Stratos induction system on 246GT | Page 10 | FerrariChat
Discussion in '206/246' started by Pantdino, Aug 28, 2005.
  1. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    interesting, I just finished an article on 246's and it mentioned 400hp on thr stratus and was about to contact german dino for more info
    clay
  2. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    148
    Los Angeles
    Jim Oddie
    Beautiful, Freeman.
    I suspect there would be a market for these, as they let the intake roar thru while not requiring any body metal change.
    Would Simon be interested in making more of them, now that the hard work of making the prototype has been done?
    Jim Oddie
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #228 4CamGT, Nov 20, 2016
    Jim,
    Maybe once he's finished his. I just installed the 16mm velocity stacks I special ordered from Webcon in the UK. I can feel an improvement in throttle response. I love the way my Dino is driving! The sound is like a Ferrari F2! Here's what it looks like inside the air box.
    Freeman
  4. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #229 4CamGT, Nov 20, 2016
  5. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #230 4CamGT, Nov 20, 2016
  6. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    148
    Los Angeles
    Jim Oddie
    #231 Pantdino4, Nov 21, 2016
    How many mm clearance does that give between the top of the stacks and the cover?
    PS- you can remove that big, stock filter box and hose now, for a cleaner, more classic look :)
    Jim
  7. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #232 4CamGT, Nov 21, 2016
    Jim,
    I have a total of 27mm from the base plate to the top inside of the air box. I could have more if I gave the top more crown. Part of why I think it works so well is because we lowered the base plate around the carb assembly and use a full size filter. This gives a lot of air flow and creates a ram effect. I also gave it extra space between the top and inside of the deck lid for over slam. So far it works really well w/o trumpets and with the trumpets you can feel a slightly better response. Next step is to experiment with "stubstacks" which are really short stacks/plates like what the Stratos box has.
    Yes, I'm planning on removing the air filter canister assembly. It'll open up a lot of room as you've mentioned.
    Freeman
    P.S. Early in this thread there's were some others that mentioned they had installed IDF's in Dinos. It would be of interest to see and hear about their developments.
  8. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #233 4CamGT, Nov 22, 2016
    Here are the prototype mushroom shaped "stubstacks" we created. Seems to flow well. Initial tests show great promise! These are high heat resin. We're looking at making them out of aluminum.
    Freeman
  9. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #234 4CamGT, Nov 22, 2016
  10. rbsloan11
    rbsloan11 Karting
    Apr 25, 2007
    117
    Carmel
    Rob
    Freeman - I would love to see/hear a video of the engine running. Great job!
    Rob
  11. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    148
    Los Angeles
    Jim Oddie
  12. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #237 4CamGT, Nov 22, 2016
    At some point I'd love to do a video of driving and capturing the sound. The sound is glorious from inside the cabin!
    Freeman
  13. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #238 4CamGT, Nov 22, 2016
  14. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
  15. rosso corsa motorsport
    rosso corsa motorsport Formula Junior
    Nov 30, 2008
    268
    i can try download the sound tomorrow to youtube full trottle to 8000 revs on each gear and very fast gearshifting
  16. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    Fantastic! I'd love to see more of your development! Does your gearbox have the Colotti straight cut gears? Anything you can share would be appreciated.
    Freeman
  17. Telaio
    Telaio Karting
    Jan 11, 2006
    206
    Kevin O'Rourke
    Love the way you solved the height problem by dropping the air-box down, very clever and quite ingenious !!!! great stuff, cheers Kev.
  18. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    Kevin,
    It was the result of a lot of brainstorming and mock-ups with Simon. We really wanted to use the Stratos/308 filter element. By limiting ourselves to no modifications to the deck lid, it forced us to be creative!
    Freeman
  19. rosso corsa motorsport
    Nov 30, 2008
    268
    tomas
    i can not upload file i need to ask the master for that, it must be something wrong with internet!!!!!
    standard gearbox i did buy from dennis Mccan 44IDF stratos carbs, the car have been very fast side by side with Nicklas 308 328, and a 355 up to 3 gear, in the tail on a 458 he he very very different from a standard dino to drive maasive brakes and differnt suspension
  20. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #245 4CamGT, Nov 24, 2016
    Do you have any photos of your car and the engine? The NOS Stratos carb setup I have, also originally came from Dennis McCann.
    Freeman
  21. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    #246 4CamGT, Nov 24, 2016
  22. rosso corsa motorsport
    Nov 30, 2008
    268
    I'll look up pictures as soon as I have time, i am doing one engine with this carbs right now for a customer on F chat test driving next week hopefully, you found the NOS carburetors, this is very hard to find, I do not think you can find another set for sale, Ferrari would have assembled them from the beginning, dcnf carburetor is pure crap to use on a Dino
  23. racerboy9
    racerboy9 Formula 3
    2,499
    Must be sold as the like is now dead!
  24. racerboy9
    racerboy9 Formula 3
    2,499
    Well, it still shows up as available on the Ebay site.
