SCD TV Video: 330 GT 2+2 v GTC4 Lusso. | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by miurasv, Dec 12, 2020.
  1. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,034
    Cardiff, UK
    Steven Robertson
  2. Ferrari_250tdf
    Ferrari_250tdf Formula Junior
    Mar 3, 2005
    462
    Very nice video. Interesting is the dashboard of the 330 which I haven't seen before. It looks like a mix of 330 and 365 GT 2+2. Which chassis no. is it?
  3. miurasv
    Nov 19, 2008
    10,034
    Cardiff, UK
    Steven Robertson
    Don't know chassis number. Appears to be car here.
  4. 330gt
    330gt Formula 3
    Nov 12, 2004
    1,982
    Seattle, WA
    Kerry Chesbro
    8401, a series II 330 GT.
    miurasv likes this.
  5. miurasv
    Nov 19, 2008
    10,034
    Cardiff, UK
    Steven Robertson
    Did you update the site 330gt.com today, Kerry? I looked earlier and couldn't find it.
  6. thepinkumbrella
    thepinkumbrella F1 Veteran
    Feb 26, 2006
    6,047
    United Kingdom
    Kerry knows his stuff...
    Paul
  7. miurasv
    Nov 19, 2008
    10,034
    Cardiff, UK
    Steven Robertson
    I know.
  8. 330gt
    330gt Formula 3
    Nov 12, 2004
    1,982
    Seattle, WA
    Kerry Chesbro
    Yes, the registry has been updated.
    You may have to do a refresh in your browser to see the current version.
    miurasv likes this.
  9. thepinkumbrella
    Feb 26, 2006
    6,047
    United Kingdom
    The ‘Pete’ you mention didn’t acquire the car in November 2020, he was the seller (via DK)...but I already told you that.
    Paul
  10. Pmo75
    Pmo75 Karting
    Jan 17, 2016
    59
    Interesting take with the quilting on the tunnel cover...
    not correct and more bling than the understated nature of the car, but nice touch.
  11. 330gt
    330gt Formula 3
    Nov 12, 2004
    1,982
    Seattle, WA
    Kerry Chesbro
    My error, fixed.
  12. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    Bling, Bling, Bling: The area under the rear window has this treatment also. I suspect that the more you look the more bling that you would find. I wonder what the engine compartment looks like.
  13. miurasv
    Nov 19, 2008
    10,034
    Cardiff, UK
    Steven Robertson
  14. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    Thanks for the photo.
    Very little bling in the engine compartment. Maybe too little. Should not the air filter housing be semigloss? The tubes for the spark plug wires should have the same wrinkle finish as the cam covers. The one in the photo does not appear to have this finish. On the other hand, the hose clamp at the radiator may look a little too shiny. Is it a cad plated Cheney?
  15. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,921
    romano schwabel
    it looks like semigloss
    they also have
  16. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    OK How about the hose clamp
  17. turbo-joe
    Apr 6, 2008
    8,921
    romano schwabel
    you can not expect such a minor thing that it is original afetr so long time
    when I do a major for example on a TR then I just replace all clamps
  18. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,614
    Pittsburgh, PA
    Matt F
    I love seeing a 330 GT in motion. It sounded quiet, though.
    What’s with the comment on 2nd gear? That’s for transaxle Ferraris. Unless 8401 has a bad second gear synchro, it should shift fine, even from cold.
    Matt
  19. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    OK for a race car.
    But if you are trying to restore a car, besides making it look good, if you want to show it, at least in America, you need to install original equipment.
    The only post world war II car to get best of show at Pebble Beach in many years was a Ferrari. Just before the show, the owner found that it originally had vinyl upholstery. So he had the beautiful expensive leather removed and replaced by cheap vinyl.
  20. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    Well, technically speaking, only time use of original equipment is (sort of) required is if/when owner wishes his/her Ferrari to be competitive in judging according to IAC/PFA guidelines/rules*.
    Enjoying a car by driving or just showing it at most events does not require use or a "need to install" original type hose clamps or other similar OEM components/details.
    How many vintage Ferrari owners you think will carry their cars original tool kit along should they ever brave an extended** leisure drives not associated with any organized events.
    * They also specify deductions/penalties for "over-restoration", although it appears a moot point since they don't seem to be applied as often as they probably should.
    ** That's what they were made for.
  21. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    Lowell said ↑
    Looking again at the photo, I'm pretty sure it is not semigloss and not wrinkle.
    And I really do not like the quilted leather inside the car.
  22. turbo-joe
    Apr 6, 2008
    8,921
    romano schwabel
    you may enlarge the photo, then you see the wrinkle
    when you see gloss black it is much more shiny and when you see pur matt it is much more matt than this here. may be it is not 50 % semigloss, only 30 %? ;)
  23. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    If you have to enlarge to see the wrinkle, then it is not wrinkled enough. The cam covers show just the correct amount of wrinkle with no enlargement. Therefore, the two wrinkles do not match.
    The air filter covers should be 100% semigloss, not x this and y that.
  24. ArtS
    ArtS F1 Veteran
    Nov 11, 2003
    8,993
    Central NJ
    Steven,
    Thanks for sharing the video, it was fun to watch.
    Regarding all of the correctness comments, I'm also a bit curious about the interior. Apparently the car is 'Classiche Certified.' Are interior modifications not considered in the certification process? No rocker switches, the pad below the dash is tan leather rather than black vinyl, the headliner seems to be tan leather as well and the ignition switch seems odd.
    Its a pretty car done to the owner's personal taste but what is the big stink about Classiche if the car looks nothing like it did when it left the factory? Not intending to stir things up, just strikes me as odd. Probably been debated and discussed before.
    Regards,
    Art S.
  25. miurasv
    Nov 19, 2008
    10,034
    Cardiff, UK
    Steven Robertson
    I'd wondered the same myself. It would be interesting to see the details in the Classische Red Book as they are all subject to qualifications with all deviations from how the car was built should be noted in the book. Or, it was certified before the car was restored as it now is?
