Sodium filled valves | Page 2 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by larryg, Dec 26, 2016.
  1. JohnnyRay
    JohnnyRay F1 Rookie
    2,928
    Central FL/NW WI
    If this is true, then I would be led to believe that it is not so important to rotate the engine during short (less than 6 month) storage in order to periodically change relative spring tension? Any other thoughts on short term storage?
  2. Rifledriver
    34,064
    Austin TX
    Keep the battery charged. Keep mice from eating the electrical harness.
  3. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Might be worth contacting the guy in the 308 section who's getting a group buy on theirs. They might be able to match the 400 series.
    Out of interest, are all 400's fitted with these or just specific years?
  4. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Do the sodium filled valves respond to magnets at all or are they non-ferrous?
  5. Ak Jim
    Ak Jim F1 Veteran
    8,493
    North Pole AK
    I was just thinking the same thing. By the way why is stainless steel used for valves?
  6. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
  7. Rifledriver
    34,064
    Austin TX
    They OE Ferrari valves are all carbon steel
  8. Rifledriver
    34,064
    Austin TX
    Many but not all US made replacement valves are stainless but many stainless alloys have some degree of carbon steel so a magnet will stick.
  9. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The same elements in stainless steel grades that allow the material to be hardened are the same elements that cause corrosion. Leave a stainless steel knife in the rain and it will rust as it's made from 400 series stainless.
  10. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks very much for the info, Brian.
  11. Highmiler
    Highmiler Formula Junior
    Dec 8, 2010
    414
    Missouri
    Greg
    Under what driving circumstances do these valves come apart?
    Is it a function of high RPM or inevitable with time and miles?
    Greg
  12. Rifledriver
    34,064
    Austin TX
    No pattern.
  13. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,299
    are these valve failures assoc with any other issues such as other items wearing or misadjustments?
  14. samsaprunoff
    samsaprunoff F1 Rookie
    4,179
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Brian,
    I have noted an empirical pattern that may or may not be accurate. The pattern I observed is that there appears to be a much higher probability of a sodium valve failure after recent cylinder head rebuilds where the original valves were recut and/or new seats installed. Presumably the increased thermal gradients across the sodium valves (via it being recut and/or the new seats) precipitated the valve failure? These days I cannot imagine anyone would reuse the original sodium valves during a cylinder head rebuild and so my observed pattern may be moot.
    As I said... this was a pattern that I happened to notice.
    Cheers,
    Sam
  15. Rifledriver
    34,064
    Austin TX
    There may be an increase but I have certainly seen quite a few failures absent of those circumstances.
  16. samsaprunoff
    4,179
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Brian,
    Absolutely and I fully agree. My only point was that I noticed that a very high percentage who had a head rebuild (recut valves , seats, etc) and maintained the sodium valves had a failure. As I said, my comment is not scientific and simply an observation that could be completely out to whack.
    Cheers,
    Sam
  17. Rifledriver
    34,064
    Austin TX
    That could very well be and would be interesting to know with certainty but at this point for reasons you already gave I suspect all we can do is theorize and speculate.
  18. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    481
    Tim
    Digging up this old chestnut again as I've got my heads off to try and determine if I have sodium exhaust valves or not.
    How do you tell without cutting one open? I assume that the solid valve weighs more but I don't have one to compare with. Stamped above the collet groove on the valves is 'EL 107082 H' is that any indication of what type of valve is fitted? The Superformance website says their valves are tipped with 12H and 6H stellite, I imagine that is what the H indicates, not sure about what EL indicates. Hopefully someone with a bit more experience than me can shed some light on this. Cheers
    Sent from my SM-G935F using FerrariChat.com mobile app
  19. raemin
    raemin Formula 3
    Jan 16, 2007
    1,865
    Lyon (FR)
    R. Emin
    107082 is the Ferrari reference for the "stock" valve. If these valves do carry the original Ferrari references, I would tend to believe these are the sodium valves.
    Will try to see if I still have the original valves, and will let you know. At £40, I would not take a chance.
    As a side note, @samsaprunoff is probably onto something: my car had suffered from cylinder head failure so the head had been overhauled. Valve broke shortly after. So shortly after that we had a not so pleasant discussion with my (former) mechanic...
    prober34 likes this.
  20. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    481
    Tim
    True about the p/n, but superformance list their solid valves with the same p/n despite the difference, that’s why I was curious about what the EL & H stamped on the valve indicate. I definitely won’t be taking the chance, the unknown valves is why I pulled the heads. £40 per valve is fine, but if I don’t have to spend it I’m happy to keep the money too. The Aussie peso exchange rate makes these things add right up!
  21. larryg
    larryg Karting
    Jun 30, 2004
    232
    Louisville, KY
    Larryg
    I don't recall any numbers stamped into mine but I did find this picture that shows the difference in the machining where the stem meets the head of the valve. New is on the right.
    Tojo likes this.
  22. Ak Jim
    Ak Jim F1 Veteran
    8,493
    North Pole AK
    This is just a wild guess. The solid valve is stainless steel and therefore nonferrous so a magnet won’t stick but it would stick to the older sodium filled?
  23. roger21
    roger21 Formula Junior
    Aug 13, 2015
    262
    France
    Stéphane
    Ak Jim likes this.
  24. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    574
    Australia
    I finally got around to cleaning up one of my original valves which I believe to be a sodium filled one and compared it's weight to a Superformance solid valve.
    My original has the number EL 107082 K on it and weighs 72 grams (measured on the missus cheap kitchen scales so read into this what you may).
    The Superformance solid valve Part no. V1215006 weighs 82 grams on the same scales.
    Schumi likes this.
  25. Al Campbell
    Nov 22, 2013
    574
    Australia
    I should also mention that I checked these with a strong magnet and the Superformance solid valve Part no. V1215006 is mildly attracted to the magnet all over.
    My original with the number EL 107082 K on it is a different story though -
    The head is mildly attracted to the magnet (bit more than the new valve though)
    The middle of the valve stem was not attracted to the magnet
    And the collet area of the stem was very attracted to the magnet.
    Cheers,
    Al
    Schumi likes this.
