being WHIPPED. And what is the point? To make noise???? Do the car and the lad a favor - have him spend the money on some nice tires, or some gas, or insurance. This thing is a waste.
  4. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,778
    IgnoranteWest
    Bill
    Do Not Pass Go. Do not collect $200.
    Go directly to:
    http://www.3si.org/forum/
    Almost as big as Fchat, but focused specifically on the Stealth/3000GT.
    All Stealth/3000GT knowlege will be revealed.
  5. jmn
    jmn Formula Junior
    Jan 31, 2005
    361
    Colorado
    jmn
    That's not how they work. When you close the throttles, you send a whopper of a pressure wave back toward the turbo. With the blowoff valve, that doesn't happen, as the turbo continues to spin and "blows off" pressure, because the vacuum in the intake opens the blowoff valves. The advantage is that you have less lag because the impeller continues to spin (for example, between gears while shifting while the throttle is closed VERY briefly) and you are easier on your turbos.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,084
    Dumpster Fire #31
    SMG
    right, and make sure you vent un-metered air or it'll screw up the AFR. blow off the pressure before the air mass sensor, or you'll have to re-route it back into the manifold i.e. bypass.
    i just bought one for the mondial SC project. it's a HKS sequincial valve. 9second racing had the best price, from shopping around.
  7. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Bay Area / Washington DC
    Quick Draw
    They sound cool as hell too :D
    I love the flat 4 WRXs with blow off. Sounds evil.
  8. ChunkyMonkey
    ChunkyMonkey Formula 3
    Feb 27, 2006
    1,582
    Texas, duh
    Chad
    They claim for a faster throttle response as well, but I didn't notice a change on our car. I mainly bought it as a turbo saver, keeping the rush of air from abruptly forcing the turbo to spin the opposite direction. Tell him to look into going for a single turbo mod.....Are the Turbos on the car sequential or non-sequential?
  9. ChunkyMonkey
    Feb 27, 2006
    1,582
    Texas, duh
    Chad
  10. EspritSE
    EspritSE Formula Junior
    Dec 1, 2003
    509
    Colorado
    Craig
    Install is a snap with the TurboXS H-3000gt...
    about $40
    http://www.turboxs.com/shop_prod.php?what_category=5
    Craig
  11. JZ TWINS
    JZ TWINS Karting
    Sep 5, 2006
    184
    I have a 97 Supra twin turbo. I left the factory blow off valve in since it recirculates. I have a blitz venting one on the other side of the intercooler. Some guys take out the factory one and have an external bov. At idle, if they hit the gas, the car almost die since there is not air. That is why I left my stock one in. No idle problems
  12. ECTurboGSX
    ECTurboGSX Formula 3
    Dec 26, 2004
    1,074
    Bay Area, CA
    Eric
    The 3000GT/Stealth has a MAS at the filter before the turbos. Using this blow off valve will cause a rich condition every time he lets off of the throttle because air that had been accounted for by the MAS will no longer be in the system. Some of these cars do not have much of a response to this, others run terribly, there really isn't any way to predict this. My advice would be for him to pull the recirculating hose off of his stock blow off valve (aka compressor by-pass valve) and plug the end of the hose that leads back to the intake. This will do the same thing that the RFL would do. Take it out around the block and see how bad it runs.
    Honestly though, I would highly recommend against the RFL. Its loud, obnoxious, does not sound good, and you are making the car run worse. There are plenty of other things to spend money on that will actually improve the car. If he gets an open air filter intake kit, you will be able to hear the stock blow off valve, even though it is recirculated.
    There is a stock blow off valve and it is located at the Y-Pipe. The compressor outlet pipes from both turbos run up and join on the left side of the intake manifold into a Y-Pipe, which then feeds into the intake manifold. Therefore, one blow off valve, not two. Tell your nephew to spend his time reading long before he starts throwing parts at it. There is so much knowledge out there about these cars, most of the owners work on them themselves. My best friend is very big into the Stealths (I'm obviously on the DSM side of the equation) and he's put a Stealth through the quarter at 12 flat on the stock turbos (which look like they belong on a weedeater). He didn't do it by wasting money on flashy blow off valves or colored hose, he did it by carefully selecting parts after a lot of research and spending a lot of time fine tuning everything. He's since rebuilt the entire engine with larger turbos and then got rid of it. He's just now sold his second stealth and I don't know what is coming next. Your nephew should get into the community early on and he will save himself from committing expensive mistakes.
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,084
    Dumpster Fire #31
    SMG
    this is good help right here, learn from others and save yourself the time and money. i've pioneered many a project, that in the end helped alot of others save money and time. which is the point of many of us getting together to help each other.
  14. RH550
    RH550 Karting
    May 17, 2005
    53
    LA / Hong Kong
    Roshan H.
    FYI, there are dual vent BOVs that recirculate the intake charge at lower boost levels, while venting to atmosphere at higher boost levels. This eliminates any driveability issues that occur due to MAFs not seeing the required airflow. They're generally quieter under normal use, but can be as loud as some of the other vent-to-atmosphere BOVs at higher boost levels.
  15. BriSalig
    BriSalig Formula Junior
    Aug 29, 2002
    330
    Atlanta
    Andrew
    I had one on my modded WRX, and ran into problems with it leaking....just to think about, there might be better BOVs out there. take a look at HKS SSQV--its a piston valve and incapable of leaking. If you need help finding one, send me a PM.
  16. EspritSE
    Dec 1, 2003
    509
    Colorado
    Craig
