Spark Plug Anti-Seize Compound | FerrariChat
Discussion in '360/430' started by whatheheck, Sep 10, 2018.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I'm getting ready to replace my spark plugs & I have been doing lots of reading here including Aldous Voice's DIY. Seems fairly simple. Thanks to everyone that have posted and shared their experience.
    Workshop Manual says: "Apply a minimal amount of the prescribed type of lubricant to the threaded part".
    My question is:
    1) What type of lubricant did you use?
    2) Or did you just skip this step?
    3) If you used anti-seize did you reduce the required 10nm spark plug torque?
    Thanks in advance.
    Dan
    Flea7 likes this.
  2. rob73
    rob73 Rookie
    Apr 29, 2015
    18
    Athens, Greece
    Bert
  3. rob73
    rob73 Rookie
    Apr 29, 2015
    18
    Athens, Greece
    Bert
    I am using a tiny amount of a product called Silver Goop. Then torque to spec. Normally used for spark plugs in GE aircraft engines. Never ever had a problem.
    whatheheck likes this.
  4. Flea7
    Flea7 Formula 3
    1,962
    PNW
    SKIM
    Hi Dan,
    I have the silver for aluminum and copper anti seize. I can give you some of both.
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Awesome! Thanks my friend.
    I will come by and pick it up from you sometime this week.
    Dan
    Sent from my SM-G955U using Tapatalk
  6. Flea7
    Flea7 Formula 3
    1,962
    PNW
    SKIM
    No problem...glad to help.
    I will be back in town tomorrow. Give me a call.
  7. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Will do.
    Thanks!
    Dan
  8. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    Dave rocks likes this.
  9. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    And that's why I'm asking what others have done as I read the WSM and I also have read NGK's recommendation.
  10. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    Some time ago, a few years, there was a long discussion about the impact of anti-seize on torque spec. As I recall the result, and many of the pros chimed in at that time, is that the impact is 30-35%. That was based on a bunch of different sources that had done tests. NGK also has a number of turns spec if there isn't a torque wrench available. You could use that because it is independent of measured torque. But, you are 100% sure you will over torque if you use anti-seize and torque to spec. Does it damage things on any given time? Who knows. It depends if you exceed the elastic limit of the metals.
  11. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Torque always must be reduced if a dry spec. Not for nothing, I've never used anti-seize on a spark plug. I don't think the idea is bad, just never had an issues without it.
    f355spider and whatheheck like this.
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I like the idea of using anti seize compound as it greatly reduces the possibility of the plugs being frozen tight in there when its due for replacement again due to the two dissimilar materials coming in contact with each other.
    My plan is to use the anti seize compound, then torque the plugs 30% less to 7nm instead of 10.
    Skidkid likes this.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Just put some engine oil on the threads, using anti seize is ok until you remove the plugs and the stuff drops off into the liner. Copper anti seize is copper dust in a grease , it dries out and the copper dust is left between the threads, when you remove the plug it breaks and falls off.
    One place not to use is on very fine threads as I have seen this lock a blanking plug in place, that it had to be drilled out.
    It was used extensively in high pressure boilers on the hand hold doors and worked fine on course threads.
    Zcobra1 and whatheheck like this.
  14. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  15. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    #16 Streetsurfer, Sep 11, 2018
