Running Lights not Working | FerrariChat
Discussion in '360/430' started by Pete Schweaty, Dec 17, 2024.
  1. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    254
    Hey all, I feel a little dumb here as I am not sure if anything is wrong, or if it has been wrong for a year and I am just noticing! I own a US spec 2005 f430. I just noticed the light strip in the headlights does not light up under any circumstances. Headlights on = light strip off. Parking lights on = light strip off. Headlights on in the first position = running lights off. The other parking lights (side marker and tail) come on. What gives. When are they supposed to come on. What are the odds that its just bulbs on both sides. Like I said, I never noticed if they ever worked and I have owned the car for almost a year! Image Unavailable, Please Login Image Unavailable, Please Login
  2. Qavion
    Qavion F1 World Champ
    13,818
    Ian Riddell
    Strange. Your side markers (orange) are working. According to the wiring diagrams, these are spliced into the wiring for the main lamp assemblies. This means your relays and fuses are ok.
    I'm not familiar with the internals of the main light assemblies, but maybe you do have a dual lamp (or internal power supply failure) failure. Ouch.
    If you can find a yellow/black wire (on the left side) or yellow wire (on the right side), going to a plug on the back of the light assembly, check these for 12 volts.
  3. Qavion
    13,818
    Ian Riddell
  4. Pete Schweaty
    May 21, 2014
    254
    Thanks. I haven’t done any troubleshooting yet, I was just curious what the appropriate behavior is. Should they be on when the headlights are on, and when the parking lights are on?
  5. Qavion
    13,818
    Ian Riddell
    Externally, there doesn't seem to be any logic which stops the LED strip working when your headlights are on. If there is any logic, it will be in the lamp assembly itself. Anyway, your lights don't seem to be working whatever the configuration. The Park lights and stalk switch controlled lights have separate fuses and relays, but ultimately, the wiring is spliced together before entering the lamp assembly.
  6. colorfull
    colorfull Formula 3
    2,280
    Franklin Park, New Jersey
    John Napoli
    According to the manual which can be downloaded here
    https://data2.manualslib.com/pdf2/47/4672/467129-ferrari/f430_owners_manual.pdf?2ab9fc8d17100227c0c78fdf34846a48&take=binary
    'Position' lights go on at the first stalk click
    The fairy lights come on when you do that, or when you hot the P button on the center console
    They stay on when low beams go on, not sure about high beams
    If I were to take a guess, I would guess somehow you have no bulbs, not sure how they would have both failed or it would be electrical
    Maybe someone worked on them and didn't put them back. These are small, fragile bulbs, could be a fluke and they are out.
    The fairy lights are the small 'valeo' rubber cover in the outside corner of each side which you just pull off
    You should be able to access through the fender well hatch without removing the lamp from the car or even the fender well cover, though it would be easier if you do remove the fender well cover.
    I'd start with that
  7. cpep
    cpep Formula Junior
    428
    new york
    CHARLIE
    I had the same problem and it was the bulbs. Can be done with the tire on but it's not easy.
    Qavion and colorfull like this.
  8. Pete Schweaty
    May 21, 2014
    254
    Thank you. I'll start with the simple stuff like checking the bulbs. I mean, it's possible they are 20 years old.
    colorfull likes this.
  9. colorfull
    colorfull Formula 3
    2,280
    John Napoli
    I replaced mine with the SCUDing and when I pulled them out they were looking pretty nasty
    Hopefully that's all it is
  10. Qavion
    13,818
    Ian Riddell
    Are you saying they are individual, replaceable lamps and not LEDs soldered onto a flexible circuit board?
  11. colorfull
    colorfull Formula 3
    2,280
    John Napoli
    Unless I am misremembering they are just small bulbs that illuminate the plastic tunnel
    Which is why they are not that bright
    I will have a picture in a couple of hours
    I am talking about the OEM ones not the scuding
    I meant when I pulled out the OEM ones that were looking pretty nasty
    the Scuding ones are absolutely spectacular LED frames
    NYC Fred and Qavion like this.
  12. cpep
    cpep Formula Junior
    428
    new york
    CHARLIE
    Hella H6W Bulb H6W 12V 6W Bax9S T2.75
    Qavion likes this.
  13. Mario Andretti
    Mario Andretti Formula 3
    1,743
    Boston
    Qavion likes this.
  14. Pete Schweaty
    May 21, 2014
    254
    1) They are just regular H6W bulbs.
    2) I am a moron and didn't realize for a year that my bulbs are burnt out. Simple fix. Thanks for all the help.
  15. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    FWIW, Normal Guy Supercar has a DIY Youtube video how to replace the LED strip lights.
  16. Pete Schweaty
    May 21, 2014
    254
  17. colorfull
    colorfull Formula 3
    2,280
    John Napoli
    nah, if you are then I'm in the club, think we've all had our DOH! moments.
    you must be enjoying the new look!
  18. cpep
    cpep Formula Junior
    428
    new york
    CHARLIE
    Trust me I checked every fuse in the car before I decided to check the bulbs.
    Mario Andretti and colorfull like this.
