Struggling with Heater Valve / Heater Control Testing. Super stumped. | Page 4 | FerrariChat
Discussion in 'Mondial' started by Albert Penello, Mar 10, 2020.
  1. Albert Penello
    Albert Penello Karting
    Jul 21, 2019
    165
    Woodinviille, WA
    Albert J Penello, Jr.
    Afterburner what test would you suggest? Is there another way to confirm the buttons are working properly other than what I just did?
  2. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Did you test directly at the unit = eliminating any other wiring issue?
  3. Steve Magnusson
    27,000
    No. When any of the pushbuttons is pressed (other than STOP) only one electrical thing happens -- the GV wire at the pushbutton unit is connected to ground. This turns "on" the interior fan system whose operation is completely independent from the HVAC ECU and the heater valve relay.
  4. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    Yikes. So it's strange that in my car, the AC Button acts the same as Stop. What could be causing this?
  5. Steve Magnusson
    27,000
    You might have some other internal problem, but this video from Norwood shows the phenolic "sliders" inside the switch can break and need replacement:
    Does the "feel" of your A/C button seem a lot different than the other buttons?
  6. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    It doesn't - the whole system is feeling dry.
    Funny story, I took the car out for a drive and the AC button was pressed and the light was ON with no fan. Then, suddenly, the light went OFF and the fan turned on.
    A lot of things on this car are coming back as I drive it.
    Once I get the HVAC ECU sorted, I'll spend time on the button unit. It shouldn't affect the ability to get the heater and AC diagnosed I don't think.
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Albert, the switch in the push button unit is easy to bypass. Just disconnect it and add a temporary switch instead with 2 wires.
    The you have no questions about it while diagnosing the rest.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,019
    Isle of man- uk
    That is a neat fix
    Albert Penello likes this.
  9. Steve Magnusson
    27,000
    Agree -- my only minor criticism would be that bare aluminum "sliding" against bare aluminum maybe isn't so good, but once the modification is made to make it able to be disassembled that makes it much more serviceable, if necessary, and they may last a long time anyway as this is not a high-cycle situation. Since the sliders are water jet cut that would give an almost unlimited option for the slider material (assuming the right thickness material can be obtained), and there may be more modern plastics with much better strength and toughness than the original phenolic but with better frictional properties than the aluminum. Or an alternating slider stack of aluminum-modern plastic-aluminum-modern plastic...to not have any metal-to-metal sliding. Just some random thoughts that a good modification can evolve as new materials become available...
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,019
    Isle of man- uk
    If you could understand how it works, there must be a more modern way to do the same with the 3 buttons. I was following this thread on the fix but it was getting more complicated than my knowledge.
  11. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I notice that video is about 9 years old. I wonder if they are still performing this service.
  12. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    Ditto!
  13. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    Well, everything is now in working order for those following along. The A/C button is now working as expected (from pressing the button a lot!) and more importantly the heater knob is working great! (there is no AC as the unit is empty, but that's another story)
    My friend was able to diagnose the unit, create a full schematic, and recreate all the inputs on a bench. Once he replaced the OPAMP chip, all is working well.
    Funny story - the OPAMP chip he replaced it with was date coded 1984, so actually period correct! He had that part in his stash which he thinks he bought in college!
    One last note from a diagnosis perspective - the signal from the heater pot is relative to the signal coming from the interior temperature sensor. So although you might expect the light to blink all throughout the range, turning OFF at full heat and ON at full cold, that won't necessarily be the case. We noticed as the car warmed up (and the interior became more warm) the blinking ON and OFF would change at different times across the range. It's also pretty slow to respond so you have to give it a second.
    Lastly thanks again everyone for the help. My friend is going to list all the Part Numbers for each of the components within the schematic, and then I'm going to release the complete schematic to the forum. Perhaps Urs can add this to his already fantastic wiring diagram for future reference. My buddy believes that a skilled electronic hobbyist should be able to to recreate this entire unit from off-the-shelf parts vs. spending hundreds (or thousands) for a new unit. Maybe that can help future owners.
    Thanks again everyone for the help!
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Thanks for the update Albert - nice to hear things are working out.
    I would very happy to include the ecu schematics and parts list into my diagrams, which I am sure will help other owners having their car's HVAC perform as intended.
  15. ronfrohock
    ronfrohock F1 Rookie
    4,184
    MA
    Ron Frohock
    That’s awesome! And it’s also so nice to see the greater Mondial brotherhood band together to help you out.
  16. Cafe racer
    Cafe racer Rookie
    Mar 22, 2020
    24
    London
    Nigel Waterfall
    Does anyone have a wiring diagram for the heater/AC system - my wiring is a real mess in the centre console & i suspect there's a few wires missing, especially on the switch for AC/Heat.
    I have a workshop manual, it has everything except what i need, if anyone has any pictures or info it would be a great help, the temperature sensing seems to work as i can hear relays operating when i move the temperature control, the fan speed switch is operating the relay in the footwell but the fan doesn't run (guess that's the transistor?)
    Any information (especially drawings) would be great
  17. Albert Penello
    Jul 21, 2019
    165
    Woodinviille, WA
    PM Urs (afterburner above). He sells a color PDF that is absolutely mandatory to deal with electrical issues.
    Cafe racer likes this.
  18. Jbar2002
    Jbar2002 Karting
    79
    John Barhydt
    Rookie question: I see that this thread is specific to the Mondial, but I have a 1994 512TR and the push button setting for cooled external air (button 3) doesn't seem to be working. I was comparing the wiring diagram in my workshop manual with the diagrams in this thread, and they appear to be similar if not the same. I'm wondering if the HVAC system is shared across the different models from the 80s and 90s. Thanks.
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The air distribution is vacuum controlled, so if your "button" isn't working it's more likely a vacuum actuator that's leaking. The only electrical function of the unit is a "On" (powering up the HVAC ecu) when any other than the "OFF" button is pressed.
  20. Jbar2002
    Jbar2002 Karting
    79
    John Barhydt
  21. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    You're welcome
  22. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    The push button switch itself is a nightmare of Italian engineering, especially at this age. Pushing the buttons moves phenolic sliders back and forth for operation, and it’s not unusual for them to fall apart. Used to be a guy who rebuilt them by water jet cutting new metal sliders, but he quit doing it. If another cure is available, I’m all ears.
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Howard you're right, it could be the a leak or failed actuator in the push button unit as well. I will open up my spare one sometime and have a look at mechanism to see how I could reproduce them.
  24. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I have pulled two apart and both had torn sliders. I attempted remaking them in a styrene type plastic but that didn’t hold up either. I found the last NOS one on the planet, and about 48 hrs after install it was starting to hang up also. Age has just caught up with this flimsy( at best) design.
  25. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Did you take any photos of the internals?
