SF90 Driving range | FerrariChat
SF90 Driving range
Discussion in 'SF90 Stradale' started by EauRougeF1, Apr 9, 2024.
  1. EauRougeF1
    EauRougeF1 Rookie
    Mar 8, 2019
    3
    Karl Aleksander Kivimägi
    Hello can any SF90 owners confirm what a full tank range for it would be on casual driving with a hybrid drive mode?
    I've seen people say 1000km+ because of the hybrid system, you can really drive it economically. Is this true or not?
    For a long roadtrip this seems like a good car for that reason. Or is 400-600km more realistic?
  2. Jo Sta7
    Jo Sta7 F1 Veteran
    5,696
    Scottsdale/Pittsburgh
    Jon
    Really?
    rg88 likes this.
  3. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    899
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    Bravo fi=or using your Ferrari as Enzo intended. Wring it out!
  4. Fortis
    Fortis Formula Junior
    Nov 2, 2019
    739
    Fortis
    I only drive it in Qualy and sometimes in electric so wouldn’t know what the range is but that’s an interesting question.
    Divexxtreme and Jo Sta7 like this.
  5. EauRougeF1
    EauRougeF1 Rookie
    Mar 8, 2019
    3
    I'm thinking of making a longer roadtrip with very little if any petrol stations (through rural areas etc) and I'm choosing a car for it. I will ask the dealer as well, but if anyone has any figures in the real world it would help a lot.
    And after that I'm giving it to my grandma for whom it will be very important as well... /s
    rg88 likes this.
  6. mkraft3003
    mkraft3003 Formula 3
    2,355
    Tampa, Fl
    So you don’t own one yet, but are considered buying a 600k supercar to maximize the range for a long road trip after which you will give to your grandpa who is concerned about range as well?? It think @Jo Sta7 has the correct response.
    Jo Sta7 likes this.
  7. Fortis
    Nov 2, 2019
    739
    Fortis
    Ok I have no idea if the OP is trolling or not but I would like to mention something quite relevant to this, irrespective of the battery charge if you are running out of fuel the car will stop, it will not run on electric only if the fuel tank is empty.
    I’ve learned this the hard way during a Ferrari organised event where they failed to gather us all at a gas station, long story.
    Jo Sta7 likes this.
  8. rg88
    rg88 Formula Junior
    Feb 10, 2024
    416
    rg
    #8 rg88, Apr 10, 2024
    OP has been a member since 2019 and only just posted this. Unlikely to be trolling also being mindful of language and culture differences. @EauRougeF1 are you able to post a photo of your ride? Seems the question stems from not knowing if the car can transport him to his destination without refueling along the way which seems to be problematic. Fuel efficiency is good too but likely not of primary concern for most Ferrari owners :)
    EauRougeF1 likes this.
  9. RumorDude
    RumorDude Formula Junior
    Dec 16, 2003
    624
    Woodinville, WA
    it's a legit question to me.
    so, if you run the car in 'hybrid' mode, it does mostly what you would expect: depletes battery and then turns on the gas engine to charge the battery back up, engine off again, deplete battery, etc over and over. you'll notice a few different icons in the 'electric fuel bar' - including one that indicates it is going for a full recharge (after you go below 0 range on battery)
    all of this, quite amazingly works together to give you prius type fuel economy. (yes, i said that.)
    if you are a flat road, and you turn on cruise control at 60-65mph, you will average over 50 miles per gallon. if you don't turn on cruise control, you can still see this same kind of economy but you need to be gentle with the throttle.
    you can get similar performance by doing it all semi-manually. drive along and run the battery down, then when it is super low, put it into *qualifying* mode. This is because in quali it will fully charge the battery to ~16 mile range. mind you, you are driving calm and smoothly at 60-65 mph in this mode still. then once it is 'heavily charged', you can switch back to hybrid (or electric only). when you switch to hybrid, the engine won't turn off right away unless you basically ease up on the throttle so much that you are barely even touching it. then it will flip back over, un it down, and repeat. you can still get over 50 mpg this way.
  10. Jo Sta7
    Jo Sta7 F1 Veteran
    5,696
    Jon
    How’s the McLaren F1 fuel economy? I’m interested in buying one for a road trip and then giving it to my dog.
    ForeverNA, Divexxtreme and mkraft3003 like this.
  11. rg88
    rg88 Formula Junior
    Feb 10, 2024
    416
    rg
    Asking as a future 296 owner, is it good for the battery to drain and recharge repeatedly? Is there a strategy to prolong battery life?
  12. mkraft3003
    2,355
    Tampa, Fl
    Fuel economy is great but your problem may be the view out of the windshield. It will come down to the type of dog you have. If it’s a corgi or smaller I’d probably go with a Mclaren 570. If it’s a golden retriever or larger the F1 would be a perfect buy.
    Jo Sta7 and Divexxtreme like this.
  13. rg88
    rg88 Formula Junior
    Feb 10, 2024
    416
    rg
    also probably best to avoid alcantara interior. keeping it clean due to hair shedding is a bitc*
    Jo Sta7 likes this.
  14. EauRougeF1
    EauRougeF1 Rookie
    Mar 8, 2019
    3
    Thank you a lot! This helps and I got my answer.
    To anyone else, the grandma thing was a joke.... I put the /sarcasm tag. And I'm completely serious. Of course I still want to drive spiritedly with the car, but I'm trying to understand if my idea to drive through eastern Europe (where I'm from) and explore some of its rural places is even viable in a car like that.
    About myself. I've been lurking for 5+ years and never posted because I'm still young and it was a dream to buy a Ferrari. I have been reading everyones stories and looking at the pictures. Now that I'm in a position to fulfill my dream, I'm reading more about the different models and how they would work in real-life scenarios.
    I will post more here when I actually buy the car.
  15. RumorDude
    Dec 16, 2003
    624
    Woodinville, WA
    this site is just plain wrong. the car can drive 16+ miles on electric alone. i do this regularly when i go to the store - i dont even turn on the gas engine at all.
    regarding a drive through europe, you will be fine, especially in the cities which ban combustion engines in their downtown areas. :) however, you will be very crimped for storage space!
  16. mkraft3003
    2,355
    Tampa, Fl
    That’s the data from the EPA. Take a look at your window sticker and it has the same info on it. How they come to that conclusion, I have no idea.
  17. Cocoloco
    Cocoloco Formula 3
    Nov 26, 2013
    1,274
    #18 Cocoloco, Apr 10, 2024
    I pinged Mac F1 on Mclife - waiting on response, lots of guys give their dogs their F1 cars.
    Bruce Enzo & Stroll. SF90 - closest I will get to F1.
  18. RumorDude
    Dec 16, 2003
    624
    Woodinville, WA
    They actually have a “test course” designed to simulate real traffic in a few settings and then they mush it all together.
  19. ForeverNA
    ForeverNA Formula 3
    2,471
    Very mature response. I like that. You made someone look like complete ass without even trying. Lol.
    Please do share pics when you get the cars, and I hope that day will come soon!
