Hey Guys I am in the process of getting my spider top to work correctly - currently trying to get the old fluid flushed out and the will start the process of checking the pots/microswitches/etc... However, when removing the main hydraulic piston, I had to sacrifice 2 bushings that hold the piston in place (Ferrari Part No 64661900). Ricambi shows these as unavailable. Anyone run into this issue before? My piston was frozen in place - the bolts/bushings/pistons were not moving (took WAY too much force after WD40/penetrating oil used) to get the bolt out! I need two of the plastic bushings seen in the picture below: Suggestions? Image Unavailable, Please Login
