Side marker light holes
Discussion in '308/328' started by LB427SC, Jan 13, 2024.
  1. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    I’m slowly returning my euro car back to euro spec, it was a US imported car.
    Has anyone swapped the US side marker lights back to Euro indicator repeaters? Is the hole in the wing/fender the same size? Straight swap or is there extra work.
    Much prefer the look of the small Euro lights.
  2. xpensivewino
    xpensivewino Formula Junior
    Jan 26, 2008
    952
    Simi Valley CA
    Need to know basis
    I’m a bit confused by your question, but the US marker lights are found both front and rear. They are large rectangular lights which require a large rectangular hole in the fender. The euro cars only have marker/repeaters on the front wings, and they are small round lights that require a much smaller round hole. So if I’m understanding your question correctly, yes there will be substantial body work needed to weld up the rectangular holes, and drilling needed for the Euro lights. Obviously paint work will be required. Good luck on your process, I also love the look of the round euro markers.
  3. dave80gtsi
    dave80gtsi Formula 3
    1,904
    Ohio
    Dave Meredith
    You will soon discover that your main problem with removing the larger US sidelights is the pair of smaller attachment holes on either side of the larger lamp thru hole. The pair of smaller holes in the fender are required to secure the US sidelights to the body, and these will need to be welded and filled as they will not be covered and/or hidden by any smaller round sidelights.
    So, sadly, no plug-and-play easy options for any of us on this idea.
    DM
  4. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    Hi Dave,
    nuts.
    Regardless, that’s the info I needed. Much appreciated. Back to the drawing board!
    Lloyd
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,763
    Cerritos, CA.
  6. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    As an experiment, I once bought a pair of your second picture's lights and tried to fit them to my USA-spec car.
    I unfortunately found that this style of factory sidelight, which does not incorporate a reflector-style lens as does the USA style, was not tall enough to cover my factory fender holes.
    By the way, the USA style sidelights were also fitted to Fiats of that era, and likely other cars as well, so replacements are cheap as chips and are easily available at Fiat parts vendors.
    DM
    miketuason likes this.
  7. miketuason
    Feb 24, 2006
    15,763
    Cerritos, CA.
    Yes, Fiat and Lancia Beta’s uses the same US side markers and I believe some old Alfa’s too.
  8. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    #8 dave80gtsi, Jan 13, 2024
    Lloyd - If you are simply seeking a "different" look, I've discovered a pair of options, both of which exactly match the 308 USA body holes.
    The first uses the side lights for non-USA Fiat X1/9's. A ribbed black backing plate with a small round lamp in the center:
    There's an X1/9 parts guy out of The Netherlands who makes these reproductions, and they fit both front and rear 308's with no modifications whatsoever required.
    Me, I did not keep them on my car as I was bothered by the end of the pair of mounting studs being visible once mounted, as you can see in my second picture.
  9. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    And the second option uses the side lights from some particular old Lada model.
    This one is the same configuration as the USA OEM side lights, but instead of their face being flat, they have a raised center piece.
    OEM on the top (first picture) and Lada on the bottom:
    I found these Lada lights in both clear and in amber, and since they're Lada parts, they were cheap!
    For my old X1/9 I ultimately went with clear Lada lights, fitted with amber (front) and red (rear) LED lamps behind:
    I fitted the clear Lada lights to my 308 just as a trial (sadly, no pics were taken at the time), but ultimately decided to stick with OEM instead.
    So, yeah, you DO have some easy bolt-on options to play around with!
    DM
  10. xpensivewino
    Jan 26, 2008
    952
    Simi Valley CA
    Need to know basis
    Apologies for my response Lloyd, I assumed you were discussing a GT4.
  11. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    #11 dave80gtsi, Jan 13, 2024
    Finally, for posterity, and anticipating any possible "where can I get those?" inquiries for the stuff that I showed in my post no. 9 above, here ya go!
    X19Parts Holland | Lights
    Obviously, no affiliation, offered just as a FYI. But observe the non-Ferrari-tax inexpensive prices!
    DM
    P.S. - Note some of their other lights as shown on other pages - likely some Ferrari commonality could be found ...
  12. miketuason
    Feb 24, 2006
    15,763
    Cerritos, CA.
  13. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    It was really just part of a slow steady move to return the car to a full euro spec as well as dealing with deferred maintenance form 30 years of storage. Just for looks really, the small repeaters just look more delicate and in keeping with the overall design to my eye. I don’t want to get the welder out just yet so they”ll have to stay as US lights for now. Didn’t spot the Fiat source, slightly embarrassing as I served my time in Fiat/Lancia dealership in northern England! :)
    I’ll move onto replacing or tucking the front bumper next instead.
    All the info is much appreciated. Cheers fellas.
  14. ragtop1
    ragtop1 F1 Veteran
    5,220
    Ontario
    Larry Warren
    Isn't the Euro side marker wired to the signal flasher as opposed to the night running light of the US version?
    Newman likes this.
  15. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    202
    CT
    Anthony V Rapuano, Jr.
    Believe that is the case.
  16. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    Yes, confirmed, this is indeed the way it was as I understand it, as delivered by the factory.
    But note that it is very easy to convert these side market lights to flash along with the turn signals via the (easily reversable) floating ground rewire trick. I've already done this to my own USA-spec 308, front and back, many years ago. Highly recommended.
    It is easy to believe that there are many YouTube or similar videos out there showing the details since the concept applies to most any car on the road today; it most certainly is not a uniquely Ferrari mod.
    DM
  17. ragtop1
    ragtop1 F1 Veteran
    5,220
    Ontario
    Larry Warren
    Do you remember where you sourced the signal wire from? The US side marker light has its own feed terminating at the marker.
  18. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    276
    Australia
    Why did the USA feel they needed to install these on Euro cars?
  19. bitsobrits
    bitsobrits Formula Junior
    687
    Omaha, NE area, US
    Steve
    You would have to ask the US Dept of Transportation. I would be interested to see the (safety) data that supported the decision, if it even exists. Side marker lights became mandatory for model year 1968 on all cars sold here.
  20. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    Mine had some modifications done, which I'm reasonably sure were undone in the US.
    Smog pump added, and then removed. The only evidence left is welded in, then welded up exhaust bungs in the headers.
    US front bumper, but Euro rear bumper
    Side marker lights
    I have a feeling that speedo was swapped to MPH, but the sender not as it seems to read fairly accurately if you consider the MPH numbers to be KPH. Or it could be the speedos are just wildly inaccurate.
    It has the feeling of a car that they did just enough to, to get it through a test, then removed at least some of it at some point
  21. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,350
    Canada
    Newman
  22. Newman
    Dec 26, 2001
    14,350
    Canada
    Newman
    The factory US spec front side lights are further ahead than the euro light, 3 inches if memory serves me correctly. The Euro light is just far enough ahead to clear the inner fender and a US spec light wont fit that location, so a converted car will have the holes in the wrong position as well. Not to mention the socket hole is larger as mentioned earlier.
  23. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    So they had to weld up the holes, drill new ones and then repaint? Quite a job! I checked images of my car and you're exactly right. The side marker lights are mid fender.
  24. Newman
    Dec 26, 2001
    14,350
    Canada
    Newman
    Big job and where you end the new paint is hard when there's no seams. Colour match is another problem.
