Seat Removal | FerrariChat
Seat Removal
Discussion in '348/355' started by arthurhoyle, May 18, 2021.
  1. arthurhoyle
    arthurhoyle Rookie
    May 16, 2021
    20
    Australia
    Arthur Hoyle
    The driver's side seat (this is a right hand drive car) seems to have become stuck in the rearmost position, and despite my best efforts will not slide forward. Lifting the guide control fork (as it is described in the parts manual) doesn't release the seat. I can see the two front screws holding the guide rails, but as the seat doesn't move forward I can't get to the two rearmost ones. Any ideas?
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    Not sure if you tried this but sit in seat
    Pull up on bar and grab steering wheel and pull forward
    Mine got stuck one time and this worked
    You can not get enough leverage without sitting in the seat
  3. arthurhoyle
    arthurhoyle Rookie
    May 16, 2021
    20
    Australia
    Arthur Hoyle
    Thanks Taz. I've tried that, but I'll certainly give it another go with a bit more effort
  4. Tony Moore
    Tony Moore Rookie
    Oct 16, 2019
    17
    Surrey UK
    Tony Moore
    This may or may not help, but I replaced my seats with 355 ones and had the same problem. I was able to go down a gap between the seat squab and the side bolsters and press down on a shiny metal lever (each side) that lifted the mechanism and released the seat. I know my original 348 seats you wouldn't be able to do this, but some I think you can..
    Qavion likes this.
  5. arthurhoyle
    arthurhoyle Rookie
    May 16, 2021
    20
    Australia
    Arthur Hoyle
    Thanks Tony. I'll give it a go tomorrow. You never know -)
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    IF all else fails, remove the bottom panels, and from the bottom drill out the two bolts you cannot see.
  7. arthurhoyle
    arthurhoyle Rookie
    May 16, 2021
    20
    Australia
    Arthur Hoyle
    Yes, I was afraid of that but at least it is an option... Thanks
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    Have you ever had to do that Mitchell
    And if you did what was the root cause?
  9. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    I had to to that on a 328 once. The seat was frozen because of old grease and bearings. I almost had to do that on a 355 Spider because the motor drive cable was pulled out and the seat did not move back or forth (Spider has different seats than the manual Berlinetta seats).
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    Gotcha thanks
    By the way thanks again for all help
    Engine is back in
    Hopefully this weekend will replug everything in
