Scud Ing Swiss Smart F1 Relay | FerrariChat
Discussion in '612/599' started by TrojanFan, Oct 12, 2017.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,194
    So. CA & NV
    Peter
    Anyone have any experience with this or any thoughts on it for use in a 612? There was some discussion from guys who have installed it in there 430's. Also reported to give smoother shifting.
    https://www.scuding.com/Shop/en/ecu-solutions/101-smart-emt-relay-ecu.html
    "This Plug&Play pure electronic solid state Smart eMT F1 Relay ECU is a direct replacement of the OEM robotized gearbox hydraulic pump relay like for the F1/E-Diff of Ferrari. With our embedded software, this ECU will greatly improve the reliability of your car and will help to prevent very expensive hydraulic system failures."
  2. tazandjan
    39,370
    Should work fine as a reliability upgrade, but any reports of improved shifting are slightly (highly, actually) exaggerated.
  3. TrojanFan
    Nov 17, 2008
    5,194
    So. CA & NV
    Peter
    Has the Relay failure been a big issue?
  4. swiss612
    swiss612 Formula Junior
    May 10, 2016
    252
    Zurich
    Michel
    I don't think relay failure is a big thing, I have never heard of it, but dir hear of F1 systems needing to be replaced
    I bought one, and will try it on the 612 as soon as I receive it
    The stuff is not only an expensive relay, it helps you protecting the downstream equipment by shutting down the system if anything runs abnormally, it also gives you the diagnosis of what might be failing
    TrojanFan and Makuono like this.
  5. TrojanFan
    Nov 17, 2008
    5,194
    So. CA & NV
    Peter
    Keep us posted on how the relay works for you in the 612.
  6. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Can someone show the location of the F1 pump relay on a 599? Mike
  7. Mor_wroc
    Mor_wroc Rookie
    Oct 14, 2017
    3
    In 599 You need to take out battery cover. It’s inside there.
    I’ve also mounted the F1 relay mase by Scud Ing Swiss, removing the old 50a relay. One month later everything is Ok.
    Wysłane z iPhone za pomocą FerrariChat
  8. Mor
    Mor Karting
    Oct 14, 2017
    95
  9. afwrench
    Nov 24, 2004
    593
    NY
    Hi "Mor", thanks for the pic. Mike
  10. Mor
    Mor Karting
    Oct 14, 2017
    95
    I have same problem with new relay. Somethimes when I just open the trunk, then drivers doors, F1 pump won’t start so I can’t start the car. If it happened, I need to disconnect battery (master switch open). I need to contact with scud ing swiss what they think about it.
  11. RichardCH
    RichardCH F1 Rookie
    4,661
    NO smoother shifting thats BS
  12. Mor
    Mor Karting
    Oct 14, 2017
    95
    Of course not. But I don’t need to worry about pump working time.
  13. afwrench
    Nov 24, 2004
    593
    NY
    Hi "Mor",when I installed my relay the 85/86 switch was in the wrong position.No pump, no shift,no trunk.After I switched it all is well.Perhaps yours is not pushed all the way to the proper position.I" think" it needs to be on 85.Good luck,Mike
  14. Mor
    Mor Karting
    Oct 14, 2017
    95
    No, it’s not the problem. 85/86 switch is Ok. It happens only somethimes. I’ve contacted with scud ing swiss and they will send me a new unit. They also ask me, Could I send them back the fault ecu to check what the problem is. So I’m waiting for the shipement and will put new one relay in my 599.
  15. afwrench
    Nov 24, 2004
    593
    NY
    Hi "Mor",please keep us all informed.Mike
  16. swiss612
    May 10, 2016
    252
    Zurich
    Michel
    I have installed and run the smart F1 relay
    It is a good product and does the job, my gearbox was not sick, so nothing to diagnose
    Big advantage of this system to me is the suppression of the power surge when the pump goes on
    This translates into less flickering of the instrument panel (I see less because it still happens when cooling fans go on) and the fact that the battery tender does not put itself in default anymore when you open the door, this is also due to the suppression of the power surge created by the electromechanical relay
    One can only imagine that these surge are destructive for the car electronics.
    Shift quality, I cannot tell the difference, my 612 has very little mileage (12K) my original relay was like new when I opened it. I guess the guy that has an old relay will probably note something, but this is not the main point of this device, as a new relay will just be cheaper
    This relay is a peace of mind regarding your F1 system, this is why I bought it in first place
    Some pictures of my 612 installation, you need to take the battery out if you want to do a clean job
    I have attached the picture of my 612 installation Image Unavailable, Please Login Image Unavailable, Please Login
    TrojanFan, Makuono and ZDF_Fan like this.
  17. Mor
    Mor Karting
    Oct 14, 2017
    95
  18. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    214
    Madrid, Spain
    F3RN
    Hi Mor,
    Any further news, mate ?
  19. Mor
    Mor Karting
    Oct 14, 2017
    95
    The new relay is Ok, No more problems.
  20. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    214
    Madrid, Spain
    F3RN
    Great, thanks!
    Happy New Year.
    Mor likes this.
  21. Shahz
    Shahz Rookie
    Oct 9, 2015
    35
    Geneva / Dubai
    Shahz. K.
    Hi,
    Is everyone still happy with the SwissSmart F1 relay ... i was thinking to get one
    Would you really recommend everyone to upgrade ?
    Shahz
  22. afwrench
    Nov 24, 2004
    593
    NY
    No issues with mine. Mike
  23. Mor
    Mor Karting
    Oct 14, 2017
    95
    Recommend it too
  24. HK Mondial
    HK Mondial Karting
    Mar 12, 2007
    89
    Mark M.
    Yep, mine works fine too !
    Hadn't had problems with the old one either, but when we replaced it ,we found evidence
    of burning on it around contacts
