Speedometer ring | FerrariChat
Speedometer ring
Discussion in '308/328' started by Lefti31, Feb 20, 2021.
  1. Lefti31
    Lefti31 Rookie
    Oct 8, 2020
    8
    Germany
    Detlef Müller
    Hi. Does anyone have a solution for the speedometer rings? The previous owner ruined mine. Can i still buy this rings somewhere?
    By the way - can anybody explain me how to remove the pointer from speedometer?
    Thank you Image Unavailable, Please Login
    Sent from my SM-N975F using FerrariChat.com mobile app
    janmante likes this.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Is that a bezel around the outside ? As their specialist companies who fix these
  3. Lefti31
    Lefti31 Rookie
    Oct 8, 2020
    8
    Germany
    Detlef Müller
    Hi.
    Yes correct the bezel from outside.
    Have you more Infos or an address?
    Thx
  4. redqv
    redqv Karting
    127
    Almost Oregon, California
    Ron Stevens
    I just had Porsche 911 “pointers” put on my tach and speedometer by Palo Alto Speedometer in the Bay Area of California. They also recalibrated the speedo. Is also had the pointers on the original gauges painted to match.
  5. Lefti31
    Lefti31 Rookie
    Oct 8, 2020
    8
    Germany
    Detlef Müller
    Hello,
    Ok, and you think they can also help me with the rings/bezel?
    Regards
    Detlef
  6. Cirorsi
    Cirorsi Formula Junior
    Nov 10, 2016
    790
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    I would recommend you ask them as well as Mo-Ma Manufacturing (Joey) in Albuquerque, NM and West Valley Instrument Specialists in Reseda, CA. I’m no expert but your bezel ring looks salvageable.
  7. janmante
    janmante Karting
    176
    jan mante
    #7 janmante, Feb 25, 2021
    We used these folks for MANY years in the M/C business ! 30+ years ago ! their work was superlative glad to see they are still around ! they were expensive but their work was always PERFECT !
    North Hollywood Speedometer Repair - NH Speedometer
    www.nhspeedometer.com
    We perform Concourse Restorations,Conversions, Calibration and Customization of your gauges, Concourse level restoration of speedometers, tachometer, clocks and automotive gauges. For over 65 Years our Porsche Department has specialized in 356, 911, 924, 928, 930, 944, 993, 996 models.
    Service and Restorations · ‎Contact Us · ‎Porsche · ‎Volkswagen
    PS the needles are pressed on , a friction fit you can use two small pry bars to ,lever them off ! CAREFULLY ! from the backside of the needle at the base Watch you tube videos ! Image Unavailable, Please Login
