Scud Ing E-Diff bypass review | FerrariChat
Discussion in '360/430' started by swc5150, Aug 31, 2023.
  1. swc5150
    swc5150 Formula Junior
    696
    Wisconsin
    Scott Calderwood
    After reading some reviews on the E-Diff bypass, I wanted to try one for myself so I went ahead and ordered one. First off, it arrived very quickly, considering it came from overseas. Then installation was easier than setting the clock on a microwave.
    Driving impressions:
    I did a back-to-back drive, with and without the bypass to avoid a placebo affect. Slow speed maneuverability is much better without an active E-Diff. We have a roundabout in the neighborhood, and the car zings around it much snappier/nimble now. I then got it out on the winding WI back roads, and the car is much more alive. I really had no idea how active the E-Diff was until no longer using it. Perhaps the e-diff can keep you out of trouble, but for me, the car is much more fun to drive without it. I also noticed the F1 pump not activating as much, and when it does, it's for shorter durations. Shifts are brisk as well, but I also tightened the PIS, so I can't honestly attribute that to the bypass. Overall, I'm very satisfied and think it's money well spent.
    Hazim and Plainview like this.
  2. swc5150
    696
    Wisconsin
    Scott Calderwood
  3. BlacktopRacing
    BlacktopRacing Formula Junior
    993
    Pittsburgh
    Dale
    How is this different than just completely turning off CST (remember, there's regular CST off and then completely CST off by holding the manetino for a couple of seconds).
    flash32 likes this.
  4. swc5150
    696
    Wisconsin
    Scott Calderwood
    I wasn't aware it was possible to disable the E-Diff in CST? I always drive in Race mode, with the other nanny systems on, so that's where I noticed the difference with E-Diff off.
  5. Mario Andretti
    Mario Andretti Formula 3
    1,743
    Boston
    #5 Mario Andretti, Sep 1, 2023
    How do you do that? There is nothing in the manual about holding it ... only CST off mode where it deactivates it.
    Also, I read about scuding swiss bypass that it still keeps the stability and traction control enabled ; how is that possible with the e-diff disabled, I thought e-diff is doing all that ?
    Quote:
    " Even if the E-DIFF is disabled, the F430 retains all brake & traction control systems such as CST (ASR / VDC), ABS, ESP and EBD."
  6. swc5150
    696
    Wisconsin
    Scott Calderwood
    The E-Diff is separate from the other nanny controls.
  7. Mercedes_Benz
    Mercedes_Benz Formula Junior
    509
    South Florida
    I ordered it too but have yet to install it. I got the permanent off version with the bypass plugs...
  8. swc5150
    696
    Wisconsin
    Scott Calderwood
    I may now order the plugs too, since I’ll be doing my clutch over the winter and will be deep in the bay anyway.
    I’ll be curious to what your take is on it. I took the car out again last night and it is driving great. It was Ferrari’s firsts attempt at an e-diff, so it doesn’t surprise me that it wasn’t completely dialed in.
  9. Mercedes_Benz
    509
    South Florida
    I am curious too! I will possibly make a post about it once I try it next week hopefully.
  10. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    772
    Bay Area, CA
    I still don’t understand why anyone would want to disable the ediff as you will have an open diff.
    a friend installed the bypass which resulted in his 430 becoming a “one-legger” out of corners on track which severely impacted drive out of the corner.
    DOWORKFCAR likes this.
  11. LorenzoR
    LorenzoR F1 Rookie
    The question I have is why would anyone tracking a car install a ediff bypass. I'd never do that
  12. boostedt0y
    Dec 25, 2014
    772
    Bay Area, CA
    ediff warning lights and car going into limp mode. Needed the bypass to salvage the track event.
  13. swc5150
    696
    Wisconsin
    Scott Calderwood
    I’m can simply pull the bypass on the track. On regular roads, the car drives better bypassed. Anyone is free to do whatever they want, but I’m really liking the bypass. My car just drives better.
    Mercedes_Benz likes this.
  14. Mercedes_Benz
    509
    South Florida
    I agree. I only got it because it seems I may be having e diff issues from my aftermarket 20" wheel/tire setup. But I will confirm this soon.
