Strange rattling at 1600 RPMs | FerrariChat
Discussion in 'California/Portofino/Roma' started by GNU, Sep 29, 2020.
  1. GNU
    GNU Rookie
    Sep 28, 2014
    27
    I’ve got a 2012 California that is due for its 20k service that has developed a rattling metallic sound from underneath somewhere every time it’s been run warm and passes 1600 RPM.
    No noise at all at any other RPMs.
    No noise when revving past that RPM in neutral.
    Does anyone have any idea of what could be causing the rattle?
    I’m thinking a lose heat shield for the exhaust would make noise at other RPMs too?!
  2. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    Engine mounts going bad?
    T
    russellmcg likes this.
  3. GNU
    GNU Rookie
    Sep 28, 2014
    27
    Thanks!
    I think you could be right.
    It’s been 2 years since I swapped them and I have been feeling the vibrations slowly coming back so I think it’s time to replace them again.
    I’ll report back with findings after I swapped them out.
  4. tomc
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    Hmm. If it's been 2 years, how many miles since then?
    T
  5. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
  6. Sammi
    Sammi Karting
    Aug 8, 2020
    102
    Las Vegas
    Samantha (Sammi)
    Had a similar issue recently, it was the engine mounts. Had them replaced and now completely smooth.
  7. tomc
    Apr 13, 2014
    25,892
    DFW, Texas
    Tom C
    That's right. Could not recall where I saw it. Thanks.
    You also were able to save a few $$$ by shopping around dealer and independents, no?
    T
    Sammi likes this.
  8. Sammi
    Sammi Karting
    Aug 8, 2020
    102
    Las Vegas
    Samantha (Sammi)
    It ended up being approx ~$1400 with parts and labor. I went to a local service shop that specializes in Exotics rather than through a Ferrari dealership directly. The parts were ordered from Scuderia.
    tomc and BLAMPEE like this.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    It sounds like one or both of the exhaust damping weights has separated and is vibrating. They are large rubber cylinders (about the size of skateboard wheels) that are bonded to a metal mount which is bolted to the middle of the exhaust system. They change the harmonic frequency of the exhaust system in order to reduce noise/vibration. With time the rubber comes un-bonded from the metal mount, and they make a rattle at a specific RPM.
    You can see if they are loose and remove them from the exhaust to see if the noise goes away. They are on the pricey side (part# 252174, $200 each).
    Brian Brown
    San Francisco Motorsports
    tomc, Patricia2020 and GNU like this.
  10. Mafiaboy1975
    Mafiaboy1975 Formula Junior
    Aug 10, 2019
    258
    South Africa
    Mick
    I had a buzz at 2800 rpm. Swore it was the exhaust heat shields. Fiddled until blue in the face no luck. Then my kids hopped in the back and the buzz was gone. Turns out it was a seatbelt clip... damn did I spend time under that car looking for a buzzing heat shield. ... oh well. It at least it’s gone now. Lol
    GNU likes this.
