Seat bolster ware? | FerrariChat
Seat bolster ware?
Discussion in '458 Italia/488/F8' started by Tim Ryan, Jul 23, 2020.
  1. Tim Ryan
    Tim Ryan Karting
    Jul 3, 2020
    64
    Lincoln, California
    Tim Ryan
    Hi,
    Does anybody have any good ways to protect the seat bolster from ware?
    I try avoiding rubbing the seat bolster while entering or exiting the vehicle, but I tend to rub the bolster.
    Thank you?
    Tim
    2017 488 Spider Black on Black
  2. SoCal to az
    SoCal to az F1 World Champ
    14,963
    Arizona
    I know there are some companies that make aftermarket parts for the Porsche bucket seats to protect from wear on the bolsters, but am not aware of anything like that for the seats for the 488.
  3. Tim Ryan
    Tim Ryan Karting
    Jul 3, 2020
    64
    Lincoln, California
    Tim Ryan
    Thanks SoCal to AZ, I'll keep looking! For now I'll add a little more leather conditioner!
    Tim
  4. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,168
    AUSTRALIA
    ANGELO
    What seats ? I have full electric so before I turn off the ignition I hit memory 1 ups seat all the way back and the seat back back and the steering wheel into the dash. Then i slide in arse first then swing legs. Don't even touch the bolsters. Then touch memory 2 and back to driving position
    If you have goldrake you can manually do the same i guess but it so easy with electric
    rob5819 likes this.
  5. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    Tim,
    I posted this before. Do not know if it you happened across it. I hope it will help you as much as it does me. I can say I have had 5 Ferraris with dealer always remarking on my LACK of bolster wear.
    First, I always slide my seat back before exiting the car. This gives you the most clearance/space to maneuver. It is simplest with the race seat as no motor to contend with.
    If entering car, I put right leg in. I then reach down with my left arm and place it on the rocker. I can now support my body weight on the right leg and left arm. I then slide my left leg in. At this point there is no trick to supporting all your weight as it is on both legs and the left arm. Now that you have cleared the bolster and can slowly lower yourself into the seat. Using this method you can stay off the bolster easily.
    Getting out is almost the reverse. I put right hand on top of wheel for balance and left arm on rocker. I push up on left arm which raises me out of seat. I then put left foot on ground and just pull right leg out with little trouble. Left leg and left arm do most of the work. Bolster never touched.
    If you are in England driving on the right side then just reverse my hand positions. LOL
    Best
    Randy
    Napoli, Thecadster and rttj777 like this.
  6. Tim Ryan
    Tim Ryan Karting
    Jul 3, 2020
    64
    Lincoln, California
    Tim Ryan
    Hi Randy,
    Thanks for the info!
    I have the electric seats and Telescopic/Tilt wheel.
    I'm rather tall and not very flexible, I do use the left had for support on the door sill and have my seats all the way back. I try not to rub the seats but it happens.
    Tim
  7. Randyslovis
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    Damn!
    Oh well. I tried.
    Airplanes and sports cars are the only time my lack of height has an advantage!
  8. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    I do something similar to Randy, but place my left palm on the seat bolster.
    So at the very most, I only brush against my own hand.
    I always get comments remarking on my lack of bolster wear.
  9. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Whenever I get out of car I put seat
    I do the same and have the golddrake seats, almost find it easier than electric since it's much quicker to adjust manual seats
  10. MANDALAY
    May 23, 2013
    14,168
    AUSTRALIA
    ANGELO
    Definitely quicker but speed for me isn't an issue being a 488 GTB I always let the engine idle 3 minutes before turning off
  11. bruno787
    bruno787 Karting
    Nov 1, 2010
    200
    PHILIPPINES
    bolster scuff or wrinkles?
  12. Napoli
    Napoli Formula Junior
    Nov 18, 2017
    958
    NOYB, Ray!
    Alcantara.
  13. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,203
    Austin, TX USA
    Greg
    *wear
  14. ferrarifam
    ferrarifam Karting
    Jun 9, 2020
    91
    Utah, USA
    Adam
    Can you post a video of the process you use to get in and out. Would like to see how this is done by pros.
  15. Randyslovis
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    And risk going viral?!
    I will try and enlist my wife to film it and my daughter to post it!
    Best
    ferrarifam and Cigarzman like this.
  16. Cigarzman
    Cigarzman F1 Veteran
    This should be interesting. Can’t wait. Best , Kirk.
    AD211 likes this.
  17. tonyswfla
    tonyswfla Formula Junior
    823
    Florida
  18. AD211
    AD211 Formula 3
    Owner Rossa Subscribed Silver Subscribed
    Aug 19, 2017
    1,201
    South Carolina
    Andy
    Why is that?
  19. MANDALAY
    May 23, 2013
    14,168
    AUSTRALIA
    ANGELO
    I have always allowed the engine to idle on turbo engines for 3 minutes before turning off. Turbos a bloody hot so allowing oil to circulate is better than turning them off immediately
  20. AD211
    AD211 Formula 3
    Aug 19, 2017
    1,201
    South Carolina
    Andy
    Great to know. Thanks.
  21. adesalos
    adesalos Formula Junior
    Mar 19, 2003
    251
    Texas
    interesting question... what about in the case of carbon race seat (challenge stradale)?
  22. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,795
    I love this thread!
    I seriously would never admit to worrying and or thinking about all of these thoughts..
    I am truly relieved to see that I am not as simgularly neurotic as I had assumed.
  23. MANDALAY
    May 23, 2013
    14,168
    AUSTRALIA
    ANGELO
    You are well beyond about thinking about these thinks because you have driven your car to the max . But I wouldn't be surprised your bolsters look bad , really bad.
    Ive had cars where I looked after them like a baby . Once I had a have a few scratches , stone chips etc I reach a point that I just don't give a rats arse . But they aren't Ferrari's
  24. MalibuGuy
    Sep 18, 2007
    5,795
    no I think I didn’t make my point clear.
    I’ve thought about all these things but wouldn’t care to admit them to others.
    I was afraid people would think I was a little crazy
    (Perhaps I am when it comes to cars and some other things too)
    MANDALAY likes this.
  25. MalibuGuy
    Sep 18, 2007
    5,795
    Poltrona Frau makes the best wrapper in the business.(You will find the PF label inside the door panel on the passengers side).
    the leather is fully abalone meaning it has a special highly durable coating to protect it against chemicals water spots and fading from the sunlight.
    If the surface gets worn off, there are repair options which avoid replacement. Ask your service center for an experienced leather man who can ‘ re-paint’ the worn areas. I ve done this before—later bought the color liquids and done it myself with a small paintbrush.
