Strangest thing you ever found to puncture a tire | FerrariChat
Discussion in 'Technical Q&A' started by james patterson, Jun 4, 2008.
  1. james patterson
    james patterson Formula Junior
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    Today a car cam in with a tire puncture. It looked like it had a large, 5/8" diameter concrete lug stuck in it. When I pulled the tire off the car and went to pull it out I noticed the thing reeked of pot - the kind folks smoke. The thing cam apart while pulling it out and appears to be part of a dope pipe and has left a 1/2" hole in the tire. Anyway I have seen all kinds of nails, screws, staples, tacks, glass etc. put holes in tires but this is hands down the strangest find for me.
    Thought it would be interesting to see what other oddities everyone else has found to cause flats for them.
  2. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    James, you need to get the holes in your trouser pockets sewn up ;-)
  3. james patterson
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    I will look into that.
    Much thanks.
  4. Whisky
    Whisky Three Time F1 World Champ
    30,688
    In the flight path to Offutt
    The original Fernando
    spark plug in one of my tires about 25 years ago.
    not my spark plug.
  5. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,867
    Wellington, FL
    Duane
    Coathanger thru the sidewall about 15 years ago.
  6. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I had a 1981 Mercedes Benz 300D Sedan. A headlight went out, so I bought one at the auto parts and put it in.
    The next morning, as I drove away, a sudden bang, followed by a long screech from the left front tire -- the phillips head screwdriver that I had used had bounced off the front bumper, and perfectly speared through the middle of my tire. It actually stopped the wheel from rolling due to the handle.
    But I cannot match the bong.
  7. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,554
    NY/SC
    David
    5mm allen wrench in a motorcycle tire picked up in the paddock during a track event.
  8. chris marsh
    chris marsh F1 Veteran
    5,742
    Detroit
    Chris Marsh
    Once had a 1/2" diameter bolt that was 5" long. How it made it's way into the tire I don't know, you'd think anything that large would have to be laying down and not sticking up.
  9. Ferrari328GT
    Ferrari328GT Karting
    Jan 6, 2008
    232
    Phoenix, Arizona
    Steve
    Same thing happened to me with a 1/2" drill bit. I asked a Goodyear tire rep how that was possible. He said "It was a rear tire, wasn't it?". It was. He said it is common for the front tire to kick it up and hit the rear tire just wrong. OK, so was yours the rear tire? -Steve p.s. I still use the drill bit.
  10. jk0001
    jk0001 F1 Veteran
    Oct 18, 2005
    6,706
    Sun Coast
    Jim
    Eye glasses,!!! I never remembered running anyone over
  11. Lemke
    Lemke F1 Rookie
    Oct 27, 2004
    4,644
    Vancouver, WA
    Daniel
    Well at least there wasnt a head attached to the glasses.
  12. velocedog
    velocedog Karting
    Jun 6, 2007
    119
    Michigan
    Jack
    My wife once had the "S" hook from the end of one of those trucker type bungies puncture through the tread and then out the sidewall.
  13. DrStranglove
    DrStranglove FChat Assassin
    30,983
    Google Maps
    DrS
    Bullet head from a .308. I don't remember noticing if anyone was shooting at me but I guess they were! :(
  14. duskybird
    duskybird F1 World Champ
    12,529
    29 Electoral Votes
    Bill B.
    Here or Iraq? :D
  15. Llenroc
    Llenroc F1 Veteran
    5,420
    Colorado
    Vern
    I know this will be off topic a bit but here goes.. I have a friend that veered off the road just enough to catch a metal post(one of those green fence posts) that held a reflector on the top of it, anyway it acted like a spear and went into the tire and then thru the top of the fender it was the damnest thing I have ever seen.
  16. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I had a rock go through a cheap tire that Ford puts on their pick ups. I had pulled off to the side of a gravel road for a moment. When I started up and left I was only doing about 10 MPH and the tire was flat. I was up set. It was cold and raining to boot. Now I have a set of ten ply tires on the Ford.
    Bob Wassam
  17. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    1994 F250 coming up the alcan on the OEM tires - - - EXACT same thing. I was astonished that gravel (not sharp - just a regular old piece of rounded off rock) would punture an 80psi tire!
    Rgds,
    Vince
  18. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    In the late 60's and early 70's, I owned a few Firestone stores. The weirdest was a human tooth that puntured a tyre; I always wondered about that one! Another was a flat caused by a Bic Pen, and the pen still wrote!
  19. Ferrari328GT
    Jan 6, 2008
    232
    Phoenix, Arizona
    Steve
    Also, slightly off topic, but funny. A friend of mine about 30 years ago hit a deer, just sort of busted up the front grille and headlight, no big deal. A month later, the battery went dead. When I removed it, I found an antler sticking into the bottom of the battery, and had drained all the acid out of one cell. I removed the antler, put some black RTV in the hole, and filled the cell with water. Took it back to Sears, and got it warranteed :). -Steve
  20. f355spider
    f355spider F1 World Champ
    18,027
    Friend of mine had a spark plug through a tire. He saved it like a charm and had it hanging from his rear view mirror in college.
    I once had the broken end of a Craftsman box end wrench go through my tire...I was going to take it to Sears and see if they would give me a free replacement...but didn't have the nuts to do it. ;) I carried that wrench in my glove box for 3 years, thinking I would drop in and exchange it...but never got around to it.
    I also once had the hook end of one of those giant nylon straps used on semi-trailers go through the side wall of a tire...instant blow out!
  21. DrStranglove
    30,983
    Google Maps
    DrS
    Va surprisingly enough!
  22. JohnLClark
    JohnLClark Karting
    May 15, 2005
    188
    Pittsburgh
    #22 JohnLClark, Jun 5, 2008
    I once had a part of a metal fork stuck in my rear tire. Lucky for me, I caught it before it punctured the tire. Never did figure out, where it came from.
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,559
    The twilight zone
    The Butcher
    I found what looked like a piece of a bullet, maybe from a .22.......driving along in rual upstate NY.
    We had somebody shoot the house too, thorough the wall, broke a picture hanging there and stuck in a beam in the ceiling. The police said there were several similar reports, appearently someone was driving around shooting houses. Again rual upstate NY.
  24. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Long ago I worked at a Goodyear store as a tireman, we saw all kinds of things that caused flats.
    The strangest one that comes to mind is a pair of tire weight pliers that some tireman left inside the tire and was poking through the sidewall. Bet he wonders where he left those!
    Occasionally some one would bring in a flat tire, I'd open the tire up and find someone had plugged a tire with a tube in it....or they would bring in a tire they had repaired with FIX A FLAT......what a mess in side.
  25. ryalex
    Aug 6, 2003
    25,726
    Las Vegas, NV
    Ryan Alexander
    I had a small segment of Rebar puncture my last replaced tire.
