Simpson FIA Hybrid Head And Neck Restraint | FerrariChat
Discussion in 'Tracking & Driver Education' started by Rosso328, Jan 22, 2016.
  1. Rosso328
    Rosso328 F1 Veteran
    7,299
    Central FL
    Paul
    I'm looking at taking the 430 to a couple of HPDE days, but there is no harness set up in the car, just the stock three point belt. 3 point = No HANS.
    The Simpson hybrid is billed as being FIA tested and approved for use with a 3 point system. I'm thinking it might be a good option, but still investigating and doing my own due diligence
    Anyone have any experience with it to share?
  2. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Most of my time in cars is instructing at HPDEs. Other instructors use them. I'm planning on picking up one soon, along with a new helmet. Will be selling my HANS Sport II to offset costs. Very versatile. Also, random information, Simpson acquired Stilo back in December.
    If you don't have a dealer in the area, I'll suggest: Bob at www.teamdi.com and the folks over at Winding Road Racing www.windingroadracing.com
    BTW, I'm flying to your neck of the woods tomorrow and driving back a car with a friend. Anything going on in the Tampa/Central Florida area that I should know about besides the cold air?
  3. fatbillybob
    Aug 10, 2002
    28,563
    socal
    I go back 2 decades using HNR. My research was the reason for HNR is to prevent fatal basilar skull fracture. That is a very real threat in the racecar environment and more as driver containment increased. BSF is rare in the oem 3pt safety system because of the dynamics of how it works. R3 was the 1st HNR to champion the idea of anti-BSF with 3pt belts. I think it is more marketing than anything else. In 2016 the HANS still has the most data to prove reliable function with black box recordings of professional crashes at over 100g's. HANS is the 800lb gorilla while everyone else trys for market share. There is no compelling reason to use any other HNR in the properly designed racecar safety system.
  4. Schatten
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    3 point seatbelts is the issue, which is not going to work for a HANS.
  5. Rosso328
    Rosso328 F1 Veteran
    7,299
    Central FL
    Paul
    Exactly. The Exige has a harness, but the 430 does not.
    I heard encouraging things about the Simpson from one of the Chief Instructors at Chin, but was looking for additional data points. Thanks for your thoughts, Randy.
    BTW, if you are here in time, the Orlando Cars and Coffee at Lakefront Park in Celebration starts at 10:00 AM tomorrow morning...
  6. fatbillybob
    Aug 10, 2002
    28,563
    socal
    No basilar skull fracture with 3pt belts. So wearing a simpson hybrid with 3pts is like carrying a flashlight outside in a bright sunny day. If your research finds that BSF is a concern with 3pt belts please point us to those papers so I don't spout false stuff. Thanks!
  7. Schatten
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    FBB, With speeds getting up there in over the shelf/non-build race cars, it seems the data would be lacking at this point. I'm not arguing one way or another, but Paul wishes to have that piece of mind in safety gear. With airbags and a 3 point, I don't doubt your claim.
    As someone with a major closed head injury in their past, I'd take that flashlight just for the extra assurance, even if that is .000001% better than without.
  8. fatbillybob
    Aug 10, 2002
    28,563
    socal
    That is the problem if there is no data. Sometimes doing something that sounds like a good idea has unintended consequences. For example what if the hard shouldered simpson does not deform and trap the belt like the shoulder/clavicle/neck interface and instead encourages dumping of the shoulder belt? We just don't know when we have no data. Who has crash tested a HNR with 3pts? Certainly there is no black box data with real people. Under your situation of a stock car I would consider a 4pt ASM (that acts like a 3pt do the research) which is HANS compatible. But again if the 4pt ASM acts like 3pts BSF it is not an issue.
    There is nothing more difficult to design than a dual use trackcar. This is a primary reason that so many track organizers allow modern stock OEM safety systems for HPDE. We know what we get with stock OEM and we know what we get with true race safety systems. The in between is very gray and possibly more dangerous than first glance would suggest. This game is chess not checkers.
  9. Rosso328
    Rosso328 F1 Veteran
    7,299
    Central FL
    Paul
    #9 Rosso328, Jan 22, 2016
    Good points, FBB, and exactly why I am looking for as much input and as many data points as possible. It is my neck on the line after all. Literally.
    The folks at Simpson claim that their FIA Hybrid has been tested and approved for use with a 3 point system. They have their regular Hybrid Sport model which does not make that claim, so apparently they believe this particular model would at least do no harm in a 3 point car.
    Is there a significant risk of BSF with a 3 point belt and an airbag? Probably not. Definitely not at 'normal' road speeds, but on track with the added weight of a helmet, I would prefer to go the extra step.
    Thanks for any and all input. I believe in gathering as much information as possible in order to make the most educated decisions.
    Edit: As your signature says, the right answers come when you do your own homework. Absolutely agree! And again, I do appreciate your input, especially knowing a bit about your experience in the subject matter.
  10. Heat Seeker WS6
    Heat Seeker WS6 Formula 3
    Nov 4, 2003
    1,704
    Milwaukee, WI
    John G
  11. Teachdocs
    Teachdocs Formula Junior
    Sep 3, 2012
    568
    Kansas City area
    Chad
    I have one FS if anyone is interested send me a PM. Thanks
    I purchased it to use in the 16M when I used to track it. The device is comfortable and easy to use with a 3 point system. I only used mine several times.
    The reason I don't use it anymore? Because I don't track that car anymore. I realized that the speeds seen in that car are just not the smartest thing in a street car. I moved into a proper race car with cage, harness, fire suppression, and nets.
  12. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    a few thoughts to add...
    I'm a 15 year+ HANS user, and a HALO seat user for about 5 years. Really won't go hard on a track without all that (plus seat, cage, et al).
    HANS has a lot of data to support that it works, plus there it fits within a "system" that has no evolved, including harnesses, seats, cage/harness bar location, etc. A HANS is great, but it's part of a co-developed overall system (or, it's evolved that way, which is good).
    With a HANS, the "design requirement" for lateral restraint has been sort of increasingly replaced by the use of HALO seats, or of head surround padding in prototypes and formula cars.
    The HANS literally works by fixing itself to the car....via your belts.
    The Hybrids work by being fixed to your body. I have not seen much data on their design/testing/use, but maybe it's out there. Your body is obviously not as rigid, fixed, et al as the car is. I've seen people using these systems wearing them loosely, and I could easily displace the tethers by pulling. Fitment and proper adjustment is key to any protection. They do offer some lateral support/restraint, but again, it's anchored to your body (and human bodies can contort in an impact).
    However, I'd speculate that wearing a hybrid, vs. wearing nothing, in a street car is probably worth considering.
  13. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
  14. Heat Seeker WS6
    Nov 4, 2003
    1,704
    Milwaukee, WI
    John G
    #14 Heat Seeker WS6, Jan 25, 2016
    Sorry for the poor pic quality of the catalog when I Visited Pegasus Racing. Got some good info as well as got sized for a hybrid. Didn't purchase it yet but I'm leaning towards this.
    I know most of you guys don't ride shotgun anymore and/or in fully prepared cars, but I do ride in he passenger seat of street cars on track
  15. Rosso328
    Rosso328 F1 Veteran
    7,299
    Central FL
    Paul
    I'm strongly leaning to 'yes' on this as well.
    I will rarely drive a street car on track, and may or may not ever ride shotgun in someone else's street car. And while I know the mechanics of how the torso moves in a collision under a three point belt making head and neck restraint less imperative...
    If it does no harm, and may in fact help, I'm in.
    Really appreciate the lively discussion on this. Thanks, everyone.
