stat o seal | FerrariChat
stat o seal
Discussion in '308/328' started by lostbowl, Apr 2, 2011.
  1. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Looking for 6mm stat o seals and all that comes up on the net are fractional. Anyone know where? thanks Lost
  2. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
  3. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,335
    Encino, Ca
    Carl T
    Pegasus racing will have what you're looking for
  4. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    To quote from that McMaster page:
    If memory serves me right with the engine/tranny oil pans, where the washer sits, aren't the shanks of the stud not far up enough in the hole (and therefore the stat-o-seal will compress on threads and not the shank of the stud)?...
  5. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    #5 lostbowl, Apr 3, 2011
    Thanks for the info! I hope to rectify this problem with the sealing washers. I tried nylocs and thye didn't do the job.
    As far as working against the threads------------- Dave Helms reccomended them and I have no doubt his knowledge on F-cars exceeds mine by light years and that is why I am looking for them. lost
  6. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    I need to fix a tranny pan leak as well and this will be the third time in over ten years I've replaced this gasket. I've always stuck with the same original plain washers/nuts and had considered replacing them with some sort of sealing washer. But upon reading the description in the catalog, that's what triggered a memory of seeing threads and not shank when doing the pan in years past...
    I'll try them too and see if it does the trick.
  7. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    In my search for 6mm stat-o-seals I found a company by the name of Parker that sells a specific washer that seals on the threads and not the shank. Now I need to know where to buy them. If anyone knows please sound off. Lost
