Smoke testing headers | FerrariChat
Discussion in 'Technical Q&A' started by ronrob, Dec 30, 2013.
  1. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    I have read often that headers can be smoke tested for leaks. Is this possible with the headers still fitted (in my case to a 355) and, if so, how is it done?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,384
    San Carlos, CA
    Mitchell Le
    You need a smoke machine that some automotive shops have. They stuff the smoke pipe up the car's pipe, block off other orifices and let the smoke reveal the leaks. It is possible to test your headers with them still on the car.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #3 2NA, Dec 30, 2013
  4. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Yup, but what puzzles me is how to block off the other orifices!
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Duct tape works just fine.
  6. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,656
    Essex, UK
    Andy M
    :D
    Like your style
  7. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    There is a lot of info on the net about making a simple smoke machine at home. I think you would only have to block the air intake for this to work.
  8. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    How do you get all the exhaust valves closed to the exhaust system at the same time?
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Don't overthink this. Intake and exhaust valves are typically NOT open at the same time. You don't have to block the intakes. Just tape off the exhaust pipes and add the smoke. If there's a leak, you'll see it.
  10. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    This is encouraging - I was, as you said, overthinking the procedure. I have always wondered how it was possible with the headers still fitted. Just do it, is the message I am getting. Thanks.
  11. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    The independent shop that services my BMW has a smoke machine-- you just occlude the exhaust tip(s) with tape or whatever except for the tip the smoke machine is occluding then watch for smoke to appear at any holes or loose clamps in the exhaust system.