    As for tracking a car, I personally would not want an open diff on the track either, so I would not want to use the bypass on the track IMO.
    boostedt0y likes this.
  15. swc5150
    696
    Wisconsin
    Scott Calderwood
    I’m heading to the track at the end of the month and will try it out both ways. I’m no pro so it may not make a difference regardless:)
  16. boostedt0y
    Dec 25, 2014
    772
    Bay Area, CA
    Yes, it feels more playful on the street at slow corners because the diff is not locking up in the corners reducing the amount of under steer. But I’m sure you’ll experience the one leg situation coming out of corners in the street depending on how aggressive you are on the throttle.
    When installing a clutch type LSD on my other sport cars I noticed a reduction in playfulness as well but was rewarded with increased corner exit grip exiting under heavy throttle and a stable rear end under hard braking applications.
    but as you said, if you’re happy with it that’s all that matters.
  17. swc5150
    696
    Wisconsin
    Scott Calderwood
    Is it really becoming a one legger? I did a quick “test” and laid down two tire tracks on a hard launch. Seems to me like the “posi” traction is still there and it’s not an open diff like we think?
    LorenzoR and Mercedes_Benz like this.
  18. boostedt0y
    Dec 25, 2014
    772
    Bay Area, CA
    Try it coming out of a corner…
    I’ve had a few emails back and forth with Stefan about the bypass and there is some inherent amount of lock still available with the bypass, but he was unable to quantify how much. But for sure the amount of lock in the bypass diff will be significantly less than a fully functioning ediff.
    DOWORKFCAR and swc5150 like this.
  19. swc5150
    696
    Wisconsin
    Scott Calderwood
    Ah ok that makes sense!
  20. swc5150
    696
    Wisconsin
    Scott Calderwood
    I’ll pull the bypass on track day. I threw my last 430 sideways out of a corner and it’s not a fun feeling. Track insurance!
  21. boostedt0y
    Dec 25, 2014
    772
    Bay Area, CA
    Nothing a little opposite lock and throttle can’t fix ;)
  22. RobinMasters
    RobinMasters Karting
    Dec 31, 2022
    53
    Bill Bodner
    Which version do you have? I have the smart e-diff bypass version and you can enable/disable the e-diff via a keychain remote. You can also program it to disable the e-diff in certain manettino settings. I guess I’m in the minority in that I’m not a fan of e-diff on the track.
    As you correctly noted when the e-diff is disabled you have a standard limited slip rear end. Like you said, think positraction in a 60s muscle car. It’s not an open differential as others have suggested.
  23. boostedt0y
    Dec 25, 2014
    772
    Bay Area, CA
    The following statement was directly from Stef when I inquired about whether the disabling the ediff will function as an open diff.
    “The SEB ECU will allow you to disable the E-DIFF and your differential will become a mechanical LSD but with limited lock ratio, less than a 100% mechanical LSD. It's very difficult to evaluate exactly how much and when the differential will lock”
    will you still have some lock with the disabled ediff? Yes, but the amount is unknown. But from the experience of other 430 owners who track their car running in the fast group with R compound tires, the disabled ediff functions more like an open diff.
    To me, this makes sense given the ediff uses a hydraulic actuator to engage the friction discs,clutch plates to lock the diff rather than a mechanical mechanism (e.g., a spring) in a mechanical lsd. Disabling the ediff causes the e diff solenoid valve to stay closed so no hydraulic fluid flows through the e diff. Without the flow of hydraulic fluid how can the hydraulic actuator lock the diff?
  24. Mercedes_Benz
    509
    South Florida
    his picture shows he has the permanent disabled version.
    swc5150 likes this.
  25. Mercedes_Benz
    509
    South Florida
    Although I won't disagree. I am wondering how many of the guys saying it feels like an open diff on the track are just comparing it to what they were used to feeling with a fully functional e diff. Maybe it's just a different feel than they were used to? No doubt this diff was designed to work with the e diff of course. To the OP who said he laid down some rubber, how much was it? was it a few inches? or were we talking a few feet? if it was a few feet, not many open diffs would be able to do that.
