sealing up fuel line pipe threads | FerrariChat
Discussion in 'Technical Q&A' started by cavallo_nero, Jan 5, 2012.
  1. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Ever since I fuel injected my 308 and used a hi pressure fuel pump I am having the worst time sealing up the pipe threads that go into the pump. I have tried many things, Teflon tape, gas pipe sealant and now a special sealant made for fuel line fittings. Both lasted about a year, then I get leaks around the fittings. Anyone have a good remedy for sealing up the pipe fittings for gasoline?????
  2. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
  3. Steve Magnusson
    26,509
    Almost always, the threads are not where the sealing should be occuring in a high pressure fitting -- unless you are literally using an NPT tapered pipe thread (the threads usually only apply the clamping load to bring the sealing surfaces into contact). Can you better describe the fitting type that you are using, and where you are applying the sealant?
  4. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    this is a NPT (tapered) pipe thread into the body of the fuel pump(mallory 4060FI), there are 3 fittings that are pipe thread.
    thanks for the responses so far.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Is it possible that the fittings bottomed-out in the holes in the pump before the tapered thread was tight?
    Pipe fittings with teflon tape on them shouldn't leak if tightened properly (not over-tightened).
  6. Steve Magnusson
    26,509
    #6 Steve Magnusson, Jan 5, 2012
    I like Tim's thought and Bill's recommendation (if it's a metal-to-metal connection) -- Loctite 565 or 592 are also very similar to that Permatex product (and also should only be used on a metal-to-metal connection).
    But I'm amazed that they used a pipe thread -- that makes more sense when the (hard) pipe and fitting are all one piece (and the hard pipe OD is the same size as the tapered thread maximum OD). Is that what you have -- an all hard pipe system (which might have vibration troubles IMO), or is there another joint between the tapered pipe fitting that goes into the fuel pump and a flexible tube delivery system?
  7. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #7 cavallo_nero, Jan 5, 2012
  8. Steve Magnusson
    26,509
    #8 Steve Magnusson, Jan 5, 2012
    Which is worth a thousand words ;)
    You do have a fair bit of (unsupported) mass hanging off of that inlet fitting -- are you having leakage trouble at all three fittings or just the inlet fitting (your initial post says "I am having the worst time sealing up the pipe threads that go into the pump", but later on "...then I get leaks around the fittings")? If just the inlet fitting, you might try better supporting the free end of the hard structure where it joins the rubber hose from the tank (maybe add something to tie the end of that filter? to the top of the fuel pump motor -- like a hard "saddle" piece of rubber between the body of the filter and the body of the motor and then a band clamp around both) -- could be moving around quite a bit during operation (relative to the motor) and putting a lot of stress on the sealant in the threads of the inlet fitting (and the sealant isn't designed for that) -- just a thought...
    PS Can you confirm what sort of fuel pressure you are working with -- is it something like ~3 bar (~45 psi)?
  9. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    hi Steve, i am leaking at all 3 fittings, especially the one on the bottom. since the pic was taken, i HAVE supported the inlet configuration. This will be the fifth time i had to take the fittings apart and seal them up, so i want to get it right this time. Incidentally, i am on my 3rd pump - the seals fail and i get fuel leaking out the weep holes.
    Correct, i am running 45 PSI through a regulator, and will be using non ethanol gas from now on (hopefully that will make these pumps last longer).
  10. Steve Magnusson
    26,509
    Can't fault the mounting of those other fittings so let us know if one of those curing-type sealants perform any better.
  11. mwr4440
    57,741
    Bavaria, The 'Other' Germany
    Mark W.R.
    Man that thing hangs SCARY low .........
    :eek:
  12. ago car nut
    ago car nut F1 Veteran
    5,463
    Madison Ohio
    David A.
    I have had so much trouble with aftermarket fuel pumps that I would not recommend them.
    Ago
  13. BMWairhead
    BMWairhead Formula 3
    Sep 11, 2009
    1,052
    Portland, OR
    Ted
    Just looking at the set-up and how it might be improved...
    I would get rid of the 90* blue anodized fitting and the adapters to the filter. Replace it with a fitting like the straight brass fitting that is directly opposite of it. The advantage of the straight fitting is that you can tighten it properly without any regard to orientation. (it kind of looks like you might be over-doing the teflon tape...perhaps in an effort to get the blue 90* to seal AND point up...?). From the straight fitting, run a soft line 90 degrees up and support it with a clamp at the mounting bolt for the fuel pump. Then, attach the filter between the two soft lines...both of which have their own support separate from the pump...
    More things would be isolated from pump vibration and movement...it sure can't hurt and will probably help some.
  14. Cribbj
    Cribbj Formula 3
    #14 Cribbj, Jan 6, 2012
    Along the lines of what BMW AH is saying, I'd be tempted to dump the whole Mallory setup, and put in an inline Bosch, which is already rated for up to E85, and will probably last until you give the car to your grandkids.
    I'd mount it to a frame rail in a cradle with a foam isolating sock to reduce any transmitted noise and put a screen type filter on the inlet and a good filter on the outlet.
    Kinsler's prices are a bit high, but you can get a good idea from their website what you need: http://www.kinsler.com/handbook128.html
    This pump does 100 L/hr, and it also comes in 165 L/hr and 200 L/hr sizes.
  15. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    Is the pump solid mounted or is it mounted using those little rubber feet with a stud at both ends? If solid mounted it is shaking those fittings constantly. Rubber mounting would dampen that vibration.
  16. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    #16 Peter, Jan 8, 2012
  17. mwr4440
    57,741
    Mark W.R.
    If someone wants an OEM Bosch fuel pump let me know and I'll see what I can do.
    LOTS of (old) Bosch products are NOT sold outside of Germany and/or Europe.
  18. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    thanks for all the good advise. It is hard to find a fuel pump that delivers 45 psi to support my FI setup. that is not teflon tape you see, it is sealant. the fitting on the bottom is mainly the culprit. the blue fitting on the side doesnt appear to be leaking as bad as the brass fittings. i will look into supporting the filter assembly better. most pumps do not have a return provision (the fitting at the bottom of my pump). i dont think that inline bosche pump has a return (overlow). If someone can find a suitable pump that delivers 45 psi and has a return fitting, i would be interested....
  19. Steve Magnusson
    26,509
    Any specific reason that you can't route the return line to the top of one of the tanks instead of the pump inlet?
  20. Sigmacars
    Sigmacars Formula 3
    1,187
    I hope you will make a shield under it the hoses are so low you could get stone damage or anything flying from the road or the track at it.you would feel a lot saver
  21. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i thought the pump needed a return line for bleeding purposes. this pump doesnt hang any lower than the stock pump and filter. i have had it on the car like that for over 5 years now with no incident. sheilding the lower hoses cant hurt though, i can look into that.
  22. Steve Magnusson
    26,509
    I don't believe so -- aren't the small return fitting port and the inlet fitting port just connected directly together inside that aluminum piece (i.e., same functionally as "T"ing the return line into the inlet line or running the return line back to the tank)?
  23. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #23 cavallo_nero, Jan 16, 2012
    i did a lot of research, and have decided to go with Gasoila E seal, designed for ethanol based fuels. this stuff is specially designed for solvents like gasoline and alcohol. i will let you know how it all works out.
  24. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #24 cavallo_nero, Jan 23, 2012
