Swirl marks from rubbing compound | FerrariChat
Discussion in 'Detailing & Showroom' started by jimpo1, May 13, 2013.
  1. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,867
    Dallas, TX
    Jim E
    #1 jimpo1, May 13, 2013
    I bought my kid a used car to take to college about a month ago. He was washing it yesterday and I noticed it had some fine scratches in the hood. He said they'd been there since we bought it, and he wasn't worried about them. In my infinite wisdom, I grabbed the rubbing compound as I was sure that it would help minimize them.
    I made it worse. Not only did the rubbing compound NOT help with the existing scratches, it put lots of little swirl marks in the section of the hood that I did. In bright light, it's pretty noticeable. I told him I'll pay to get them out if needed, but thought I'd ask for suggestions from the pros here first. He's not happy with me, but he's hiding it well.
    Car is a dark silver 07 Nissan Sentra SE-R Spec V if that matters.
  2. GuyIncognito
    98,978
    was the rubbing compound you used clear coat safe? If not, ruh roh Shaggy.
    also, rubbing compounds are usually intended to be the first step, followed by wax or some other top coat polish. so maybe a quick coat of wax will cover your sins.
    good luck!
  3. GuyIncognito
    98,978
    oh, and was this done by hand or with an orbital buffer (or something else)?
  4. jimpo1
    Jul 30, 2001
    24,867
    Dallas, TX
    Jim E
    Um...there's a diff? It was Turtle Wax rubbing compound. Done by hand.
  5. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,778
    IgnoranteWest
    Time to call Jano and see if he'll fix it and tutor you and your boy on what to use and what not to use!
  6. FarmerDave
    Jul 26, 2004
    15,778
    IgnoranteWest
    also this. I always thought it went Rubbing compound, then polishing compound, then wax and buff.... with some or all of these steps done with an orbital.
    I've never had the cajones to try all those steps myself.
  7. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    Try meguires scratch-x followed by meguires swirl-x. You can buy those at pretty much any auto parts store. They are clear coat safe, and do a very good job. If you can't get it out using those products by hand, you will most likely need to go to a professional detailer that uses a wheel.
    Do yourself a favor and throw out that compound! It has no business touching car paint. I like the meguires products mentioned above because they have what's called diminishing abrasives. The more you rub it, the finer the abrasives get. It just polishes the paint more and more as you work it in. If the damage is bad start with scratch-x because it is a little more abrasive and will get the marks out quicker. If they are just swirl marks, or if you don't mind doing the area 10-20x, then you can probably get away with only swirl-x. By what you described, it sounds like you may need scratch-x first. A photo of the damage would help.
    Once you are done, top it off with a nice wax.
    As long as you didn't go through the whole clear coat, it should come out perfect when you are done.
  8. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Rubbing compound is rough stuff as noted. The marks it left are no different than any other and are repaired like any other.
    The basic theory is to carefully and slowly remove paint until you reach the bottom of the scratches. This is typically done with varying coarseness of polish. You want to do the minimum possible to remove the scratches.
    So, as others have said, start with a more aggressive polish #4 or greater and then work up to a #2 followed by wax.
    You could do it by hand but a random orbital polisher will make life much easier/faster. Assuming you do not have one, borrow one.
    Or just run it down to the local detailer.
  9. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Your going to want a slightly milder polish with a high speed to remove the coarse marks made by the compound. If your not proficient in this craft go to a detailer.
  10. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    That old turtle wax compound was for paints prior to clear coats that were soft and the coarse compounds would simply remove the top loose layers without really scratching the lower layers. Today's (last 20 years or so) have the clear coat that is very thin but hard. The old turtle wax compound in the green tin really shouldn't be used on clear coats unless you can buff (high speed) properly. It can be done and is routinely done by detailers.
    Don't sweat too much just turn it over to a detailer who knows how to buff. Many don't.
