Seatbelts | FerrariChat
Seatbelts
Discussion in 'Vintage (thru 365 GTC4)' started by Oengus, Jul 12, 2020.
  1. Oengus
    Oengus F1 World Champ
    Wondering why a lot of older Ferrari’s don’t have the blue factory seat belts?
    Most changed/updated etc etc.
  2. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    blue??
    was the installation of seatbelts a dealer things? I getting close to wrapping up a clients GTC and was thinking today - we need some seat belts for this car......the mounting on the rear side panels has 3 mounting bolts (right below the rear quarter window)
    where else would they mount......assume i need to make a provision for this?
  3. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    959
    Australia
    howard pigdon
    Ed I have a set of original Irvin if you need
  4. lancia
    lancia Formula Junior
    512
    Oengus likes this.
  5. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    yes i see that now - and yes, now looking at it, i recall this a whileback
    my 330 GT car had gray belts installed......assume this is dealer install item/vs factory?
    thanks for the pics.....
    thinking of it, my 330 car has Kiplan? Belts......sound familiar?
  6. donv
    donv Two Time F1 World Champ
    23,988
    Portland, Oregon
    Don
    I believe seatbelts were not required in the US until 1968, not sure about other countries. Before then, I would guess they were dealer installed?
    My 1969 365GT had the Klippan system, I think (replaced it with an inertia reel system which I think is much more usable)-- the old belts were fixed.
    I just bought a 1968 Mercedes 300SEL which also has Klippan belts... it had a brochure from the US Government describing "new safety features required for 1968" which included seat belts.
  7. JimEakin
    JimEakin Formula Junior
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Do you have a picture of the mounting holes with the interior removed? I really want to install 3 or 4 point belts in my recently acquired GTC. I did see there is a stout support bar in the trunk that could be used.
  8. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    there are 2 mounting nuts on the rear quarter side panel, inside. ill get pics......each side has 2 nuts 3.5MM apart
    they take a 10 x 1.5 MM bolt in either mounting position.
  9. daytonaman
    May 1, 2007
    959
    Australia
    howard pigdon
    Ed sent you an email
  10. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
  11. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
  12. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    out of the times, if not all the times i have seen belts installed, it is usually with one bolt. So i assume either bolt
    would be sufficient IMO.
    Related to the interior panels, i have also seen that they are already provisioned with holes in them, ill get pics of the back sides of each, the bottom piece and the top piece to accommodate the bolt or bolts coming thru. let me get those pics today for you
  13. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Thanks. I guess I really don’t need new panels as the seatbelts will be permanently installed.
  14. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    crude cut outs, i have never seen one with a nice round cutout.....
  15. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Thanks, Ed. Looks like someone just ripped out the holes by hand.
    Need to install some form of standoff to attach the seatbelt end to.
  16. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    im making some plates that go on the outside of the black upper interior molding, it will have 2 holes in it for the mounting bolts, so the look is a better look than having bolts sticking thru - with or without seatbelts. Prob have them out of alum and black hard anodized for a nice look
    ill send u pics when ready
  17. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    These pics are very helpful!
    What is the bolt size and thread?
  18. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    10 x 1.5 thread - i believe...
  19. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,867
    romano schwabel
    don´t think so, bolts for seatbelts are always inch sizes
  20. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    i cleaned up my threads and this is what i have......
  21. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    OK, I've installed "3 point" retractable seat belts in my 330 GTC that I'm documenting on a separate thread.
    Regarding the bolts: 10mm and 12mm of any thread count would not fit into either hole. One of the holes takes a 3/8-16. I got some grade 8 bolts at the hardware store.
    The other bolt hole was something completely different. Is it possible that it's a Whitworth thread?
    On the driver's side the 3/8-16 is the front bolt. On the passenger's side, the rear bolt.
  22. enio45
    enio45 Formula 3
    1,533
    Gilbert, AZ
    Ed
    mine were both the same as i mentioned - however the 3/8 - 16 on the front, im sure u can clean the threads to make
    it work in the rear as well - at least so they are interchangeable ....if u need
  23. turbo-joe
    Apr 6, 2008
    8,867
    romano schwabel
    that is usual: the screws for saftybelts worldwide are inch sizes, not metric
