Source for flat 2 pin connectors? | FerrariChat
Discussion in '308/328' started by ATSAaron, Sep 13, 2019.
  1. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Does anyone have a source for the flat two pin connectors like used on speed sensors and early crankshaft triggers?
    I need some for an ecu project.
    Thanks,
    Aaron
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    A picture would help your case.
  3. Steve Magnusson
    26,504
    An internet search on "2-pin bullet connector" should get you something very similar -- they've changed the shaped of the male bullet slightly (and probably the female too), but I think it would still be compatible with the early design:
  4. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Steve - that is close. Close enough that I ordered a set to try earlier this week. But the male (and female) are actually too large.
  5. Steve Magnusson
    26,504
    That's unfortunate. I see on Digikey that they have different diameters of bullet connector terminals available:
    https://www.digikey.com/products/en/connectors-interconnects/terminals-barrel-bullet-connectors/393?k=bullet
    but they don't seem to have pre-molded bullet connectors (although I didn't look to hard). Perhaps looking thru those terminals for what you need might get you to a manufacturer name to pursue further, or you could make your own ;). What is the diameter of the male pin that you need to match?
  6. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    Are the male connectors flat blades or round bullet shaped?
  7. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
  8. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
  9. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
  10. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    This site has a lot of the flat connectors.
    https://www.autoelectricsupplies.co.uk
    Not seeing the ones you need for the sensor, but looks like they have the individual connector.
    Steve is correct with Digikey having a wide variety, just a little challenging to search their site.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    If you access to one of the sensors, why not take it to an auto parts store (NAPA) and see if they can match the connector?
  12. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
  13. Chrill
    Chrill Karting
    May 31, 2018
    61
    Christian P Galle