  11. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
  12. jimpo1
    Jul 30, 2001
    24,867
    Dallas, TX
    Jim E
    Yeah, that's what it was. Green tin. Isn't over 2 or 3 years old. It goes in the trash tonight.
    I may try the Meguires stuff before springing for a detailer.
    Oh dopey me.
  13. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    A dual action orbital such as a Porter Cable will get them out. The rubbing compounds are so abrasive, you definitely need to refine the paint after with something milder, a medium polish. By hand, I'm not sure how much you will get out. Megs 105 is a good compound that can be bought locally, Megs 205 is their milder follow up polish that will finish down nicely. With a Porter Cable, this will not be too bad of a process, by hand, it will probably suck.
    Sent from iPhone
  14. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    #14 up4speed, May 21, 2013
    Good plan of attack, please post the results.
    I just finished removing massive amounts of swirl marks from my sister in law's M3 last night. It looked like someone used a 3M scotchbrite pad on it. She just purchased a VERY clean used car, I'm guessing that the prior owner always wanted it to look clean, so they used detail sparay on it to keep dust off of it. That's the worst thing for paint, the dirt just gets rubbed in that way. A car should always be washed with 2 buckets of water after the loose stuff is floated off of the surface using water pressure. One bucket to soap the washing mitt, the other to rinse it.
    The result of my (and my brothers) work was STUNNING! I used all Griot's Garage products. I used their DA Buffer with Griot's #3 Machine polish. There were some tough spots where I used the Meguires Swirl-X, it's a little more aggressive than the Griot's stuff that I used, but still totally safe and it still works on the same principle of diminishing abrasives. Here are the results on the hood which happened to be the worst panel, take note of the sharp reflections. I don't have a before pic, but I can tell you that the reflection looked hazy:
  15. jimpo1
    Jul 30, 2001
    24,867
    Dallas, TX
    Jim E
    For the price of a Porter Cable, I'll just pay a pro. Coming to Dallas any time soon? :)
  16. Envious Eric
    Envious Eric Karting
    Sep 21, 2009
    238
    Orange County, CA
    Eric
    you need to compounds, then polish, then wax
    meguiars ultimate compound, then megs polish OTC would be a better compound/polish duo.
    Scott's Mobile Auto Detailing :: Home or net would be a good person to call!
  17. jimpo1
    Jul 30, 2001
    24,867
    Dallas, TX
    Jim E
    Update:
    I used Meguires Swirl Remover 2.0 and it worked beautifully! I also bought the Swirl X to do a 2nd application, but the first one worked so well I didn't use the Swirl X.
    I applied it by hand using only front/back motion, not circular. It even helped the scratches I was originally trying to repair.
    Thanks all for your input!
  18. BigTex
    79,320
    Houston, Texas
    Bubba
    +1000
    Perfect It or the 3M Finnesse It, these are special for clear coat.
    I use them to buff out minor scuffs and marks all the time, GREAT product.
    The old rubbing compounds I use on mag and aluminum wheels for when you have real debris you want to cut thru....
  19. ConnyF
    ConnyF Karting
    Jun 27, 2013
    173
    Europe
    Conny
    You mean that blue 3M bottle, right?
  20. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    haha, I am not, but I can if you would like. You will have to give me about 3-4 weeks before an opening.
    EDIT: Just saw your other posts. Glad you found something that worked.
  21. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
  22. Ptek Will
    Ptek Will Rookie
    Sep 9, 2013
    4
    There were a couple possible reasons why you swirled your paint with compound.
    1. Dirty applicator, possible, but not very likely.
    2. Japanese cars tend to have soft clear coat. A light to medium abrasive polish will remove the majority of your swirls and light defects. Which is why scratch X worked for you.
    Compounds will mar and instill it's own swirls in an effort to remove deeper swirls on soft clear coats. Totally natural. For this particular car and paint, the compound was too abrasive, but the scratch X was just enough.
  23. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    Interesting I will have to try this ...
