Suspension | Page 3 | FerrariChat
Suspension
Discussion in '308/328' started by Imatk, Nov 30, 2020.
  1. ginoBBi512
    ginoBBi512 F1 Rookie
    Oct 9, 2016
    3,434
    SO CAL
    GINO RUGGIERO
    The weight imbalance comes to light on downhill corners, especially off camber , or flat off camber corners, the 308 / 328 s are not going to handle better than a Boxter or Caymen, or newer BMWs. the 3x8 s will go from slight understeer to slight oversteer when cornering hard , so its best to enter a corner slower and then accelerate through the APEX, I know at some point I read this exact verbage (plow ) in some magazine years ago which was featuring an article on our 308 / 328s . Driving a 308 /328 quickly demands a skilled person behind the wheel , same can be said for 911s without 4wd and oh what fun it is gentlemen !!
    Thank you
    derekw likes this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,517
    Cerritos, CA.
  3. dave80gtsi
    dave80gtsi Formula 3
    1,813
    Ohio
    Dave Meredith
    A DIY girly craft store ought to have a variety of stencil letter stamps, but you'll first need to determine what font style and size suits you best.
    Beetleything and miketuason like this.
  4. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
    Thanks Dave I will try Michael’s and see if they have something, as the far as the font, it is exactly like the one on the pic above.
  5. dave80gtsi
    1,813
    Ohio
    Dave Meredith
    Yup, Michael's was just the kind of store that I had in mind, but I was not certain if they were a national chain.
    My reference to 'matching the font' is that a store like that generally has a variety of different stamping kits on the shelf, so it may become a bit of a challenge to exactly find a close enough match to suit you whilst shopping.
    miketuason likes this.
  6. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    .. are you worried about losing points for the wrong font? I would prefer an un-stamped power-coated version over a 40 year old original with perfectly smudged stamps in the correct shade of off-white in the approved font. It is only original once...
    waymar and miketuason like this.
  7. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
    Question, I only see this stamping on the rear right a arm but not on the left rear, should there be one on both side?
  8. 2cam
    2cam Formula Junior
    Aug 28, 2014
    742
    Austin, Texas
    MikeS
    This is a great thread! Has anyone rebuilt their steering rack while they were going through the suspension or replaced the rack bushings?
    2cam
  9. built2grind
    built2grind Formula Junior
    407
    The Peninsula
    ANDREW
    Hey Mike the powder coating looks amazing. As for your stencil, have you tried just playing around with one of those font programs? Once you determine the font like mentioned earlier you can upload it to one of those Cricket machines (also at Micheals) for making stencils. My wife plays around with that stuff when she makes her cakes for her business. Then all you need is to lightly “dab” paint it with a fine sponge. It will look an original as original did......
  10. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,627
    Essex, UK
    Andy M
    I think that rebuilding the steering rack when working on the suspension is the norm.
  11. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
  12. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    153
    Mike,
    Which Ferrari part number is this equivalent to?
  13. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
  14. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    153
    Yes MIke, Gotcha. Thanks.
    dave80gtsi likes this.
  15. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
    waymar and thorn like this.
  16. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    256
    Australia
    Hi Mike, did you also put new inner steel sleeves? do you know, do the inner steel sleeves wear, or is all the wear taken by the bushing? Are these better than the OEM ones that are sold by Ferrari parts suppliers? Cheers, BB
  17. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
    Hi Brock! My original inner sleeves are still good so I’m just replacing the PTFE coated bushings. Normally neither the the bushings nor the inner sleeves get damaged and usually both are reusable, it is just this time the powder coating shop did a poor job masking the bushings and ruined the PTFE coating but no big deal for $2.00 a piece, I just replaced them all.
    waymar likes this.
  18. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    308
    Mid West
    Paul John
    While my front suspension is currently removed, I rebuilt my steering rack on a 1979 308 GTS, and used the CRC Sta-Lube Engine Assembly Grease. If you search, there are a lot of great FerrariChat write-ups on steering rack rebuilds. I like the two below, the second link includes a Pantera write up here, which apparently uses the same steering rack as the 308.
    https://www.ferrarichat.com/forum/threads/steering-rack-rebuild-308.403218/
    https://www.ferrarichat.com/forum/threads/1975-308-gt4-steering-rack-rebuild.407980/
    GordonC and 2cam like this.
  19. 2cam
    2cam Formula Junior
    Aug 28, 2014
    742
    Austin, Texas
    MikeS
    Great threads. Thanks John!
    2cam
  20. mcfarlin
    mcfarlin Karting
    Jun 9, 2008
    137
    Colorado
    Mike McFarlin
    I just did this job myself. I was so happy with the way the front end came out that I’m now doing the rear. I used the energy suspension bushings and had a guy at brakes plus tack weld in the metal outer part of the bushings. Could have used the old ones but I messed a couple up with the sawzall while removing the old rubber. Hint, use a propane torch! I also bought a press at Harbor Freight. Came I. Very handy.
    built2grind, Imatk, jjason981 and 3 others like this.
  21. 2cam
    2cam Formula Junior
    Aug 28, 2014
    742
    Austin, Texas
    MikeS
    Whoops! I meant Paul and wasn't able to edit. Thanks Paul! ;)
    2cam
    ProvaMo likes this.
  22. ProvaMo
    Jun 29, 2004
    308
    Mid West
    Paul John
    Just to highlight the OEM-style bushing tack weld for this thread, see Pictures #9 & #11 of Basal Skull's thread, nicely shows the welds in detail.
    To reinforce an important detail that Basal Skull mentions: When you do final tightening of the main OEM style rubber bushings in the forks, ensure they're in the rested position, with weight on wheels, to preclude inadvertent pre-torque/twisting (apologies if this is basic!)
    Imatk likes this.
  23. miketuason
    Feb 24, 2006
    15,517
    Cerritos, CA.
    Basal Skull likes this.
  24. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    The S is upside down. (Or rather, needs to be.)
