Side Mirror glass only replacement | FerrariChat
Discussion in '308/328' started by miketuason, Jun 8, 2012.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    #1 miketuason, Jun 8, 2012
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    MIke can you tilt the miirror enough to get a view from one of the sides? It appears that one of the four studs that held the mirror broke off in the white lower left piece. That would suggest a pressure fit type of stud that should pull out carefully. This is like a chinese puzzel box. Alternately there might be little keeps on the back of the studs but it would be really tough to put them back on. Perhaps the glass comes off a carrier that plugs into the white piece? I will have to look at mine when I get home unless others here are in the know.
  3. miketuason
    Feb 24, 2006
    15,761
    Cerritos, CA.
    Robert, unfortunately the second pics is not my so, I really don't know how they got it off. But, I think you're right, looks like something broke on the lower left corner that looks like from the glass carrier. It would be great if you could look at yours. Thanks.
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I wonder how it would look to just glue a piece of mirror of the correct size on top of your cracked one?
  5. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    Mike, yours is broken..... break out the remaining mirror as gently as possible starting in the center, safety glasses are a must!
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    No joy, couldnt even get close to seeing in there. Good suggestions here though.
  7. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    I haven't looked inside one of these (I sold mine when I removed). However, it would seem likely that the circular piece with the 4 tabs are permanently affixed to the glass, and that a special tool (moulding remover?) could be used to detatch the round piece and glass as an assembly from the tilt mechanism.
    Mike, when you do remove the broken pieces, please look closely for a detachment point(s).
    To break more glass out, use a glass cutter and score the surface; then tap the score hard on the surface at the score with the ball on the cutter (Usually, you tap from under the score, but no good here...no access...you would basically be scoring only to have better control of where the glass breaks.
    Use gloves to handle the shards.
    Rotate shards attached to loosen...and softly at that...don't just pull out.
    If you want, you can mail to me and I'll give the glass removal a go. I used to do professional stained glass, so I am not afraid. I also have excellent cutters. If successful, I'll document here for all. I may also figure out removal/replacement. PM me if you are interested.
  8. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I dont have experience with these exact mirrors (ones on UK cars are different) but assuming they are a standard design, the glass is removed by turning a locking ring which is part of the backing plate which the glass is glued to.
    The ring is accessed through the bottom by adjusting the mirror to open up the gap to max, at the bottom. Then look into the gap and you might be able to see some slots in a round ring just behind the glass. Insert a screwdriver and turn the ring and the glass should pop out. Then use a hot air gun and scraper to remove the glass from backplate and refit.
    Again, this is pure theory, these mitrrors might be a different design, but the picture seems to confirm they are this type. The locking ring engages on the 4 tabs which can be seen in the picture.
  9. miketuason
    Feb 24, 2006
    15,761
    Cerritos, CA.
    Here's the thing guys, I have an extra side mirror complete assembly. I don't have a problem breaking the old crack mirror but, what I like to do is remove the mirror out of my extra side mirror assemble and install it to my existing housing that's on the car now.
    I know I can just swap the whole thing but the housing on my extra one is not as good as the one on my car now. So, I will still try you guys recommendation and let you how it comes out. Thanks guys for helping.:)
  10. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Personally, I would not hit that assembly with anything. My first thought would be to apply some gentle leverage to one edge of the mirror or the other with a putty knife, etc., then heat the mirror itself with a heat gun (being careful not to cook the black outer housing...though it's pretty durable and can probably withstand some heat). It's very likely that it's glued to that white plastic "collar" and heat may allow the whole thing to pop loose without any impact to it. The holes may be for positioning pins on the back, that are glued. Your photo of the disassembled mirror hints at some dark colored adhesive on the white "collar". With the small plastic gears and mechanism, it may not take well to impact.
    My 2.5 cents.
  11. miketuason
    Feb 24, 2006
    15,761
    Cerritos, CA.
    #11 miketuason, Jun 9, 2012
    Ok I decided to try and see if I could swap my old crack mirror with the housing for the spare side mirror assembly that I have. I mentioned earlier that the housing of the spare mirror wasn't as good as the one on the car now but, after trying to clean it with the tire, trim, & molding cleaner, it came out just as good as the other one. The base of the spare one had lots of scratch and paint were pealing off so, I decide to keep my old base but, before I can do that, I had to remove the pins from the terminal housing of the plug in order the be able to pull the wires through the hole on the base. After doing so on both side mirror assembly, I was able to put the housing with the good mirror with my old but good existing base (lower side mirror on the pic) while doing all this, I had to place a small screwdriver between the wires that I pulled through the door to keep it from going down inside the door (2nd pic) So, everything is back together now with a good mirror.:)
  12. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Great work, Mike.
  13. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
  14. miketuason
    Feb 24, 2006
    15,761
    Cerritos, CA.
    Thanks guys but, I still have not achieve on removing the glass from its housing.
