Shell Rotella oil question | FerrariChat
Discussion in '308/328' started by Tifosi2011, May 14, 2011.
  1. Tifosi2011
    Tifosi2011 Formula Junior
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Please do not laugh as you read this. The only Shell Rotella oil that is available here locally is actually diesel oil. I've been reading many posts about this brand, but I have not noticed anyone mentioning that is in fact diesel oil. Am I crazy? Or just stupid? Are those of you who use Shell Rotella telling me that you are using diesel oil? Please be kind with your responses. The last thing I want to be labeled here on this forum is 'Stupid'!
  2. tazandjan
    39,007
    #2 tazandjan, May 15, 2011
    John- There are a bunch of Shell Rotella oils designed for heavy duty diesel applications. The one most suited for cars would be the T6 synthetic 5W-40. At the bottom is what Ferrari had to say about oil.
    http://www.shell.com/home/content/rotella/products/t6/
    Any of the modern synthetic 5W-40, 0W-40, or 10W-50 oils will work for your car, with the 5W-40 most often recommended. Various owners and pros recommend Shell Ultra Helix, Valvoline SynPower, Redline, Royal Purple, Mobil 1, etc, etc.
    Taz
    Terry Phillips
  3. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Hi John,
    I've just been through all of this trying to figure out what's available in Canada. Shell Helix is hard to find, but because Shell purchased Quaker State and Penzoil they have packaged Shell Helix as Quaker State Euro Formula and as Penzoil Ultra Euro Formula. The Penzoil Ultra Euro is available in Canada (5W40 weight is what I use for my 360).
    That said, I'm not sure that you need Penzoil Ultra Euro for your 308/328. I ran Mobil 1 5W40 in my 308 and was very happy with it (despite the new oil drips that resulted from using synthetic oil!!!).
    I hope this helps.
  4. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,745
    Atlanta
    John!
    The above posts are great and outline sound advice. I offer a side note regarding Shell's Rotella T6 formerly known as Shell Rotella T synthetic. The group III base oil is a hydrocracked slack wax oil which further refines it beyond a group III synthetic but cannot qualify as a group IV as group IV begins life as synthetic rather than having it's chemical properties changed and realigned to be a synthetic which is what group IIIs are. That being said, Shell's crack (pardon the pun) at making a group III are beyond what others are doing to the point that Ferrari's F1 motors are run with this group III base stock with of course different additives based on what track they are running. Point being, it's good stuff and the T6 formula is great for our early Ferrari's however I would not recommend it for the newer stuff with cats.
  5. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,261
    Illinois
    Can you expand on this interesting point? Thanks
  6. Tifosi2011
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Thanks to everyone so far for your input/advice. The reason why I'm asking about synthetic oil is that there is a reputable Ferrari mechanic here in Vancouver that says he does not use synthetic oil formulas because of the fact of leakage. I have a minor leak coming from my lower oil cooler line and I'm pretty sure that the previous owner used synthetic oil during it's last oil change back in July.
    I'm in the process of acquiring a good Dino oil that provides as close to the best startup protection and lowest warm weight. I guess it is possible that this oil cooler line leak might disappear or lessen if I use a non synthetic blend. My oil pressure is within it's parameters during idle and generous driving. I don't have any leak on the pan/gaskets/ or even the pan bolts. It's just in the oil cooler line.
    I live in a very mild climate. I don't ever plan on running my car on a track. But I do want the best option. Can anyone give me a good choice on a Dino oil in comparison to a synthetic? Please help. Thanks everyone. And especially, Go Canucks!
  7. tazandjan
    39,007
  8. Ferraripilot
    May 10, 2006
    17,745
    Atlanta
    John!
    The additive package in the diesel formula is ok for modern cars with cats, but I would still steer clear of it as there are many good alternatives. Not a whole lot to expand upon, it's just an oil that was intended for diesel first, gasoline second. It has an incredibly robust additive package but for my personal preference I would keep away from it for more modern engine management cars.
  9. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    #9 Spitfire, May 15, 2011
    Hi John,
    When I switched from dino to synthetic oil I definitely noticed a few additional drops of oil forming on the garage floor. However, when I made the switch I immediately noticed changes to the mechanical sound of the engine (i.e., it was quieter, especially at start-up) and I therefore decided that I was getting better protection and that the switch to synthetic was worthwhile. Each into his/her own of course.
  10. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Too much worrying about oil! Use a known brand and grade that corresponds with the owner's manual recommendations and forget about it. Every "Ferrari" shop uses whatever brand of oil they get the best profit on; you'll notice that there is little or no commonality among them as to the brand (and not much more with the weight) nor are there any issues with it... ;)
  11. Ferraripilot
    May 10, 2006
    17,745
    Atlanta
    John!
    +1! so true
  12. thecarreaper
    thecarreaper F1 World Champ
    17,957
    Savannah
    Redline 10-40 from the internet.
    Amazon even sells it.
    the end.
  13. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    +1
    I have been using Rotella in my Dodge Diesel pick-upand 97 Jeep Wrangler (4.0 ltr 6) for sometime, no problems.
    The 308 once about 3 years ago got Castrol 20/50 racing. I just turned 3000 miles on that change, so it's due again. I'll see what they have at Autozone
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    The issue with diesel oil is that it still contains zinc, a much needed additive for flat tappet cam engines. The zinc is known to contaminate cats and has been removed from oil due to this. that's a problem for early cars and diesels that need that protective layer.
    there are zinc additives however they tend to contain large amounts of wax for suspension. Shell Rotella, lubro moly, and some small oil producers still add zinc but it's for race engine or diesel use only per EPA guidelines.
    as to the cat issue this is a new thing with the newer cats and the material and light off temps involved.
