Stud removal tool | FerrariChat
Stud removal tool
Discussion in 'Technical Q&A' started by Dave rocks, Sep 24, 2016.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey guy, I have no experience using a collet type of stud removal tool.
    I'm Looking into a Snap On set. Found this video: http://youtu.be/4IFF_-6xwpE
    Seems just like a 5C collet for machine tools only threaded.
    This looks like a great method.
    Thoughts / comments?
    Thanks.
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    Oh! A stud removal. I thought you meant a Stud removal tool. :D
  3. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Belongs in the BRL ... disgusting.
  4. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    They work well, and you can pick your sizes. Other types will roll the threads and require a cleanup.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #5 Dave rocks, Sep 24, 2016
    Thanks. I see they also have another style which looks handy for areas of reduced clearance.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    I have all variants, roller, collet and the "smash and turn" last resort before it goes to the burn out removal guy. I prefer the collet tool as it saves the threads, but it's not a cheap option. I use the roller set more often as most studs remove easy enough and at least with Ferrari the studs are double ended with a shank so the tool will grab the shank vs the threads and they come out fairly easy.
    Now for install the williams collet works for that as well so it's a dual purpose tool. For the small stuff like M6 I have a small socket tool that's threaded with a pressed in ball bearing at the bottom, installs studs very quickly and you don't have to tighten loosen any collars. Really saves time on the bazillion m6 studs ferrari loves to use.
  7. fatbillybob
    Aug 10, 2002
    28,545
    socal
    #7 fatbillybob, Sep 24, 2016
    Each has its purpose depending on your goal. Left is just double nutting that works if the stud is not really in the workpiece. Then the spec sized collet and its companion to place studs. Finally the roller that has a narrow range of SAE or metric it will except.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you, gentlemen.
  9. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,201
    Georgia
    Wade Williams
    I have the collet style and the roller style. I use the collet style 90% of the time.
    It will take out 14mm wheel studs that are heavily loc-tite bound. They are big and pricey but worth it.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thanks, Wade.
    It appears Snap on is selling Williams made removers. Does anyone know the Williams P/N for the metric set?
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    You know I looked up Williams stud puller sets. The product descriptions on Amazon and two other tool sites don't even state whether it is metric, or standard, and what sizes are included in the sets. The prices are clear to see, more than $300.
    Here is a message to the Williams marketing people: If you don't feel good enough to describe what it is you are selling, I don't feel good enough to buy your stuff. You can stuff it.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #12 Dave rocks, Sep 26, 2016
    Mitch, the one listed on Amazon and other sites is english only (87032). I cannot find a metric set P/N - it may only be offered thru Snap on which is $570 list and I'm told from my rep no discount on that item. Snap on seems to be reducing their discount structure or it's just my rep...
    Also - Williams is now owned by Snap On
    I might just make my own set using 5C emergency collets....
  13. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    So if you are going to make your own, I like a few for myself. I do not need all the sizes, just a few. M8, M10, and M11 is all I need.
  14. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    I had broken Cylinder studs on my Ducati engine and wanted to get a set of metric collets but someone outbid me on a slightly used set on eBay and I just sucked it up and did it the hard way. You may get lucky and find a used set.
  15. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
  17. Speedmade
    Speedmade Formula Junior
    387
    Minneapolis, MN
    Reed H
    #17 Speedmade, Sep 26, 2016
  18. Cribbj
    Cribbj Formula 3
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Wow, 585 area code is typically Rochester NY, 1-1/2 away from me
  20. treue
    treue Formula Junior
    Jan 22, 2004
    290
    Oklahoma
    Tom Treue
    Dave,
    I have a full metric set of the Snap-On CG500 stud removal tool: housing and all the collet sizes for my 330 2+2 which also covers my 430, so far.
    I have absolutely no complaint about the tool. It is probably the least-damaging to studs, which should be re-usable. I also use it to install studs, just a few inch-pounds on steel studs in aluminum parts.
    Three points to remember: 1) the collet thread MUST match the stud threads. Just like a M8x1.0 nut won't fit on a M8x1.25 bolt, the Ferrari M8x1.25 exhaust stud needs an M8x1.25 collet. 2) each collet has a groove that must engage a pin in the ID of the housing or things will not work. 3) I lubricated the contact surfaces (housing-to-collet) and the housing screw threads with anti-seize.
    Tom
    2007 F430F1 Coupé (Izzy)
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thanks, Tom. I understand all of that in full.
  22. fatbillybob
    Aug 10, 2002
    28,545
    socal
    Here is a corollary to this discussion...how much do you tighten studs into the workpiece before you say put on an engine cover or head and torque the bolts?
  23. treue
    Jan 22, 2004
    290
    Oklahoma
    Tom Treue
    FBB,
    Steel studs into aluminum: just a few inch-pounds to make sure the stud bottoms out in the hole. No anti-seize and no threadlocker on the end of the stud that goes into the aluminum. You can put anti-seize on the nut end, if desired. Make sure the hole is cleaned out before installing the stud: I use a chasing tap, compressed air and Q-tip, as necessary.
    Tom
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    When I worked for GM, many studs were fully automated installations (I designed a few) and the fastening was done with IR rundown equipment. I seem to recall some of the threads being coated with a thread locker. I'll hit up my buddy who still works there and see what kind of torque they are using. I just don't recall as it was a long time ago.
  25. fatbillybob
    Aug 10, 2002
    28,545
    socal
    #25 fatbillybob, Sep 27, 2016
    Well I think it is an interesting discussion. I do it toms way which is conventional wisdom as far as I know. I use locker if a stud goes into a water jacket. If using a locker I'm careful to torque critical fasteners before the locker has set to utilize the full desired dynamics of the torque application to the stud and nut. There are some lockers that expand upon anerobic setting. I dont use those since they change forces in the surrounding area. The claim is a stud close to a cylinderwall with expanding locker on a race motor isn't good. True or false I don't know. Just use a nonexpanding locker. I have always put steel studs in ferrari aluminum blocks clean and dry. On acura NSX blocks I use antiseize/anticorrsion because the nsx motor has lame metalurgy where you get galvanic corrsion and your steel eats the threads in the aluminum. The antiseize seems to slow that down. If I have to frequently take off say the case on a hewland racing gearbox I will use locker on the studs so that the nuts always come off vs sometimes the nut staying firm and the stud unscrewing.
