News
SD2 and SD3 software collection?
Discussion in 'Technical Q&A' started by ForzaLaVida, Jan 1, 2021.
  1. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    Hello, I'm looking for any and all SD2 and SD3 software/car config files. I'm more than happy to share what I have for the SD2.
    Ray Smith and 2NA like this.
  3. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    #2 ForzaLaVida, Jan 1, 2021
    Ray Smith likes this.
  4. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    Made some more progress! Got shell access to the SD2 tester! Checking commands now, but should be pretty easy to change the active model to Maserati!
    JazP and MCASEY like this.
  5. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    Good news!
    I can now change the mode of the SD2 between Ferrari, Maserati, and Both!
    The startup splash changes to just "SD2" when put in Both mode.
  6. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    More good news! I have acquired the SD3 model, and will include that software in the VM image i'm working on.
    MCASEY and ChipG like this.
  8. JazP
    JazP Rookie
    Feb 23, 2013
    27
    Would you like to explain your project a bit? Are you working on a VM that can run the SD Software? So that I can use it to diagnose my car? I guess I'd need a piece of Hardware to connect the VM to my car then, or?
    MK1044 likes this.
  9. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    Hi, The VM will have all of the Ferrari software preinstalled, I'll include the pile of documents,schematics, and pics that I have in my collection. This project is aimed at giving everyone access! I am indeed slowly logging the SD2 and SD3 request and set commands so that we can be rid of all of these expensive and hard to find tools for the F cars, and allow us to use open hardware/software. I love the cars, but I do not like the hoops and money spent to work on them.
  10. JazP
    JazP Rookie
    Feb 23, 2013
    27
    Then your idea is to extract the secrets from the SD (protocol, commands, answers)? Or is your target to create a VM that runs the SD Software? Thanks for sharing this with the community!
    When I open the link you posted in #2, I find a screenshot. Is there anything else inside?
  11. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    It's both, for now, the VM will contain all of the software and documents I have collected, later on ill develop the hardware that can be used with the F-tools installed, but for people that already have the tools, this gives them easy access to everything in 1 shot.
    MCASEY likes this.
  13. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
  14. ssgharkness020147
    ssgharkness020147 Formula Junior
    270
    Midwest
    Wow! That’s a very cool project. Though I don’t know that our friends in Modena would be as enthusiastic.
  15. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    Perhaps not, we shall see. I should have Khalid's Maserati SD2 here soon, and i'll be able to demo the maserati version, sporting Ferrari diagnostics.
  16. Skippr1999
    Skippr1999 F1 Rookie
    3,016
  17. PaulK
    PaulK F1 Rookie
    3,963
    Michigan
    Paul
    If you can pull this off so I can access my 2.7 Motronic F355 I will be a very happy man. Someone needed to do this!
  18. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    #16 ForzaLaVida, Jan 10, 2021
    My tuning software has definitions for the 355 motronic 2.7 ecu's, and give me a second, but I think I have the 2.7 f355 diag files.
    EDIT: Yes, I should be able to work on the 2.7 ecu's as soon as I'm done with the F1 system's, I also have a 360 CS TCU coming so I can start on it. along with several wiring harnesses for different cars, and a whole host of other small things I think will help out.
    PaulK likes this.
  19. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
  20. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
  21. JazP
    JazP Rookie
    Feb 23, 2013
    27
    Great stuff, thanks a lot for sharing! I was able to install SD1 and SD2 in a VM. But of course I couldn't do much with it as I have no tester hardware.
    Do you think it is possible to connect a generic tester? Or is it "dongled" with the original Ferrari equipment?
    By the way: Is this the original Software, e.g. the one that runs on the diagnostic computers?
  22. Ricambi America
    Sponsor Owner
    LOL. You'll be making friends quickly.
    And by 'friends', I don't really mean 'friends'
    SingleClutch and Island Guy like this.
  23. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    The PC end of the software does load the handheld tester applications, but consider it to be a 2 part deal, first part allows testing from PC while the tester is just the interface, the second part is the loading of the tester applications to the handheld device for standalone use (with limitations) some software can only be ran from the PC due to size.
    Since the PC software wants a COM port for connection, there is a "handshake" that happens. that will be easy to capture. It's possible to make a dumb interface for the sd2 software, I'm just not there yet.
    2NA likes this.
  24. JazP
    JazP Rookie
    Feb 23, 2013
    27
    Can imagine that. I spent $5000 for a Galileo Diagnostic tool some time ago.
    I'm looking forward for that! In the end all older models use K-Line anyway. There are cheap adapters. They are USB, but a COM adapter should be easily possible, too. K-Line is (protocol-wise) very similar to serial COM (except for init).
    Please let me know if you need support for your project.
  25. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    #23 ForzaLaVida, Jan 11, 2021
    The Galileo is a perfect example of making a profit, by reverse engineering the commands sent and received, using official tools. No one has stopped them.
    The K-2000 protocol is super easy stuff, for example, the 430 TCU, uses slow init for the first wake up then switches to fast init for reading/writing.
    As things progress I'm certain help will be needed and I appreciate the offer, Not many people on here have even bothered to reply. No matter, progress will be made in time. Right to repair is becoming a bright subject in america. https://www.repair.org/stand-up
    Also, Thanks to another contributor, we now have the other 2 maserati cars, diagnostic files!
  26. Skippr1999
    3,016
    Great project !!
  27. ForzaLaVida
    ForzaLaVida Karting
    60
    Deltona Fl
    Tom Dodd
    Thanks, Just trying to help you guys out.
