Stuck Caliper piston
Discussion in '308/328' started by Big Daddy, Oct 14, 2009.
  1. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    Albuquerque, NM, USA
    RJ
    The inside piston on the right rear caliper isn't budging. I am soaking it with break free overnight, but if i can't move it in the morning I guess I will have to send the whole caliper out to be rebuilt.
    I did search the old threads and found a few recommendations, but they were all for several years ago. Does anyone know someone good who is still around?
    Thanks.
  2. Jet Lag
    Jet Lag Karting
    Dec 6, 2003
    173
    Seattle
    Robert Bangs
  3. t3thomas
    t3thomas Formula Junior
    May 9, 2008
    427
    North Carolina
    GThomas
    Put a plug in the hole where the line connects then attach a grease gun to the bleed screw and pump it full. The grease will force out even the hardest pistons. The whole thing will have to be flushed with cleaner to get the grease out, but it's a sure fire way to get the piston out without being dangerous.
  4. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Have you looked at the rebuild procedure on Birdman's site? BIRDMANFERRARI.com. Might be helpful
  5. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    mine was a bear to get out as well. soaking in penetrating oil and beating on it with wood and plastic drifts for several days finally worked. lots of cussing was also quite helpful. the rebuild is quite simple. use birdmans' procedure. there are some porsche sites that have valuable info as well. get the parts from superformance in the uk. great price, fast delivery and knowledgeable staff. perseverance furthers
  6. ZiFF
    ZiFF Formula Junior
    Mar 30, 2009
    323
    put it back on the car, hook it up, put a thin piece of wood where the brake pad would go and pump the brakes to push the stuck one out.
    calipers are easy to rebuild. just did one last night, start to finish was about 2 hours, and that includes jacking the car up, taking the wheel off, etc. cost all of $15.
  7. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    Did the same to mine. Right rear. Not a real hard job.
  8. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Yeah, never been beat yet. As advised, bolt it back up and use the hydraulics to push it out with something to fill the gap. If may not fly out, it should just stop coming out once it's past the seal. Of course there'll be fluid all over the place, so cover things up - you could even put it in a carrier bag when you push it out.
    It's fun to rebuild callipers :) but take your time and do it properly with a "clean-room" attitude - an air line helps but use eye protection. I use rubber grease around the dust seal when rebuilding to keep it from going dry and rusting, but check the temp rating of the grease if you are going to drive fast.
    Rear callipers are of course more complicated, but not really any ore difficult.
    Lee
    '77 GT4
  9. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    RJ
    Thanks for the tip on the grease gun because that was the only thing that worked. Cleaning up was messy, but I had to do that anyway. Now I am waiting for the seals kit.
