!st to 3rd gear? | FerrariChat
!st to 3rd gear?
Discussion in 'Mondial' started by kitreid, Jun 28, 2016.
  1. kitreid
    kitreid Karting
    Feb 7, 2012
    105
    Australia
    Kris
    Surely this has been discussed before, and I apologise if it has.
    I know to do it, however....why?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Until the gearbox warms up you will find 2nd gear a bit stiff. Book says 80/90 oil but 75/90 makes the change a bit easier
  3. kitreid
    kitreid Karting
    Feb 7, 2012
    105
    Australia
    Kris
    oh, ok...thanks mate....I recently did have it serviced, and its not bad really....just needs an extra nudge until warm like you say.....interesting
  4. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    1St-3rd-5th......if I'm not in a hurry or a race... Same with the Countach
  5. kitreid
    kitreid Karting
    Feb 7, 2012
    105
    Australia
    Kris
    I find, my Mondial doesn't need 2nd.....I don't use it until car is up and running well into the drive....sometimes never use it
  6. Alden
    Alden F1 Rookie
    2,913
    Central Florida
    +1, same for me. But I do go to second when I have to go slow and always keep it out of 1st as long as I am moving, even a little.
    Alden
  7. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    The 2nd gear synchronizer seems to either be weak or just take a lot of wear, so if you occasionally skip 2nd, voila, less use means longer before it needs replacement.
  8. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    the whole 1-3 gear change is really overblown. I wait 5-10 minutes - smooth as butter...
    you have to wait 5-10 minutes anyway to let the engine warm up so you can rev to 7,500 - so it's not a big deal at all.
    Just meets a the quota for 'negatives' when a automotive journalists sits down to tabulate things on the 'con' column.
    Cheers
  9. kitreid
    kitreid Karting
    Feb 7, 2012
    105
    Australia
    Kris
    Yep, my thoughts exactly....in fact, anything on the car that I can get away with not using, I will, especially if its electrical
  10. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    The Netherlands - NH
    Tijn
    #10 MvT, Jun 29, 2016
    Wrong thoughts :) its not the sychronyzer.
    when your transmission is warmed up (10-15min) and you can shift into second gear.. It is not your sychronyzer, but the oil that cannot get away from the second gear shaft that that goes into the transmission case. There is also a resolution for that, but you would need to bolt the transmission off.
    and redline will not fix it..
    Example of the MOD. A hole drilled so that transmission oil can escape when going into second gear when cold.
    The second pic shows a radical solution of drilling from the outside..
  11. Bell Bloke
    Dec 6, 2012
    1,839
    Nice one MvT
  12. TheMac
    TheMac Formula Junior
    Sep 5, 2009
    452
    Alberta
    Jon Mac
    This makes so much more sense to me than the weak synchro explanation. Thanks for posting.
  13. kitreid
    kitreid Karting
    Feb 7, 2012
    105
    Australia
    Kris
    Awesome....that makes a heap of sence
  14. redlightrich
    redlightrich Karting
    Jul 28, 2009
    98
    north New Jersey USA
    Rich
    I wonder if this is the same for a 1989 Mondial T. It makes all the sense in the world. If it were a "weak syncro", the issue would be there hot and cold.
    Amazing that the Fcar engineers or designers of the trans missed this?
    Thank you for the important information
    Rich
  15. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,096
    PB County, Florida
    Jerry
    If my car is any indication, same with the t. It is the same issue from what I have read. Using Redline tranny fluid helps some, but did not cure the problem. And I am not in a cold climate.
    1st to 3rd at about 3500 rpm is not a problem. Usually by the time the oil temp gauge starts to move, the 1-2 shift is fine. I always rev match on the downshift, so that is not a problem.
    Regards,
    Jerry
  16. motomike8
    motomike8 Karting
    Jan 7, 2015
    60
    Phoenix, AZ
    It's also worth noting here that if your clutch is worn, stiff 2nd will be much more noticeable. Also, rather than going to 3rd you can also just double clutch between first and second and voila. Works every time and after two or three times the trans will be warmed up anyway.
  17. kitreid
    kitreid Karting
    Feb 7, 2012
    105
    Australia
    Kris
    Thank you all....that was very educational. I was thinking about this thread today while out in the car....mine very happily goes from 1st to 3rd....ill change down into 2nd once I see the temp gauge go up a bit
