Starting question | FerrariChat
Starting question
Discussion in 'Mondial' started by syata, Apr 4, 2019.
  1. syata
    syata Formula Junior
    Feb 23, 2017
    428
    I have a 1988 Mondial CAB with ABS. When I bought the car the previous owner said to start the car I should dirt leave the ignition key in the first position and wait until the ABs light and other lights go off.
    Is this the correct process to start the car or do I turn the key until it starts then release the key? Kind of strange to wait 10 seconds or more to start the car each time.
    Thank you fir your input.
  2. 88MONDIAL
    88MONDIAL Formula 3
    Apr 13, 2005
    1,052
    Racine, Wisconsin
    Jim Smith
    He is correct. I put the key in and turn it to position 1, lights come on the dash,I buckle up and put the car in neutral (so 4-5 seconds), this supposedly "energizes" the circuitry on these old cars - then I simply turn the key the rest of the way to start the car. Think of it as something cool.......it's a starting procedure that is different than all the other cars out there. You don't have to do all this say if you just drove the car, starting again at a gas station or something...
  3. syata
    Feb 23, 2017
    428
  4. mustbenuts
    mustbenuts Karting
    May 14, 2017
    70
    Lancaster, PA USA
    GR
    yep. The glow plugs have to get energized... :)
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,584
    Menlo Park, CA
    Paul Chua
    I do this as well.
    ronfrohock likes this.
  6. ronfrohock
    ronfrohock F1 Rookie
    4,175
    MA
    Ron Frohock
  7. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,104
    PB County, Florida
    Jerry
    If nothing else, it helps the fuel pressure build up for those couple of seconds that you wait.
    Regards,
    Jerry
    Cadillacbart likes this.
