Shifting into Reverse | FerrariChat
Discussion in '308/328' started by Hotzos, Sep 27, 2014.
  1. Hotzos
    Hotzos Formula 3
    Oct 19, 2004
    1,060
    Parker, Colorado
    Mark Gomez
    When my QV is hot, it sometimes does not "like" going into reverse. You can feel the gears try to crunch.
    A solution where it is always smooth going into reverse:
    Go into 1st the Push the lever down while in 1st and go up into Reverse
    Another alternative is to go forward just a bit and then it goes into reverse fine.
    The experts believe the pilot bearing may be binding, not allowing the engine and input shaft to be independent of one another with the clutch released. The clutch is fine so i will keep watching this before i move forward with a full transmission service to replace the clutch/TO bearing/pilot bearings etc.
  2. sapqq1
    sapqq1 Rookie
    Dec 10, 2013
    30
    ATHENS GREECE
    HARIS
    Same does my 1979 gts, and i do the same trick, 1st gear first. I thing is a typical behavior of 30+ gear boxes
  3. Rifledriver
    36,755
    The last Ferrari gear box without a synchronized reverse. I forget sometimes driving ours. On the TR I can select reverse while still going forward.
    1st then reverse is never a bad idea.
  4. 4zaJim
    4zaJim Formula Junior
    May 15, 2012
    838
    Los Angeles
    Jim
    When I first got my 308, it did not take long to notice that it was too doing this when warm, . . . until thanks to FChat (Steve Magnussen) I learned the first then reverse trick, which I've done ever since and have spared myself and the car that horrible clunk
  5. Renato
    Renato Formula Junior
    Apr 14, 2013
    553
    New York
    +308
    This usually does the trick for me!
  6. djs308
    djs308 Formula 3
    1,129
    Long Island, NY
    David S.
    When I first got my Mondial 3.2, I experienced the ominous "clunk" every time I engaged Reverse from Neutral. Could not for the life of me understand why that was happening. This being my first Ferrari, I was understandably concerned for the well-being of my gearbox.
    So I asked some folks about it and their response was the same as discussed here – go from neutral to 1st, press down on the ball and slide it smoothly into Reverse. My reaction was, what is this? The secret Ferrari handshake?
    Well, ever since then, I've done it just that way, and never a clunk in Reverse since. Now engaging second gear when cold – that's a different story! LOL
  7. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,572
    Gates Mills, Ohio
    Jon
    My 328 was the same. It became a habit to the point where I just did it without thinking twice.
  8. tegspeed813
    tegspeed813 Rookie
    Sep 29, 2014
    11
  9. shmark
    shmark F1 Rookie
    Oct 31, 2003
    2,968
    Atlanta
    Mark
    If I get any resistance going into reverse, I do the same thing. Don't even think about it, straight habit.
  10. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    Your mechanic can also adjust the 'travel' on the clutch to fix this, it will go into reverse from neutral when car is warmed up without the clunk or at least it will become much less and be adjusted more until fully smooth.
    I had this done on my 89, it used to behave the same way...
  11. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Are there any tricks for getting into first gear after the car is warm? Mine has no problems with any gear, including second, when cold. After about 5 minutes, I can't get into first any longer, though I haven't tried doing so from other than reverse, neutral, or second.
    Ciao!
    Hannibal
  12. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    All these posts seem to me to call for a shift alignment adjustment.
    With a search you can find many posts here about the procedure.
    I can also post my document with the procedure. The "pros" can do it without dropping the gearbox pan. I cannot.
  13. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    On occaison I have a slight balk going into reverse but since it glides into second even when dead cold no one's going to touch my linkage.
  14. spike308
    spike308 F1 Rookie
    Nov 8, 2003
    4,688
    Austin TX!
    Mike Z
    sorry to butt in here...
    Rifledriver.... clear out your inbox!
    tried to send you a PM!
