Step by Step Blinker Fluid Change Procedure | FerrariChat
Discussion in 'Technical Q&A' started by Ksullender, Jan 26, 2009.
  1. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    887
  2. Ksullender
    Sep 3, 2003
    887
    Make sure you check your owners manual for the proper amount required for the refill.
  3. tazandjan
    39,007
    Ken- Would you please subscribe? We could use you in the silver and rossa forums.
    Taz
    Terry Phillips
  4. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Factory quality blinker fluid should be changed every 150,000 blinks but when the blink counter jams you're looking a major bux. And big trouble if the left blinker is used more than the right as the blinker balancer adjustment requires an expensive tool. According to the manual, if right blinks exceed left it's ok unless the fluid is dirty or revs exceed 7k for more than 2 parasecs.
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    My counter is broken so I need to change the fluid every other 3rd year. I do have a problem with my electrical harness leaking smoke once in a while. But I have been using this after market smoke sealant to solve the problem. It is made by 3M and you can get it in colors to match your car.
  6. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    I changed my blinker fluid in my Audi only a few weeks ago. Apparently BMW driver's never need their fluid changed. A local garage recently had a 1988 3-Series in for a service and the blinker fluid was as good as new.
  7. Ksullender
    Sep 3, 2003
    887
    I'm not sure, but I think if you don't change your blinker fluid it will trip a code or check engine light.
  8. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Yes, often non-BMW factory trained mechanics will overlook carefully measuring out no blinker fluid then adding in the correct manner.
    A certified BMW service center with the correct factory tool to measure exactly that correct amount is essential to smooth running. In fact, not carefully adding none will breach your warranty.
  9. UroTrash
    Jan 20, 2004
    40,198
    Purgatory
    Clifford Gunboat
    Question.
    Since my wife has stopped using her blinker all together and instead utilizes the cell phone from garage-door-up to garage-door-down, must I still change the blinker fluid?
    In other words, is there a mileage limit independent from the 150k blinks limit?
  10. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    My understanding is you can pay a little more for the synthetic Blinker fluid, which helps to keeps the blinks at
    a much faster rate when its below 30F out. Probably not a bad idea during the winter months to swap to the
    synthetic stuff at the same time you are getting your wiper blades sharpened.
    BobR
  11. Derek Trotter
    1,790
    Cambridge, UK
    Yes, I too had mine sharpened just before the winter. I now have a disclaimer sticker on my "A" pillar warning the car wash boys that I accept no responsibility if they injure themselves whilst cleaning my car. You can't be too careful nowadays, what with the no-win, no-fee ambulance chasers out there.
  12. SonomaRik
    SonomaRik F1 Veteran
    #13 SonomaRik, Jan 27, 2009
    is it like mine: Title:Windshield wiper sharpener Document Type and Number:United States Patent 3886657 http://www.freepatentsonline.com/3886657.html
    if you are not using the correct tool, you will ruin the katana edge...just a warning mind you but, well, you've been warned.
    BTW, works best when strapped down using my yard of shore-line
    rik
  13. Steve King
    Feb 15, 2001
    4,367
    NY
    There is a repair kit for this. It is a package that contains a pair of sissors and a small roll of check engine light (black electrical) tape. There are instructions on how to make the repair. Good luck
  14. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Common problem on most Lexus, Volvo and SUV models, as well...
  15. elipinski
    elipinski Formula 3
    May 14, 2006
    1,390
    Emanuel
    Excuse me, but may i ask the forum, what for a blinker nedds fluid? thanx
  16. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,572
    Gates Mills, Ohio
    Jon
    Welcome!
    (Don't take this thread too seriously. ;) Blinkers don't need fluid. It's not like changing out your exhaust air freshener, which is actually important.)
  17. thecarreaper
    thecarreaper F1 World Champ
    17,957
    Savannah
  18. lilturbododge
    lilturbododge Karting
    Jul 7, 2008
    152
    SC
    Justin
    Maybe this is why I keep getting the middle finger when I change lanes...need to replace my blinker fluid!! Thanks for helping me out!!
  19. bill brooks
    bill brooks F1 Veteran
    BANNED Silver Subscribed
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
    i restored a 1935 olds 6 which had only 1 blinker on the driver's side.
    the ruby glass lens was unobtainium if you broke it. the real mccoy came in a yellow box!
  20. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    The last time I changed the blinker fluid in the 308, I read the fine print on the bottle. It said that if you change your blinker fluid yearly, it will extend the life of timing belts indefinitely. Now, I know the reference on the bottle was primarily intended for Japanese imports, but I see no reason why it wouldn't work on Ferraris as well. Think of it, you might never have to change a timing belt again!!
  21. bill brooks
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
    ah ha!!
    if you'd read the even finer print you will have noted that it does not prevent premature seizure of tensioner bearings
    peculiar to ferraris.
  22. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    Wow, I can't believe the difference a simple change of fluid could have on my blinkers. If fact, I'm going to try some in the flux-capacitor this weekend to see what impact it might have on that too.
  23. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    No No No.....the finer print mentioned using the fluid on the muffler bearings to keep them from seizing
  24. Dino355
    Dino355 Rookie
    Nov 5, 2007
    44
    Wimbledon England
    Dean
    With respect I am quite sure you understood exactly what I did not mean...
