Small drop of coolant | FerrariChat
Discussion in '360/430' started by gsworld2014, Jan 30, 2021.
  1. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    So the weather has been hot and cold and last week there was a small drop of coolant.. right side.. I wiped it off and drove around. One more drop. Now today i wiped Off the bottom to make sure no liquid was on the car. Ran the car for 15 min sitting there. No coolant on the ground. Checked 2 hours later to see if any would be there.. still no coolant. The car is going in for annual Tuesday but has anyone had this happen?
  2. imahorse
    imahorse F1 Rookie
    4,448
    WI
    Dustin
    Not a drop. I've had a smokescreen from a coolant coupling exploding though. That was kind of cool. If you want help figuring out where it is coming from, we will need a better description of the placement. Saying it is on the right is half of the car. Are we talking the right side looking at it from the front or back? And how far from the front or back?
    gsworld2014 likes this.
  3. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Your right... it’s in the vicinity of the water pump... behind the door like midway to to the middle of the car. Let me rephrase... has anyone experienced a hose leaking from rapid changes in temp?
  4. imahorse
    imahorse F1 Rookie
    4,448
    WI
    Dustin
    The changes in temp outside are nothing compared to what happens in the engine bay when the car is running. I would put money on it being this guy. IIRC that's the hose off of the thermostat housing (it's been a few years since I changed it). They commonly fail when the upper transmission mount goes out, so I would check that too. Ferrari wants like $160 for the hose, but if you do your homework you can find a much cheaper, better replacement. Image Unavailable, Please Login
  5. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Thanks. Hopefully it is a hose. Trans mount just replaced last year around Feb. where does that hose run?
  6. imahorse
    imahorse F1 Rookie
    4,448
    WI
    Dustin
    It's off of the thermostat housing, on top of the water pump iirc. Bouncing around before your upper trans mount was changed is probably what did it in, assuming that is the problem. I wouldn't be worried about anything bad. Unfortunately 20 year old rubber exposed to such high temps doesn't last forever.
  7. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    True story eventually all those hoses will have to be changed. I’ve been changing stuff as I go. I’ve had the car for around seven years and it’s been really good but I do keep it maintained and I have replaced pretty much all the seals.
    armedferret likes this.
  8. RedNeck
    RedNeck F1 World Champ
    12,475
    The CSA
    Me
    What concerns me is the fact that even though the “drop” is on the floor, I haven’t seen any reference to what maybe on the belly pan. A drop on the floor could be a pool in the pan and is dripping through a place that is nowhere near the actual leak. Have you checked your coolant level? Took a flashlight to the belly pan?
  9. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    yes on both. Nothing visible from any angle... no fluid. Yesterday ran it in place for 15 min and no fluid .. very odd. Coolant level good... no temp issue either.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    Maybe weak coolant cap.. drips thru overflow tube
    If this was checked already ..sorry in advance
    Sent from my moto g(7) using Tapatalk
  11. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Thanks and yes checked that the overflow is on the left side.
  12. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    So interesting one. .... they cleaned the bottom... ran on the lift... nothing. No leaks. WTH ... I was in the shop so I saw as well. Now we need monitor cause couldn’t replicate the leak after cleaning it off
  13. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    380
    NC
    Did you put a pressure tester on it? That'll expose a leak pretty quickly. With the car just idling you may never have gotten the coolant system pressure up.
    Sent from my SM-A515W using Tapatalk
  14. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    They let it run for like 10-15 min....
  15. tstuli
    Jun 12, 2018
    380
    NC
    Don't think that will be sufficient. If you're inclined, pressure testers can be bought on Amazon for pretty cheap.
  16. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Interesting.... how are they used? There is no issue when I’m driving so what would that tell us?
  17. tstuli
    Jun 12, 2018
    380
    NC
    flash32 likes this.
  18. RedNeck
    12,475
    The CSA
    Me
    I would hope any Ferrari mechanic worth his salt would have done this already, that is a SOP at places like Midas, etc...
  19. tstuli
    Jun 12, 2018
    380
    NC
    Me too? Sounded like they just let it idle out though
  20. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,638
    San Jose
    dc
    There are a few areas where coolant flows that are metal on metal (I think w sealant or o-rings) that could re-seal after a heat cycle. I've seen one area with very minor "wetness" when doing a coolant swap and thermostat replacement and at first had some concern. Nearby the thermostat housing but not an area where any "adjustment" could be made w the engine in installed.
    I had thought to make a post about it but did not find anyone else having the issue and likely common but no one leaves there under body covers off for weeks. Totally resolved once I brought the car up to temp and wondered if it was due to the coolant separation since I poured in the undiluted coolant first.
  21. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Thank you. Very odd... I have driven about 200 miles and nothing...
  22. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,638
    San Jose
    dc
    Same here. I had the under car covers off for weeks (doing other work along the way like AC and belt) and left a paper towel under the area and checked. Many miles and weeks later nothing.
  23. tonino ct
    tonino ct Karting
    Mar 1, 2018
    140
    tony
    Did you find the leak? I had the same problem. 1 drop today and nothing for weeks. Then again. The coolant was sitting under rhe oil pan.
  24. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,638
    San Jose
    dc
    #24 Sj_engr, Mar 4, 2021
    No leak but when I swapped the thermostat the arrow is what I observed. It did not have any "wetness" after the car was brought up to temp and I am guessing the coolant mixed properly. You can see the new thermostat at the top of the picture.
    BTW there are different mount holes of the thermostat depending on the year. I found on my 2005 that I needed to drill out one of the boss on the thermostat to fit the "old" bolt pattern. When I tried to blindly put the new thermostat I was spinning the final bolt forever since the pattern did not align.
    If I did not explain well you can easily tell the difference when you compare the removed thermostat to the replacement on the garage floor. Frustrating experience when you cannot get that final bolt to catch and cannot see what is wrong.
