458 - Steering Wheel Disassembly | FerrariChat
458 Steering Wheel Disassembly
Discussion in '458 Italia/488/F8' started by SirJImothy, Apr 27, 2021.
  1. SirJImothy
    SirJImothy Rookie
    Mar 9, 2021
    2
    James Coffman
    Can anyone offer any advice on disassembling the turn signal indicators for sticky finish repair? I removed the two T25 torx screws and the airbag, but I at a loss on what to do next. The metal faceplate does not want to come off. I can’t make sense of it.
    Thanks in advance!
  2. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    549
    Did you figure this out? The only information I've found is to pull really really hard, but man it is stuck on there!
  3. FFan5
    Jul 7, 2018
    549
    For those that find this in the future. I put my hands around the back of the assembly and front of the plate, braced myself on the brake and pulled hard. The whole unit then broke free. Do not pull just the plate, the whole unit needs to be pulled.
    F8Spider and Melvok like this.
  4. SeattleStew
    SeattleStew Formula 3
    1,017
    In the rain
    Stew
    You can also get steering wheel removal tools that are designed for removal. But yanking hard on it is also the usual method.
  5. Fanaticrom
    Fanaticrom Rookie
    Mar 27, 2021
    17
    Romania
    I was wondering about the same thing. I just want to replace the bumpy road (suspension adjustment) button, but I don't know if I want the hassle to disconnect battery, remove airbag etc. :confused:
  6. FFan5
    Jul 7, 2018
    549
    The turn signals, flasher and windshield wiper buttons were easy to remove. I gave up on figuring out how to get the bumpy road switch out. I probably could have sent the whole assembly to StickRX, but as my bumpy road button wasn't showing any signs of being sticky yet, I gave up.
  7. montegoblue
    montegoblue Formula Junior
    572
    East TN
    Any DIY on this thread for turn signal removal? Wanna send them for sticky repair. Thanks
  8. jsh458ft
    jsh458ft Formula Junior
    365
    PA
    I believe all of the refinishers prefer you just send the central wheel piece as one assembly.
  9. FFan5
    Jul 7, 2018
    549
    The only thing that was not obvious is after you unscrew the screws and remove the airbag, you have to pull hard enough to break two rubber pieces holding the steering wheel dash in place. I couldn't get it to come out, called my indy and he was just like "put your foot on the brake to brace yourself, and then pull gently, but hard until it dislodges.".
    If you try this, be sure to pull by the back, not the carbon fiber bit.
  10. dom1172
    dom1172 Karting
    152
    Sarasota, FL
    Dom
    I know this is an old thread but once you “break” those two rubber pieces, don’t they have to be replaced when you reassemble? How did you handle that? Thanks!
  11. FFan5
    Jul 7, 2018
    549
    Correct, I didn't have to replace them, the bolts on the sides hold the button cluster in plenty tight.
    I never figured out how to disassemble the bumpy road button, but it wasn't sticky yet, so I just did the turn signals and whatever else I could get removed. Be sure to take a lot of photos, as it'll be two months before your refinished buttons come back and you are likely to forget how the puzzle went.
    Very happy with the result.
