News
348 Seatbelt conversion
Discussion in '348/355' started by dvelez2, Feb 22, 2021.
  1. dvelez2
    dvelez2 Karting
    Jan 20, 2016
    66
    Daniel A. Velez
    I did a quick survey and did not find a thread on how to convert an active seatbelt system to passive. Has anyone out there done it?
  3. vjlax18
    vjlax18 Formula Junior
    636
    Nottingham, MD
    I did it with my 1990. I switched to the normal style or euro style belts. I found a set of euro trim pieces and just cut the opening in the black trim. The mounting points for the belts are there by the B pillars and it's easy to pull the seats and put the receiver on the correct side of the seat. I pulled the fuse for the mouse tracks.
    Qavion and axarunner like this.
  4. axarunner
    axarunner Karting
    Sep 8, 2019
    72
    Glen Ridge, NJ
    Dan Murphy
    Did you purchase OEM European seat belts or did you go with generic belts? I'm in the process of converting to the euro active system (I too found some euro trim pieces). Thanks
  5. vjlax18
    636
    Nottingham, MD
    I purchased belts for a different car that bolt right in, but I would have gone with belts from Superformance if they had them at the time. (I think it's Superformance that had them now)
  6. chopsui
    chopsui Karting
    Feb 27, 2019
    80
    Did the same with my 1990 only I just used 355 belts and trim pieces. They're usually easy to find on eBay.
    axarunner likes this.
  8. vjlax18
    636
    Nottingham, MD
    Did you drill out the spot welds in the middle housing? I have yet to do that, but the center trim is waiting to be installed after I do it.
  9. dvelez2
    dvelez2 Karting
    Jan 20, 2016
    66
    Daniel A. Velez
    Let’s see some pictures of the process!
  10. dvelez2
    dvelez2 Karting
    Jan 20, 2016
    66
    Daniel A. Velez
  11. To remove this ad click here.
  12. chopsui
    chopsui Karting
    Feb 27, 2019
    80
    Not sure what you mean. I don't recall any spot welds.
